10-27-2021, 01:17 PM | #1 |
Rep 3
19*9 ET 27, 255/35 R19 Will it fit?
Hi guys, I just ordered these new wheels they are 19*9 ET 27,
I am planning on put 255/35 R19 tires. Its a square setup. Will it fit my rwd 2020 M340i? Or do i need any spacers? Thank you! |
10-27-2021, 04:15 PM | #2 | |
Rep 2,964
19x9 square Et 25 255/35/19 With zero issues - you will only need spacers if you want your setup to be more "flush" While I'm running a 5mm on the front to push my wheels out a whee bit more (giving me ET 20 on the front) - I think most drivers would consider a 25/27 ET on a 9" wide wheel pretty darn flush Looking forward to your pics ps- you can reference my post here for comparison pics - your setup will be tucked in 2mm vs this (I did not have spacers installed for these pics) https://g20.bimmerpost.com/forums/sh....php?t=1751170 Last edited by chenry; 10-27-2021 at 05:03 PM.. |
10-27-2021, 07:49 PM | #3 | |
Rep 3
I saw your post earlier. Your fitment looks real nice! And I am thinking about getting the 5mm spacer as well. Did you get the spacer from DINAN as well? |
10-28-2021, 11:45 AM | #4 |
Rep 2,964
I went with Macht Schnell from ECS because they also sell +5mm bolts that are black. At the time I don't think they were offered from Dinan (could be wrong) - that said, while some will say you don't need to run an extended bolt with a 5mm spacer - given the option I don't see why you wouldn't
