04-16-2024, 12:07 PM | #3 |
Rep 343
+1...... a tiny bit of light fogging sometimes in the bottom 1/4 inch of the light nothing more. Thats a clear water ingress and needs attention.
04-17-2024, 06:36 AM | #4 |
Rep 3
04-17-2024, 12:41 PM | #6 |
Rep 1,799
Were there droplets or just condensation? Can't tell from the photos. Did the condensation dry off on its own after a while? If not, perhaps try a different dealership.
04-17-2024, 03:14 PM | #7 |
Rep 3
04-17-2024, 03:33 PM | #8 |
Rep 129
Drives: 2021 bmw m340i xdrive
Service department will say anything to avoid warranty work. This isn’t normal. Does not happen often ( usually see this on after aftermarket tails or head lamps from being poorly sealed).
You can find good information on the website about this and then go speak to your dealership A common cause of minor condensation is a blocked vent. This could be caused by debris, spider webs or dust. https://www.carparts.com/blog/moisture-in-headlight/ If you notice condensation often, it could be a sign that the seals or gaskets protecting the inside of your headlights from moisture are compromised. Jun 26, 2020 Remove Condensation From from Headlights - source Toyota of Kingsport Blog Source Toyota of Kingsport The warmth of the bulbs paired with the cold weather can create the perfect environment for condensation, leading to the formation of water droplets inside … Hope this helps a little |
04-17-2024, 04:29 PM | #9 |
Rep 1,799
Ref manual. The level of condensation in your car seem a bit too much though. Are you able to reproduce the problem consistently?
04-17-2024, 04:42 PM | #10 |
Rep 331
I have seen this once on my car. It went away with some driving. It appears to be normal for condensation to form under certain conditions. It is only a problem if it does not go away.
***Excerpt from my 2022 G26 manual. Headlight glass The inside of the headlight glass can fog up in cool or humid weather. When driving with the lights switched on, the condensation evaporates after a short time. The headlight glass does not need to be changed. If despite driving with the headlights switched on, increasing humidity forms, for instance water droplets in the light, have the headlights checked. |
