09-12-2021, 04:40 AM | #1 |
Rep 166
Alignment Specs with Lowering Springs
Hey guys,
Anyone care to share their alignment specs, specifically with lowering springs? Do you use the factory specs? I currently have dinan springs and saw that they have their recommended specs - I'm curious how far off it is from factory and if anyone is currently using it. Thanks! |
09-14-2021, 12:23 PM | #2 |
Rep 2,700
What is your tire sizes ? So I can convert Dinan's instructions in regular toe measurements.
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp Daily: 2023 X5 45e Daily/Family: 2021 Atlas Cross Sport 3.6 |
09-15-2021, 02:20 AM | #3 |
Rep 166
09-21-2021, 01:42 PM | #4 |
Rep 2,700
Hey sorry for the delay, I converted the Dinan Specs to 0.24inch of total toe wich equates to around 0.12 each wheel. I don't know what is the OEM alignment specs but it should be around the same figures for toe (very street friendly with a steering that auto-centers easily) As for camber these cars normally come with around -0.5 degrees of camber from factory so the -1.2 you see on the Dinan specs is probably the result of the lowering of the car wich naturaly increases camber. The rear seems pretty normal. I'd like a total toe more around 0.35 degree the difference is negligable. I would be totally comfortable with these specs on a street car, should very easy to drive. If you want a more agressive behavior you could lower the toe up front to around 0.04-0.06inchs each wheels, turn in will be more direct. As for camber you cannot adjust it at the front and there are no camber plates available for now on our platform..
Cityofangeles32376.50 Chubbiejones890.00 |
09-21-2021, 11:37 PM | #5 | |
Rep 166
