05-12-2022, 02:29 PM | #67 |
General
10487
Rep 40,949
Drives: 2018 Alpina B6 650ix GC
Update is due out today with latest 4.35.21 mapping.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
panki_86128.50 |
05-14-2022, 05:51 AM | #68 |
Rep 253
Drives: BMW M3 Comp Xdrive
05-14-2022, 10:16 AM | #69 |
General
10487
Rep 40,949
05-23-2022, 10:03 AM | #71 |
General
10487
Rep 40,949
PM sent.
05-25-2022, 09:36 AM | #72 |
Rep 2
Hey together,
I'm thinking about whether the software is worth the $99 for me. I only found little informations on their website. Maybe someone already using the software can help me and answer my questions.
Greetings Chris |
05-25-2022, 09:55 AM | #73 | |
General
10487
Rep 40,949
2) Most Cheat Sheets are located on GitHub repository: https://github.com/packetpilot/bmw-f/tree/master/cheats 3) No. If coding produces undesirable results, just recode with original values. If coding a feature lacking required hardware, coding will either complete successfully, but feature simply wont work, or FDL coding will just fail to complete with a NotExecutable error.
05-25-2022, 12:10 PM | #74 | |
Rep 2
it seems to be very hard to find proper/coplete cheat sheets for G-Series cars like the G20. Or is it because I'm not searching properly? |
05-25-2022, 01:26 PM | #75 |
General
10487
Rep 40,949
No, they are few and far between.
05-26-2022, 09:12 AM | #77 |
General
10487
Rep 40,949
05-29-2022, 11:33 AM | #78 |
Rep 59
I'm using Esys with BU.
Works fine but still have some bugs. For example this one. I'm trying to enable TLA and LCA on a G08 Lci with 21.11 software and Psdzdata 4.34.25. But when I select and apply the cheat codes this is the result (Obviously nothing works.) Any advise ? |
05-29-2022, 11:47 AM | #79 | |
General
10487
Rep 40,949
05-29-2022, 12:02 PM | #80 |
Rep 59
Good point. Let me explain better
I enabled everything ( aSLA, TLA, DAP HIghtway, DAP Emerency lane ) from BU cheat interface I coded car with resulting .ncd modified by BU. I reloaded SAS3 000042c1_003_005_006 and you can see the result. Strange to look at same function enable and disable at the same time. TLA and LCA still do not work. I can select both from Idrive menu but nothing happen |
05-29-2022, 12:13 PM | #81 | |
General
10487
Rep 40,949
In this case, the coding does not work on your car, meaning either car is not capable of these functions or the cheat FDL Codes are incorrect, or incomplete. You are coding only SAS Module. Is that all that is needed for aSLA, TLA, DAP Highway, DAP Emergency lane? No Head Unit coding or other ECU's too?
05-29-2022, 01:57 PM | #82 |
Rep 59
Cheats options seems to be embedded on BU. I wrote to support@bimmerutility.com and they just told me that those cheats are coming from Almaretto.
About BU you are right, BU works ( also if it seems that part of this NCD file is still cripted). But le me say that to have the possibility to FDL without knowing what modify it's not the best. Back to LCA, yes , also MGU and Body must coded: - HU_MGU (3E52)\Spurwechselassistent gen_1 - BDC_BODY3 ( 7083)\activ - SAS3 (42C1)\C_SWA_Vorhanden NR001_VORHANDEN - SAS3 ECU C_SLA_UCC_LAND_AKTIV and C_SLA_aUCC_LAND_AKTIV and overide the 08:00:00:00 value to FF:FF:FF:FF For any doubt, i also removed 8TR from VO and coded MGU, Body and SAS. I guess there is something related to Europe countries. |
05-29-2022, 02:12 PM | #83 | |
General
10487
Rep 40,949
05-30-2022, 02:04 AM | #84 |
Rep 59
05-31-2022, 08:23 PM | #85 |
Rep 451
Drives: 2017 X5 & 2020 X5
I have produced a sheet for my Australian Spec G05 (X5) to do aSLA, TLA and other MY21 features that IFR discovered in 2020/21. At the time i was using Launcher Pro that had outdated mapping and could not read the correct descriptions but with the assistance of an ESysx Expert user i generated a cheat sheet that ignores the incorrect mapping labels and uses the file allocation position data to code the vehicle correctly.
I have since added on more cheat options using BU's cheat editor feature. Unfortunately BU does not have a feature to select specific cheat sheets so to prevent confusion i removed Almaretto's xml file from Cheatcodes directory and replaced it with my own If anybody wants a copy of my file PM me their email address and I will send it to you. I do however implore those who want to go down the road doing this advanced coding to learn how to create these sheets and customise them for their own BMW. It is extremely important to understand what each and every command line does as these are not just cosmetic changes on the dashboard but significant changes in the vehicle's driving behaviour especially braking. I taught myself after reading an excellent tutorial written by Almaretto posted on the Car technology Forum on how to create these xml files. Remember it is very rare for one model to have the same FA build level components etc so some codes will work on some and others not
Current: MY 20 X5 2.5d xDrive MSport
MY 17 X5 2.5d sDrive Last edited by Bambazonke; 05-31-2022 at 08:36 PM.. |
05-31-2022, 09:13 PM | #86 | |
General
10487
Rep 40,949
06-03-2022, 04:55 AM | #87 | |
Rep 59
Thanks to Bambazonke and shawnsheridan . Now i understand how to use BU in the right way i have to say it works very well A tip: it would be useful to have the chance to choose between different cheat codes (if you have more than one) Last edited by modomi06; 06-03-2022 at 05:02 AM.. |
Bambazonke210.00 |
06-03-2022, 08:43 AM | #88 | |
General
10487
Rep 40,949
