07-30-2021, 04:57 AM | #1 |
Rep 69
Driving Assistant Package
Hi peeps hope your all well?
I'm doing a few retrofits to my M340I. i wanted to know if it possible to retrofit Driving Assistant Package and what is needed? steering wheel, cluster with live cam, mirrors and radar sensor. top of my head i know these will be needed. not sure if the kafas camera from my car can be used. what ive done on my car and in process so far. laser headlights with inner surrounds painted black. high beam stalk. rear armrest panel with rear charging [IMG]undefined[/IMG][IMG]undefined[/IMG][IMG]undefined[/IMG] |
08-02-2021, 09:07 AM | #2 |
Rep 24
you ll need a new switch column as you may not have the wiring for new buttons
https://www.realoem.com/bmw/enUS/sho...diagId=61_6205 |
08-03-2021, 03:55 PM | #3 |
Rep 410
Subscribed. I am wanting to add the DAP as well to mine.
G20 WestMid51.00 |
08-17-2021, 05:05 PM | #5 |
Rep 353
Drives: 2021 M340i xDrive
This is awesome. Do you have a write-up or reference for doing this? I would love to do this mod. I've wondered why the M340 doesn't come with a rear 12v (cig lighter).
I'm also interested in retrofitting the heated rear seats to the rear console and buying the seats if they don't come with the element built-in. |
08-18-2021, 02:27 AM | #6 | |
Rep 69
i dont have a write up. i did all the wiring/fitting myself. its not hard to do. but you will have to remove the centre console and some wiring as bmw dont sell a loom. Whoever you buy the parts from tell them to supply the wires and connectors. once you get the parts drop me a message i will help you |
09-27-2021, 08:03 PM | #7 |
Rep 48
I was hoping to retrofit DAP as well. Along with the parts you listed, I think you'll need the parking assistant sensors (4) and the module that goes with that. I also think there's at least one more control module needed for the rest (not sure which, but since the park assist needs one, I'd assume at least the radar for the acc needs one). In addition I think you may need the updated kafas4 camera which also requires a new windshield. You may also need the driver attention camera that goes at the top of the instrument cluster.
The more I look into this for my 2019 g20 330i the more parts it seems are needed, and then there's the coding and activation hump to get over Let us know if you make any progress on this. |
10-04-2021, 10:24 AM | #8 |
Rep 73
Drives: BMW G20 320i M Performance
maybe need fsc code.
Freelancer without work
11-13-2021, 03:20 PM | #9 |
Rep 69
ive had the lights on for a while now. they do look amazing.
regarding the driving assistance professional ive purchased a few parts. mirrors, cluster with livecam, kafsa, front radar. i will need a steering wheel and windscreen. |
07-22-2022, 06:57 PM | #10 |
Rep 410
Did you ever make any progress on the DAP retrofit? From what one company said, the windshield has to be replaced in order to install the 3 cameras at the top.
07-23-2022, 09:03 AM | #11 | |
Rep 3
rear charging
How easy is the wiring for the rear charging?
07-25-2022, 02:05 AM | #12 |
Rep 102
If driving assistant is the stop and go cruise control thing, you will probably also need pulse generators, dsc module, and new brake lines. This is in addition to the cameras and sensors upgrade.
