10-10-2021, 11:10 PM | #156 |
Rep 263
10-11-2021, 02:29 AM | #157 |
Rep 10
10-11-2021, 11:28 PM | #158 |
Rep 263
11-03-2021, 11:29 PM | #161 |
Rep 29
I had the same problem after installing the BimmerTech Amp. The only solution was to use the Microsoft Windows amp software to connect via USB directly to the amp and adjust the gain down about 5 dB. That did the trick.
VertigoAtHome136.00 MattEcho53.00 |
11-18-2021, 07:25 AM | #162 |
Rep 29
I have a G20 320e, and I don't have the xtraboost. Something that can probably be coded..
I already saw that coding the sport plus makes a big difference and I want to do it. To use bimmercode, what adapter you guy recommend? To purchase from europe. Last edited by fifthelement89; 11-19-2021 at 02:09 PM.. |
11-20-2021, 11:35 AM | #163 | |
Rep 220
11-20-2021, 06:20 PM | #165 | |
Rep 63
https://www.ebay.com/itm/M-track-vie...-127632-2357-0 Last edited by mokorx; 11-23-2021 at 05:20 PM.. |
hanselfransel27.00 |
11-24-2021, 08:52 AM | #166 |
Rep 29
Guys, my g20 320e doesn't have xtraboost..
I was going to code SPORT PLUS when I saw there is an option for xtraboost! BDC -> Expert -> 3221 PfFesMaster -> FesSportWorldMode1 -> xtraboost What you guys think it would happen? from what it seems I can't code both xtraboost and sportplus |
12-21-2021, 05:34 AM | #168 |
Rep 7
Drives: BMW 330e Touring
WOW!!! What a great post thread this is and I hope to have a look at Bimmercode soon, as I've just bought the OBDLinkCX dongle. There are a couple of things I did wonder though.
- Is it possible to code in the Auto High Beam Assistance rather than pay BMW to switch it on? - No one here has mentioned how to program the exhaust flap open. Is that possible with Bimmercode or do I need Bimmerlink too? - Mine is a G21 330e (2022MY) and has XtraBoost as standard. Is that the same as Sport+ on the non 'e' cars? Regards Chris |
12-21-2021, 05:46 PM | #169 | |
Eurobimmer
21
Rep 39
- You can do it with ProTools, if your car supports it - I guess it's somehow different, since all the power management is quite different. Cheers |
12-22-2021, 08:45 PM | #170 |
Member
898
Rep 2,032
Drives: 2019 X5 40i M Sport
Garage List 2023 BMW M2 (HEA) [10.00]
2021 330i xDrive [0.00] 2019 G05 X5 M Sport [0.00] 2017 Jeep Grand Che ... [0.00] |
Does anyone know how to code the Auto High Beam to stay on. Our X5 remembers it but our 330 doesn't. I'm having to activate it every time I get in the car.
2019 X5 Alpine White M-Sport
Software Version 11/2022.31 2023 M2 (HEA) Brooklyn Gray 2021 330i XDrive Alpine White M-Sport |
12-24-2021, 06:39 AM | #172 |
Rep 1
12-24-2021, 11:19 AM | #173 |
Rep 263
12-24-2021, 03:45 PM | #174 |
Rep 3
Has anyone coded the digital cluster on a 330e? I ve tried with bimmercode but it seems I can’t change them without some defects. M performance applied nothing changed, m version removes the battery charge and alpina one seems to mix the rpm section with the OEM one. Maybe someone knows how to adjust them through expert mode
12-24-2021, 03:57 PM | #175 |
Rep 3
Hello, i have bmw xd 520 2021 , anyone had any experience with coding manual recirculation button. On my car once you activate manual recirculation it keeps the air circulating with in the cab for 2-7 minutes and then starts taking in the fresh air, after a while and in cold weather starts doing that almost every minute and when you are in traffic it is taking all other cars exhaust smelly air in the cab . Please help, one of the dealers told me it is normal for all BMWs to do that and always turn manual button off automatically . any idea? so far I shut off condensation prevention- beschlegsvermeidung, i translated these: kreis regelung wcc-circle regulation wcc and umluft auto aus-recirculation car off i am not sure what they do, still didn't try them. If anyone have detailed cheat code sheet for AC pls share. Thanks
12-25-2021, 10:54 AM | #176 |
Rep 83
