11-17-2021, 03:55 PM | #23 |
Rep 1,682
11-17-2021, 04:18 PM | #24 |
msej449
514
Rep 717
Drives: M235i Convertible +LSD 2016
My UK Adaptive + High beam assist Xenons work as follows at night, when the ≡A switch is set and the ≡A button on the stalk is pressed.
After a short while with no other traffic ahead, the separate passenger and driver side full beam headlights engage. If you drive into a well-lit area they both disengage, and the standard beam flattens a bit to illuminate the driver side pavement, to better highlight pedestrians and cyclists. In the full dark and with both high beams engaged via ≡A: On a straight road, if an oncoming car approaches, it creates an unilluminated 'box' around the oncoming car by spreading the high beams to the left/right for as long as possible. Eventually, it drops the driver's side full beam but leaves the passenger side full beam fully operating. This is particularly useful driving cross-country, where the edge of the road may not be very clear. If a car appears ahead, it will create an unilluminated 'box' around the tail lights. This box will move up/down and left/right as the vehicle ahead moves vertically and horizontally. If you get nearer, it will eventually drop the high beams. On a curve, it will drop the passenger high beam if it detects oncoming vehicles in the line of sight, so as not to dazzle them. But it will still 'box' the oncoming car as above, until it has to drop the driver's side high beam. All of the above things happen concurrently. The Xenon HBA+Adaptive has different physical assemblies for left-hand drive and right-hand drive cars. So when I drive to the Alps, I can't use the ≡A button in France and Switzerland and just have to use manual standard or full (left+right) high beam. This Xenon assembly is different in a non-optioned car, so you can't just enable Adaptive with coding - the physical baffles and lenses just aren't there. My understanding is that in the USA, BMW either fits Adaptive assemblies but disables the control software, or doesn't fit the Adaptive assemblies at all. It isn't clear which applies to what models, and whether some models have a mix of the two approaches. That some people can retro-fit Adaptive simply by re-coding, while others are adamant they've been unsuccessful using the same coding implies the latter. The switch to LED also complicates the discussion, because in the UK certainly, some of the earlier LED headlights that were fitted definitively did not have an Adaptive capability although it seems that later versions do. So what it looks like US customers will be getting is the full repertoire of functionality: Beam spread when entering well-lit areas; separate left/right full beams; separate full beam illumination of the passenger side at the same time as standard beam only on the driver side; dynamic 'boxing' of oncoming vehicles; dynamic 'boxing' of vehicles in front of you; and directional illumination. There seems to be a separate landscape for directional lighting (on Xenons) i.e. where turning the wheel produces additional lighting in the direction of travel. Directional lighting seems to use foglamps and/or adaptive i.e. foglamps only where no adaptive is fitted, adaptive where there are no foglamps (as in the M-Lites), or both where both are fitted. However, I'm happy to be corrected on this and again, I've not got experience with LEDs, so they may implement this differently. I also have a theory that the original BMW design engineers never envisaged adaptive and HBA as a separate option. They thought that all headlights would have all the necessary mechanical components to support the functionality of HBA plus adaptive. And it was only later that the marketing geniuses thought of optioning these two things, to increase revenues. So as a result, the standard beam is by default set lower than you would otherwise like it because the assumption is that it's only used when you're close to a car ahead (otherwise, the HBA/Adaptive woud be doing its thing). In addition, it caused a lot of annoyance in the UK because dealers didn't always make it clear that you had to order both, separately - quite a few owners complained that they ordered HBA thinking it gave them all the functionality of Adaptive as well, then found the car was delivered without Adaptive (i.e. the left+right high beams would both drop when it saw tail ights or oncoming headlights, but that's it). And in the UK, it got even more confused when people with the early versions of LED would fully-spec all the options and then find that they'd lost the Adaptive capability they'd got used to on their previous Xenon-based BMWs. Finally, for those of you who haven't seen this technology - it works. I had HBA+Adaptive on my previous 3 Series as this made me choose it again for my current M235i. The 'boxing' tech really is impressive. But the HBA is not really any faster to respond than a human, which some owners find annoying and not up to expectations. Moreover, HBA can never match a driver who uses a cross-country road regularly and knows that, say, a twinkle along a hedge up ahead means a car will materialise 'round a corner suddenly, and would drop the high beam in anticipation. Notwithstanding such criticisms, I still think it's a great technology and I for one have never been flashed by oncoming cars while using it. One thing that you do need to get used to is that the headlighting can become sort of busy with all that boxing of oncoming and ahead vehicles on a busy road with a lot of curves. So I do still sometimes turn it off again on stretches where there's lots of traffic, I know the road well, the edges are very clear and all that high beam dropping/lifting and boxing gets distracting.
2016 M235i Convertible Estoril Blue & Oyster
2023 Peugeot e-208 GT (electric) Last edited by msej449; 11-17-2021 at 05:17 PM.. |
12
Limegrntaln13433.50 grumpyguy12.00 EXE462100.00 LivinLrge201.00 LogicalApex2025.50 QuarterMileJoe9.00 BMWGirlFL6274.50 amzbimmer299.50 CJ4211547.00 AndrewC198910931.00 rhyary1563.00 Kingpin4386.50 |
11-17-2021, 04:32 PM | #25 | |
Rep 6,949
Drives: 2022 DG/BLk xDrive M4C Wk 34
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou |
11-17-2021, 06:07 PM | #26 | |
Rep 4,551
Drives: 2015 328d xDrive
NYC Bimmer259.50 |
11-17-2021, 06:37 PM | #27 |
sportscars only
3244
Rep 3,195
Wow, so weird. Why was it disallowed for the longest time?
The richest one percent of this country owns half our country's wealth, five trillion dollars. One third of that comes from hard work, two thirds comes from inheritance, interest on interest accumulating to widows and idiot sons and what I do, stock and real estate speculation...It's bullsh*t. I create nothing. I own. We make the rules, pal...Now you're not naive enough to think we're living in a democracy, are you buddy?
11-17-2021, 06:57 PM | #28 |
Rep 3,216
Drives: 2018 BMW 440i GC
I am so confused. I am not even going to try to understand. I will wait until my next car to maybe have this option
11-17-2021, 07:23 PM | #29 | ||
Rep 1,247
Drives: 04 z4 3.0 Sport & 15 X5 35i XD
2015 X5 XDrive 35i - 2004 Z4 3.0 Sport
11-17-2021, 07:37 PM | #31 |
Rep 2,758
11-17-2021, 07:45 PM | #32 |
Rep 6,949
This is a good video showing what it does.
YT: G Dubyou |
LogicalApex2025.50 DanielHazelrigg146.00 |
11-17-2021, 07:50 PM | #33 |
sportscars only
3244
Rep 3,195
Guess I'm confused as presumably was a specific law to disallow this, otherwise hey should've been in use w/o prbs?
11-17-2021, 07:52 PM | #34 | |
Rep 2,758
"The reason is basic bureaucracy. In 1967, the U.S. Department of Transportation’s National Highway Traffic Safety developed a regulation (Federal Motor Vehicle Safety Standard No. 108), which specified that road-legal vehicles must have a dedicated high beam and a dedicated low beam. Because adaptive beams don’t have dedicated, separate high and low beams, they violate this regulation. Adaptive beams can adjust brightness and illumination area, but they do all of it using the same LED lights." |
tranquility3243.50 |
11-17-2021, 08:02 PM | #35 | |
sportscars only
3244
Rep 3,195
Anyway, such poor law interpretation, one would've though despite this law the lights in question would still be permissible.
11-17-2021, 08:13 PM | #36 | |
Rep 2,758
tranquility3243.50 EXE462100.00 |
11-17-2021, 09:35 PM | #37 |
Rep 165
Seems like those of us with newer models where anti-dazzle was decoded could maybe code it back to active via BimmerCode?
Wonder how it would work on a pre-LCI G01 with the adaptive lights. |
Limegrntaln13433.50 |
11-17-2021, 09:44 PM | #38 |
Rep 255
Drives: 2021 M-B GLS 580
My Benz has it already somehow they got around it. It is amazing to watch in good ole USA countryside. Leave in auto and it's amazing. No one ever flashes me for brights…ever. Car is smart.
2020 X5 M50i
2017 X5 50i M-Sport (Retired) 2013 X5 50i M-Sport (Retired) |
11-17-2021, 10:01 PM | #39 |
Rep 6,949
Many people have recoded it, already. Check my post above. But also, sometimes when the car does an over the air update, the anti dazzle is again reverted to OEM spec.
YT: G Dubyou |
11-18-2021, 06:40 AM | #41 | |
Rep 165
11-18-2021, 06:55 AM | #42 |
Rep 220
Does this differ from the adaptive headlights I have in my 330i?
| 2018 BMW 330i | 30k Miles | M-Sport Package | Driving Assistance Plus | Premium Package | Executive Package | Harmon Kardon | Active Blind Spot Detection | PDC | Mineral Grey Metallic/Coral Red Dakota Leather |
| 2022 Toyota Highlander Platinum AWD | |
11-18-2021, 07:24 AM | #43 | |
Rep 2,161
I spent a ton last year upgrading my car with these and I'm glad others will get to option it now without the hassle. |
firedown31913.00 |
11-18-2021, 07:44 AM | #44 | |
Rep 349
