08-04-2020, 01:58 AM | #155 |
Rep 250
Hi. Have you tried:
Updating the apps? IDrive - apps - option - update all apps And/or Reset iDrive - hold down the volume button for 70 seconds (let it cycle through twice basically) That worked for me.
Current: 2020 M340i
Past: M140i, Z4 35is |
08-04-2020, 06:44 AM | #157 | |
Rep 309
Did both and nothing, no spotify, neither bmw music. Last edited by FrostNixon; 08-04-2020 at 07:21 AM.. |
08-04-2020, 08:52 AM | #158 |
Rep 2,699
Drives: 23 X5MC
08-04-2020, 10:24 AM | #159 |
Rep 309
CDN-Driver692.00 |
08-05-2020, 07:06 AM | #161 |
Rep 11
I went into the dealership today for the annual maintenance service. Inquired to update the iDrive software to the 7/2020 version with wireless Android Auto. The service advisor told me the update will be available for free OTA this fall, but if I want to get it installed at the dealership now there will be a cost. He even showed me an email dated 8/4/20 from BMW to the service advisors that mentioned it. When I asked him how much the cost would be he said it'll be $300. I was quite baffled by it as I have never heard BMW charging a fee for software update. My vehicle is a 2019 BMW 330 with Live Cockpit Professional. Anyhow, I tried to argue with no vale as he insisted he was following the guideline and I'd have to pay to do the software upgrade. Does anyone here have the same issue? I'd prefer to do the update at the dealership as I don't want something to go wrong during OTA.
08-05-2020, 08:36 AM | #162 |
Rep 80
08-05-2020, 12:10 PM | #163 | |
Rep 176
Drives: 2019 BMW 330i
https://www.bimmerpost.com/forums/sh...php?p=26490798 But honestly I didn't know how to explain the second SIB so I got 03/2020.39 sw and was told I received the latest... Now I just want to code my car, my guess is we can't do our own software updates with esysx? |
08-06-2020, 11:17 PM | #164 |
Rep 29
Has anyone in Australia had any luck getting the Remote Software Upgrade to work? I'm stuck on 03/2019.70 and every time I check in iDrive and on the Connected Drive app (iPhone), it's telling me No Upgrade Available.
I'm having intermittent issues with Carplay connectivity, and Connected Drive Remote services. Any advice to manually get the car to download this without taking it to the dealer? |
08-07-2020, 12:07 PM | #165 | |
Rep 198
08-07-2020, 05:13 PM | #166 | |
Rep 37
I know others are on 2020 versions of iDrive now but my 11/2019 is 100% stable and I have no issues at all so I'm not fussed about getting the latest. I did have heaps of problems when I was still on 03/2019.x so I would get the dealer to upgrade you. |
08-07-2020, 05:25 PM | #167 | |
Rep 29
08-07-2020, 05:51 PM | #168 | ||
Rep 37
08-11-2020, 10:34 PM | #169 |
Rep 690
Finally, I received message that 11/2019.70 was ready to install in car. I didn't expect it to tell me this after the car was turned off, I just happened to notice the message said it had to be parked and would take 20 minutes. I started the installation screens turned off heard fan running, waited, and then after about 20 or 30 minutes nothing happened never said it was done or anything. So I figured I would start the car see what happens. Started car and said installation complete. then as I was getting ready to go the car alarm started ringing and I couldn't figure out why and would not turn off. I turned off car and alarm was still ringing tried BMW connect app to turn on and off tried starting car and turning off again I had to disconnect battery to stop alarm. Then re-connected battery. I don't know if I now have to register the battery? But the car works, and I noticed the alarm is so much lower than the F30 340i alarm. The update caused some lost data like I had to re-set the drive recorder and re-connect the iPhone blue tooth lighting apple car play was all messed up, etc I wasted an hour with this update, didn't expect this at all. I did not notice any difference in the exhaust note pops burbles or driving character all seemed the same. I may still go to dealer to ask them about the battery if it has to be re-registered I don't want to end up with a battery problem down the line and the alarm, maybe its faulty that it is so low and went off when it should not of? I didn't see anyone else say alarms went off needing to disconnect battery. I am glad I had tools nearby.. anyways thats the saga of my 11/2019.70 update experience.
08-12-2020, 12:20 AM | #170 | |
1949
Rep 3,521
08-14-2020, 10:40 PM | #171 |
Rep 690
After recent 11/2019.70 installation I can not get Apple CarPlay to connect and PLAY anymore. It actually does connect and show the music library but it will just NOT PLAY. Tried so many things and it just will not play music. It worked for many months under the 11/2019.50 now it will not play. I tried disconnecting iPhone and re-pairing, forgetting wifi and bluetooth connections and re-pair, re-started car, re-started iPhone, Switched from SirrusXM and back won't work- the Apple Carplay works for phone calls and other stuff but not Music, I tried another iPhone too same thing, re-set iDrive holding volume button and I did all this in different combinations and over a period of 2 hours. I just do not understand why it connects and everything shows up on the screen and HUD the artwork and music library, etc but when I try to select and play anything it just refuses to play. I gave up. Has anyone else have this problem and any fixes you can recommend? thanks.
I fixed the Apple CarPlay today, works great Last edited by BMW11; 08-15-2020 at 10:32 PM.. Reason: update |
08-16-2020, 05:53 AM | #172 |
Rep 29
Got my iDrive updated by the local dealer at Sylvania, they updated it to 03/2020.69. Shame, I was hoping for the 07/2020 version, seems there's a few more goodies introduced in that version.
08-16-2020, 11:18 PM | #174 |
Rep 1,067
Has remote engine start been removed from the bmw connected app ??? I no longer have that option. There’s no way they only give you that for a year ? What an extreme disappointment if that is the case.
08-17-2020, 08:33 AM | #175 |
Rep 7
After the OTA update, I had to re-enable it in the car. This was for my 2020 G20. The update had reset that setting back to default for me. Within a few minutes of updating that setting, the app saw that I could remotely start car again.
08-17-2020, 10:35 AM | #176 |
Rep 1,067
Haven’t gotten an OTA update yet...do you know which menu I can enable the setting ?
Tags |
g20, software update, software upgrade |
