09-22-2021, 08:57 PM | #111 | |
1937
Rep 3,520
09-25-2021, 06:43 PM | #114 | |
1937
Rep 3,520
I used the passenger side fuse box.
09-26-2021, 10:25 PM | #115 | ||
Rep 221
IG: ember.m4
09-27-2021, 10:19 AM | #116 |
Rep 8
Yes, those are both in the passenger fuse box, for me it’s easy to access but you will need a flashlight to confirm the right position of both fuses.
09-27-2021, 10:25 AM | #117 | |
Rep 8
11-24-2021, 08:49 AM | #118 |
Rep 395
Quick question to the peeps that installed the blackvue magic pro, when you switch the unit off, does it lose power immediately (green LED turns off)?
11-25-2021, 04:02 PM | #119 |
Rep 395
Does anyone know if any of the F46 to F57 fuses are ignition only?
Or is it just the F59 to F76 ones? I need to find a 20a ignition only fuse and the green ones above are 5a or 10a |
05-21-2022, 02:18 PM | #120 |
Rep 81
For those who installed Viofo A129 Pro Duo, where did you hide all that excess cable for rear camera? I ran the cable from front camera to rear camera and there is like 4-5 ft long extra cable. I don't know how or where to hide them.
06-20-2022, 04:08 AM | #121 |
Rep 69
Took delivery of a new '22 Pre-LCI G21 on Friday. Dash cam is on its way so found this thread over the weekend.
I've just had a look this morning and it has been revised on my model. There is an airbag in the footwell (UK model and on driver's side/right hand of vehicle) and I think because of this, BMW have replaced the twist screws/clips with an 8mm long bolt on either side. The bolt screws all the way out, rather than being captive and then the panel drops with the airbag module staying in place. It gives slightly less room to work in, but if you're coming down the rubber seal on the right hand side of the car into the dash behind the panel that pops off on the end of the dash, you are straight to the fuse box and nowhere near the airbag module, so still safe to run the positive wire that way. I'll get some pics when the dashcam arrives and I get to fitting it.
Type R #1 - 04 EP3 CTR (R029751) - SOLD, Type R #2 - 57 FN2 CTR GT (R008686) 256bhp - SOLD, 60 WRX STi Type UK - SOLD, Type R #3 - 58 FD2 CTR - SOLD, 13 Foad Focus ST-2 - SOLD, Type R #4 - 09 CW FN2 CTR (R#0223) - SOLD, Type R #5 - 15 FK2 CTR GT - SOLD, F30 330d xDrive LCI - Sold , MK3 Croacus Titanium X - Sold, Type R #6 - 09 CW FN2 CTR (R#0232) - SOLD, BMW #2 - 19 F39 X2 M Sport X sDrive20i - Gone, BMW #3 - 22 G21 M340d xDrive -
06-29-2022, 08:53 AM | #122 | |
Rep 69
Went down to the fuse box the usual way through the end of the dash by popping the end cap off, and zip tied the spare wire in here to the beams behind the switch panel to stop it rattling around. Used fuse #59 which is for the Emergency Call Assist if anyone is interested. Front: Rear fitted later:
02-26-2023, 05:46 AM | #123 |
Rep 1
[QUOTE=loxy;29060322] It wasn't massively different to what has already been posted on here to be honest, just with the 8mm bolts and an airbag in the middle of the underside of the dash, so I didn't really get that many pictures.
Went down to the fuse box the usual way through the end of the dash by popping the end cap off, and zip tied the spare wire in here to the beams behind the switch panel to stop it rattling around. Used fuse #59 which is for the Emergency Call Assist if anyone is interested. Front: Rear fitted later: Hi going to be trying this myself as soon as we get some dry weather (same RHD, G21). Really like what you did with the rear cam - what did you use to clip around liner & stick the mount to? Thanks! |
02-27-2023, 09:57 AM | #124 |
Rep 2
Dashcam Fitting
Hi All Sorry if this has been asked before as I'm new to the group and have become the proud owner of a 340D.
So i have found the fusebox in the rear offside wing behind a small panel. I have a Blackvue 650S and wanted to know about piggybacking a fuse. I have always used the cigarlighter fuse as it comes on and goes off with the ignition. BUT..... I have noticed members say that the fuse box is in the drivers footwell. If only I had discovered this forum fisrst Ive Ive run both (front and rear) cables the entire length of the car into the boot fuse box ready to piggyback. So Do i now need to undo this and take it to the footwell fuses? Also I have been told that using a piggy fuse will void the warranty so do member disconnect there cameras prior to drop offs at dealers. For members who may not know the 340D and possibly others are on a recall (Mines a 2022) for updates on bluetooth and wifi. I had mine done last week and it identified the rear park camera needed replacing (it's got 650 miles on the car). Just thought this may support other members to get their update. Anyway its great to have joined and look forward to the reply about where the fusebox is or if I could pigy a fuse in the rear offside inner wing as i'm cabled up to that. TIA for any replies |
03-04-2023, 08:53 AM | #125 | |
Rep 552
Nothing is going to void your warranty unless BMW determines that it contributed to a problem, in which case they may decline to repair under warranty. My car was recently in for its first scheduled service and the cameras recorded the entire visit. Here's the thread about my installation.
2022 M340xi Tanzanite Blue II Metallic
03-23-2023, 04:09 PM | #126 | |
Rep 153
03-29-2023, 12:31 PM | #127 |
Rep 2
HELP HELP HELP fuse for dashcam
Hi all I have a G20 M340D. I have fitted a front a rear Blackvue 650 DASHCAM
I have followed the recommendations here to use a piggyback fuse in F273 which is a fuse in the rear 1/4 panel. However this seems to be a permanent live. Can anyone recommend an alternative fuse that will be a switch-live so will power off when the ignition is of please. All the hard works done. Just need a fuse and have a diagram for the rear fuse box but nothing that identifies which fuse does what TIA |
04-02-2023, 01:03 PM | #128 |
Rep 13
Have just tried hardwiring a Transcend dashcam to my newly acquired 330e but it seens the ignition fed fuses are constantly live when the vehicle is plugged in and charging!
Any suggestions ???? |
04-04-2023, 04:35 PM | #129 |
Rep 13
After a bit more investigating, when the vehicle is plugged in and charging the 12 v battery fitted in the right side of the boot is also being charged(14.9/15.1v)
I also fitted a voltmeter to the 12v socket in the centre console and this also confirms that the block of ign fed fuses remain live when the vehicle is plugged in and charging. When NOT plugged in, the ign fed fuses will loose power after a few minutes when the vehicle is locked as the BCM goes to sleep. |
05-03-2023, 12:38 PM | #130 |
Rep 841
Drives: 2020 BMW M340i xDrive
Just got done doing my dash cam install and wanted to say thanks to everyone on here for the super useful tips and info. Rain started coming towards the end of the install so I couldn't snag any photos, but here's a synopsis:
Dash cam is a Viofo A139 Pro, single channel, paired with a Blackboxmycar Powercell 8 Battery Pack. Blackboxmycar recommends using at least a 20A fuse to tap for the battery packs. They ship add a fuse kit of every size, with accompanying 20A fuses. I used the passenger footwell fuse box for power connections. F54 was empty in my car and fuse diagram says it's a 20A slot. I used a circuit tester to verify it's an ACC circuit, and that the right side is the hot side. I used the ATO sized fuse tap to match what the fuse box had. I put their provided 20A ATO fuse in the top part of the fuse tap, nothing at the bottom, and put the fuse tap in the vehicle with the leg pointing left. Battery pack comes with Velcro stickers, so I stuck it on the carpet against the back of the passenger side footwell. The Tuxmat floor mats cover up that entire area, so the pack and wiring are out of sight. Rest of the install is straight forward as everyone else has done. Dash cam power up the A pillar and over to the camera. Verified the battery pack switches to discharge mode once vehicle is asleep, and camera parking mode recording turns on.
Hey Google, play "Who Am I" by Beenie Man Last edited by k4sh_90; 05-03-2023 at 12:59 PM.. |
05-05-2023, 09:43 PM | #131 |
Rep 71
I looped it a few times tucking under the door sill.
05-19-2023, 09:33 PM | #132 | |
Rep 71
