04-13-2021, 04:20 PM | #67 | |
Rep 166
Fepaxd0.00 |
04-15-2021, 01:50 AM | #68 | |
Rep 681
Enable Tailgate close with keyfob or switch (No holding) 000055D7 HKFM2 300B HKL_REMOTECONTROLLIFTGATEBUTTON_BUTTON_TYPE Change to >05< Please have a look through and it would be great if you could add any codes that you know of, and that I have missed. I'm sure there are plenty of other codes missing from this list. eg: I'd like to know how to display the Tyre Temp and Pressure widget in the cockpit dash. I have asked for Lane Change Assistant to be added to BimmerCode Expert, but, unfortunately, the module SAS2 is missing from BimmerCode and, thus, this coding can only be performed with E-SYS at the moment. One particularly useful recent addition is reinstating the Tachometer in Sports Mode. After OTA updates 07/2020 and 11/2020.50, I found that my Tacho would not display in the HUD when in Sports mode unless permanently displayed was selected. It worked fine when my car was built in Jan 2020, but the OTA's wiped it out. This six line fix does the trick. After coding and while in iDrive, under Car Settings, Displays, HUD......change the sports displays to Automatic. Works a treat and still allows driving assistance displays in all other driving modes.
25
phillyd2218.00 rico2537.00 njfoses290.50 RedKloud736.00 Anotherg2022.00 biglesias3125.00 k4sh_90539.00 youngsandwich70.00 BlaSTiWi31.00 TTG936.00 Hoverauto7.00 JasonPetrie27.00 Kandymany7.50 x5driver_one0.00 Mark72913.50 jocamero48.50 jpowers36218.00 pdxdbo331.00 iiSonnyii67.00 Ruebarb373.50 ThreeDots1.50 Oxidgrey_bmw_g2131.00 PingJu_Wu0.00 abhishek9430.00 Denny.G210.00 |
04-15-2021, 04:44 PM | #69 | ||
Rep 44
04-16-2021, 12:58 AM | #70 |
Rep 242
Talisman77151.00 SteveAus265.50 |
04-16-2021, 02:56 AM | #71 |
Rep 562
04-16-2021, 04:11 AM | #72 |
Rep 242
04-16-2021, 09:45 PM | #73 |
Rep 681
It’s in my post, under “Attached Images”.
Just click the PDF icon and you’ll see the file.
04-16-2021, 09:46 PM | #74 | |
Rep 681
I’ll give it a go later.
04-17-2021, 12:41 AM | #75 |
Rep 166
04-18-2021, 04:49 AM | #78 |
Rep 336
Curious for the "colder air conditioning" - is there any info on what the values are doing here? I understand the first key is changing country variant, which is somewhat dubious all in the name of getting some cooler air; is that changing the region only for the A/C?
PingJu_Wu0.00 |
04-18-2021, 06:20 AM | #79 |
Rep 1,479
Drives: 2020 M340Xi (G20)
Hi,
One of my preset buttons takes me to displaying tire pressure; just displayed tire status & pressed and held preset button. Also, have on one of iDrive screens I also tried coding tire pressure widget in Instrument cluster, but in so doing, it forces iDrive into some kind of M display logic & knocks out Tach in HUD completely
Al
04-19-2021, 04:42 AM | #81 |
Rep 166
Hey guys, does anyone knows how to Code BMW Chime? I would like to change the BMW warning chime sound to the Roll Royce chime. Let me know if anyone do this on their G20, cheers!
04-19-2021, 08:00 AM | #82 | |
Rep 6,738
Drives: '18 M550i|'21 X5|'03 540i
Garage List 2013 VW Tiguan [0.00]
2015 Infiniti QX60 [0.00] 2021 BMW X5 [0.00] 2003 BMW 540i [0.00] 2018 BMW M550 [10.00] |
Can you elaborate more on the B&W Eq coding? I've got an EQ now, curious what this does. Thanks in advance. |
04-19-2021, 08:13 AM | #83 | |
Rep 63
04-20-2021, 05:08 AM | #84 |
Rep 336
Has anybody tried the HVAC_REMOTE_ENGINE_START (I don't recall where this was found but I want to say it's HU_MGU -> 3000 HMI) - seems like this might allow for the engine to start in order to run the air con, or perhaps I'm being too hopeful?
04-20-2021, 10:38 AM | #85 | |
Rep 146
Having the car start in certain modes is selectable in the standard Bimmercode options list. The Bowers and Wilkins HI FI enables additional sound settings for concert, stadium, cinema etc. Personally I find this sounds better than my standard Harmon Kardon equaliser settings. |
04-20-2021, 01:14 PM | #86 | |
Rep 6,738
04-22-2021, 10:32 AM | #87 |
Rep 63
Sadly you are being to hopefull, european cars need some hardware to, not only coding.
04-22-2021, 12:18 PM | #88 |
Rep 336
