10-23-2021, 02:28 PM | #881 | |
General
10445
Rep 40,772
Drives: 2018 Alpina B6 650ix GC
https://www.bimmerfest.com/members/dayvg.437094/ He has working LauncherPRO 3.7 solution for FDL coding.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
10-23-2021, 05:07 PM | #882 |
Rep 1,777
Thanks shawnsheridan I just registered on bimmerfest but I don't have the option to PM/start a conversation. It appears I will need to have a minimum number of posts before I can PM so I have no way of reaching dayvg at the moment.
10-23-2021, 05:11 PM | #883 |
General
10445
Rep 40,772
I think for Bimmerfest, you only have to wait an hour.
10-23-2021, 05:14 PM | #884 | |
Rep 1,777
10-25-2021, 05:03 PM | #885 |
Rep 1,777
shawnsheridan big shout out! I got launcher pro from dayvg - I can also confirm that dayvg provides product support after I ran into a few installation hiccups which was fixed immediately. Successfully FDL/NCD coded additional parameters for anti-dazzle. Thanks for the pointers.
10-25-2021, 05:57 PM | #886 | |
General
10445
Rep 40,772
10-28-2021, 06:37 PM | #888 |
Rep 46
Drives: 2020 G20 330i
Two questions since i've been out of the coding game for awhile, just looking to get back the functionality i had enabled before the last software update which wiped all that out;
I had the tesla mode driving assistance with lane change enabled, and working and i had the anti-dazzle lazer headlights working perfectly now two things from my attempt tonight 1) i encountered an error in esysx when attempting to edit a CAFD file from the coding window - picture as you will see displaying the error. I believe it is a software error only as I'm still able to browse to the CAFD file manually and open it in the FDL editor (same thing the software is triyng to do no?) 2) all the FDL edits are still showing up when I load from the ECU, i attempted to make them and found all the changes made (still) and the settings activ instead of nicht-activ ... so if the changes are already on the cars ECU why are the features not working? is there something else I need to do to 'enable' the ECU to use these changes now...? slightly confused on the process now, since the original plan is make changes to FDL, code it to the ECU, and done. but it seems that part has 'stuck' through the bmw software update ... so a little lost now on the next step! even the removal of 5AP for the VO portion of the anti-dazzle change has stayed |
10-28-2021, 07:50 PM | #889 | |
General
10445
Rep 40,772
10-28-2021, 08:05 PM | #890 |
Rep 46
10-28-2021, 08:33 PM | #891 |
General
10445
Rep 40,772
10-28-2021, 10:54 PM | #892 |
Rep 1,777
VO coding survives through software upgrades. That would explain why your VO doesn't have 5AP. Also depending on the FDL you are referring to — after you VO code anti-dazzle, a couple of them automatically change to aktiv:
C_HBA_DIM_ENA C_HBA_GFHB_ENA If you're referring to these, that's expected. Are you sure your anti-dazzle isn't working? Was it working before the last update. |
10-28-2021, 11:07 PM | #893 | |
Rep 46
the other indicator is like i said all the FDL edits I made for the lane change assist and drivers display (tesla mode) are still there, but it's also not active in the car so it seems to me like all the edits persisted but I need to maybe re-code it into the ECU? not sure that makes any sense, as it is pulling the data directly from the ECU already when I read it right? that's why im saying im a bit stumped, because i went in to make the changes, going down the list and saw them already there.. so i was like ok what now...? I can't save the file because i didn't make any changes! lol |
10-30-2021, 10:21 AM | #894 |
Rep 1,777
Sounds like you'll have to recode. Never seen this kind of problem before. Typically an update does clear your FDL coding. But seeing that you have issues with Esysx I'll wait to fix that and then check the CAFD values for each of those ECUs
10-30-2021, 04:43 PM | #896 |
General
10445
Rep 40,772
Use Read (ECU), not Read (VCM).
10-30-2021, 10:17 PM | #898 | |
Rep 2
10-30-2021, 10:19 PM | #899 |
General
10445
Rep 40,772
10-30-2021, 10:58 PM | #900 |
Rep 2
Does not appear the option to send a PM to him, if I try to play the direct link appears the message "You do not have permission to view this page or perform this action.". This is both on an older account and on a brand new account.
10-30-2021, 10:59 PM | #901 |
General
10445
Rep 40,772
PM sent.
