Technical Topics DIYs and Coding Discussions M340i M display and M tach on HUD
      07-11-2021, 03:09 PM   #23
bimleaf
Drives: G20
This can’t be simply coded. There are hardware differences (i.e. require changing to a M car instrument cluster such as an M3’s)
M340 is not an M car and does not have the required hardware for M view in the hud.
      07-15-2021, 01:59 AM   #24
hayko_M340
Drives: 2020 BMW M340I
Well the guy who originally posted this was able to do it in a M340i if I'm not mistaken...
      07-15-2021, 02:12 AM   #25
bimleaf
Drives: G20
Sorry I can’t tell from the post if OP installed an M cluster or coded the cluster to the M layout.
Maybe OP can clarify?
If it is just coding the cluster to the M layout then yes it is doable on the M340.
      07-15-2021, 02:52 AM   #26
maximking
Drives: F10
it's more then average coding , can be done
      07-15-2021, 04:41 AM   #27
Heliot077
Drives: BMW G21
Without changing hardware? Coding possible with BC?
      07-15-2021, 06:00 AM   #28
maximking
Drives: F10
esys
      07-15-2021, 08:23 AM   #29
Heliot077
Drives: BMW G21
So you know exactly what to do?
      08-06-2021, 04:45 AM   #30
tooktoomuch
Drives: 2021 BMW 330i
2021 BMW 330i  [0.00]
Has anyone other than OP been successful in coding the HUD tachometer with the m gauge clusters yet? I've been looking around for awhile and am starting to lose hope .
      08-17-2021, 12:57 AM   #31
maximking
Drives: F10
pm me
      08-21-2021, 05:50 AM   #32
jpark137
Drives: M340i
That tach meter exactly what I want to see on my car!!
      10-03-2021, 04:57 AM   #33
deluded
Drives: BMW 330i M Sport
Found this on a different thread, not sure if it helps anyone here
https://x3.xbimmers.com/forums/showthread.php?t=1833561
      10-18-2021, 12:11 PM   #34
Mark729
Mark729's Avatar
Drives: bmw m340i Xdrive
Found it on ebay
https://www.ebay.com/itm/M-track-vie...-127632-2357-0
One life, live it ㅇㅑㅇㅁㅣㄴㅎㅗ
2021 BMW m340i xdtrive
2016 VW Golf R 6mt
2011 Subaru Sti
2007 Subaru Wrx
      10-18-2021, 01:51 PM   #35
helmet91
helmet91's Avatar
Netherlands
298
Wow… that's fascinating.
      10-22-2021, 10:33 AM   #36
itolev
Bulgaria
Drives: G21 M340i Touring 2021
Hi everyone,
I was trying to code the M_HUD from the x3 thread.
I make every step like the sinbad4 but without success.
Is there any difference between x3 and m340i in the headunit and instrument cluster expert coding ?
      11-04-2021, 02:42 AM   #37
hayko_M340
Found this for HUD but did not work for me with Bimmercode. Theoretically it should work because with Normal M340i displays it shows RPMS+ Shift Lights but disappears when coded to M displays all up to coding. As long as you have HU_MGU module people have been able to code it looks like just seems no one wants to break it down or release it.
Head Unit, HU_MGU module:
Expert Coding:
3010 M_GMBH
M_VEHICLE: aktiv
HUD_M: aktiv
M_DIGITAL_TACHO_EINH: aktiv
M_SHIFTLIGHTS: aktiv
M_KOMBI_LINK: aktiv
M_HUD_LINK: aktiv
M_EPS: 2_werte
M_MOTOR: 2_werte
M_Modus: 2_werte
M_VEHICLE_SP2018_RUEKO: aktiv
M_GETRIEBE: 2_werte
M_BRAKE: 2_werte
M_MOTOR: 2_werte
      11-04-2021, 06:18 PM   #38
muhammedjan
Drives: BMW M340i
Originally Posted by maximking View Post
esys
Can you post instructions on how to do with Esys. Never used it but I want to try it out.
      11-05-2021, 10:37 AM   #39
Erto90
Drives: Bmw g30 g20
esys
and is possible also to add m race cluster with esys?
      11-08-2021, 04:20 AM   #40
maximking
Drives: F10
not enough FDL coding , needs software flash
      11-16-2021, 08:12 AM   #41
maximking
Drives: F10
Designed V2 version of M track module soon will be on sale more details on fb
      01-18-2023, 05:21 AM   #42
srbs73
srbs73's Avatar
548
Drives: BMW i4 M50
Originally Posted by BBF5330 View Post
How to code tire press dispaly on live cockpi , thank u
HU_MGU
- CAFD_00003E52
- M_VEHICLE_SP2018_RUEKO - Ausgelesen = Active
      01-18-2023, 09:39 AM   #43
Marc R
Mr Anderson,we've been expecting you...
Marc R's Avatar
26
Drives: X3 M40i
Most annoying thing about the M cluster is that the street names are off center... i hate that.
      01-26-2023, 04:12 PM   #44
okankaymak
Drives: 2021 330xi M Sport
I don’t want to use the M cluster. I want to keep default cluster, can I still have the M HUD as in the pictures?
