11-26-2021, 01:55 AM | #1 |
Rep 73
Drives: BMW G20 320i M Performance
(G20 DIY 4) Automatic Trunk (VO 316)
My G20 was not Automatic Trunk. (Now Automatic Trunk)
Can Change Manunal Trunk to Automatic Trunk. But Need Many Parts. (with Esys Coding) -Parts Number- Trunk Lid Main Parts 51247430644 - Spindle Drive Tailgate 41007458666 - Ball Pin 51627482572 - Trunk Buzzer 61132360043 - Socket Housing 2P Set (with Pin) Trunk Lid Lock 51247441014 - Trunk Lid Lock 51247430626 - Automatic Soft Close 61132359992 - Socket Housing 6P Set (with Pin) x2 61136909058 - Socket Housing 6P 63217216997 - Snap Lock Coupling x3 34521164653 - Lind Holder x2 *If You Buy Automatic Soft Close with Cable Parts. Need Socket Housing 6P only. Trunk HKFM Module 61359852925 - HKFM Module 61139329883 - HKFM Module Connector Cap 61130056962 - MQS 0.2-0.35mm (with Cable) x6 or 61131383776 - MQS 0.2-0.35mm 61130056960 - MQS 0.5-0.75mm (with Cable) or 61131393724 - MQS 0.5-0.75mm 61139232683 - MCP 6.3x0.8 2.5-4.0mm (with Cable) x2 or DJ6218C-E6.3B - MCP 6.3x0.8 2.5-4.0mm (AliExpress Parts) *I Can't Find HKFM Module Connector Parts Number. You Make 12pin + 6.3 Terminal 2p with Module Connector Cap. or You Buy HKFM Module with Connector and Cable. Trunk Lid Switch 61319275121 - Trunk Lid Switch 61319162645 - Trunk Lid Switch (Old Parts) 61132359994 - Socket Housing 4P Set (with Pin) or 61138380696 - Socket Housing 4P Driver's Door Trim https://g20.bimmerpost.com/forums/sh....php?t=1867288 BDC, KCAN Pin 61131383776 - MQS 0.2-0.35mm 61131393724 - MQS 0.5-0.75mm Fuse Box Connector *61130007437 - Double Spring 1.0mm2 (with Cable) ㄴnot perfect parts but match fuse leg. 61139232683 - MCP 6.3x0.8 2.5-4.0mm (with Cable) x2 DJ6218C-E6.3B - MCP 6.3x0.8 2.5-4.0mm (AliExpress Parts) -Cable AWG- A218*1B (HKFM) to R2*1B, H6*1B = 0.35mm2 x4 to A258*3B = 0.5mm2 x1 to Z2*1B, Z10*12B = 2.5mm2 x2 S30*1B (Soft Lock) to A258*4B = 0.35mm2 x1 to Z2*5B = 0.75mm2 x1 S21*1B (Trunk Lid Switch) to A258*4B = 0.35mm2 x1 to E34*1B = 0.35mm2 x2 to S29*1B = 0.35mm2 x1 -Need Tools- Trim Remover IWISS Press Tool Hexagon Socket 13mm Star Wrench T40 *Torque Tools (preferbly to have) -Main DIY- 1. Removal 2. Make Wire 3. Make Hole 4. Right Trunk Spring to Gas Lift 5. VO Coding -Wiring- Check Image Go DIY (watch my video or repair guide) (I'm so sorry... video is not Eng sub. only Korean) Check PDF File or Video 1. Remove Trunk Trim 2. Make Hole at Trunk Lid Trim 3. Make Wire 4. Change Spring to Gas Lift 5. Change Trunk Lid Lock to Soft Close Parts 6. Assemble 7. HKFM Detect CAFD 8. Add VO 316 9. BDC, MGU, HKFM Code or Flashing
Freelancer without work
