10-23-2008, 01:59 PM | #68 | |
PCA, BMWCCA
102
Rep 2,058
Peak HP or torque doesn't mean a flippin' thing, unless you've figured out a way to stay at a precise point on the rev counter while transitioning through the gears, and that's impossible. Ultimately all that matters is the averaged whp across the entire rev range for normal driving, or the high average whp (midpoint of rpm spread to the redline--averaged) for aggressive driving/racing. Find those figures and you'll see that the N54 fails miserably as it makes its peak power and torque at midpoint and below and continously looses whp/torque as the revs go up toward redline. And redline is important as that determines the maximum velocity per gear. Even chipping the N54 only does so much due to the sharp power fall off. The major difference between the two power deliveries is that the M car has to be rev'd hard, but in that range it's producing very high sustainable whp all the way to redline. The N54 spools up quick to midrange and then flattens out considerably. If you like to keep the revs low for what I consider a lazy approach to spirited driving, the the N54 is your motor. If you like high whp and high revs and appreciate the reward, the S motors are for you. High averaged whp N54 = 243.43 S54 = 271.22 S65 = 329.93 Factor the high averaged whp to weight and the Z4 M and new M3 are very close, and both are far above the 135i/335i. The S motors can be modded too for even faster acceleration and quicker revs, and let's face it, the packages (overall cars) are far better balanced. High averaged Whp-to-weight (mid revs to redline averaged whp divided by curb weight) 135i = 83.75 high avg whp per 1,000 lbs. 335i = 79.10 high avg whp per 1,000 lbs. Z4 M = 98.05 high avg whp per 1,000 lbs. E92 M3 = 100.65 high avg whp per 1,000 lbs. Comparing the 135i and 335i, above high averaged whp to weight, and the 135i's slightly lower overall gearing (due to a smaller rear tire circumference vs. the 335i) is why the 135i accelerates faster than a 335i.
'08 Carrera S 6MT Guards Red/Black ext leather, Carbon fiber pkg, sport exh, sport chrono +, PASM, Nav, Bose, 19" forged turbos, red tranny tunnel
'07 MV Agusta F4 1000 R 1+1, Corse Red/Silver, RG3 race pipes and factory race ECU Last edited by MVF4Rrider; 10-24-2008 at 04:07 AM.. |
10-23-2008, 04:05 PM | #69 | |
PCA, BMWCCA
102
Rep 2,058
FWIW, I prefer the E46 M3 to the E92 M3. The E46 M3 is simply the industry standard sports coupe. The E92 M3 is great for sure, but too plush for my taste. Although the M-DCT is worth the price of admission. And for those who think turbos have a modding advantage have never searched for performance parts for a E46 M3. You don't need any type forced induction to make a E46 M3 (or Z4 M for that matter) into even more of a track star than they already are. There are far better ways to make a car accelerate quicker than by adding power to the motor, which adversely affects economy and potentially warranties. Although, the S motors can gain there as well quite easily and far more reliably. In the photo below, the BMW Motorsport (factory customer race car) Z4 M only produces 400 hp. But the car weighs little and for sure no hp is wasted.
'07 MV Agusta F4 1000 R 1+1, Corse Red/Silver, RG3 race pipes and factory race ECU Last edited by MVF4Rrider; 10-24-2008 at 04:27 AM.. |
11-20-2008, 02:49 PM | #70 | |
Rep 2,406
I'm thinking of getting a used m6 just because of the sound but if what you said is true, I may consider the new m3. |
