11-26-2021, 07:09 PM | #1 |
Rep 524
20” Vossen HF-5 Gloss Black
Vossen HF-5 in Gloss Black and wrapped in Conti ECS
-20X9 f (235/35/20) -20X10.5 r (275/30/20) Car is also dropped on Dinan Springs. Love the wheels - its like falling in love all over again with your car. |
11-28-2021, 08:16 PM | #2 |
Rep 410
Looks awesome, excellent wheel choice!
12-01-2021, 08:19 AM | #4 |
Rep 978
Wheels
Combat and race look is always a good thing.
2021 M340i
2020 X3 M40i - her car 2019 M5, AW, DP's, MSR CAI, BM3, SOLD 2020 Chev. ZR2 Bison truck, Daily Driver |
12-03-2021, 10:21 AM | #5 |
Rep 28
Do you rub when driving? How is it with street bumps and is there a difference from oem springs?
12-06-2021, 07:45 AM | #6 | |
Rep 524
It’s actually not bad at all, I have my tire pressure set at 40psi; with the 20’s its obviously going to be a bit stiffer when compared to the stock 19’s, but I would not say its a big difference. Overall I’m quite happy - the pros in this case far outweigh the cons. No rubbing with my setup at all. Though I did attempt to install the rears without the 7mm spacer and it rubbed. That being said, even if the rear didn’t rub without the spacers, I would’ve thrown them on as there is a very slight poke with them on, which looks fantastic. Last edited by GD1981; 12-06-2021 at 07:51 AM.. |
12-20-2021, 06:03 PM | #7 |
Rep 1,521
Hey brother, you by chance have any additional side profile shots of your car in daylight hours? I am contemplating a very similar set up; what spacers do you have installed (Dinan)?
12-21-2021, 07:52 AM | #8 | |
Rep 524
Future classic 12mm spacer for the front Dinan 7mm spacer for the rear |
12-21-2021, 04:20 PM | #9 |
Rep 1,521
Appreciate the pictures and the information brother! Couple of additional questions:
1) What is the reason you installed a set of Future Classic spacers in the front vs installing Dinan on all four corners? 2. Can you provide the details on the CF front lip and rear spoiler. Thank you again for your time! |
12-24-2021, 11:30 AM | #11 | |
Rep 1,521
https://g20.bimmerpost.com/forums/sh...686702&page=12 -20X9 ET32 (Front) (Tire Size - 235/35/20) -20X10.5 ET45 (Rear) (Tire Size - 275/30/20) |
Transfer5251.00 |
12-28-2021, 09:45 AM | #13 | |
BMW Enthusiast
170
Rep 221
As an example I went with the same wheel on mine but a little different tire size with the PS4S.... Vossen HF-5 Matte Gunmetal Front 9x20 Rear 10.5x20 Pilot Sport 4S Front 245/35/20 Rear 285/30/20 I wrote to Michelin and asked them what psi I should run the new tires at. Here was their response... We show based on the OE tire size of 225/40ZR19Rf and OE pressures of 39 psi front and 42 rear, the new pressures for the front tires will carry a similar load at 35 psi front and 26 psi rear! However, we are only allowed to recommend the OE pressures, even though, you replaced your tires with a staggered fitment. Using the lower pressures could cause the TPMS light to come on and you may need to have it re-calibrated! Sincerely, Executive Response Team |
12-28-2021, 09:59 PM | #14 |
Rep 524
Sorry for the late response.
In regards to the wheel offsets, I’m running the following: et 32 in the front with a 12mm FC spacer (effective +20) flush et 45 in the rear with a 7mm Dinan spacer (effective +38) ~5mm poke Future Classic doesn’t have a 7mm spacer is the reasoning why I went with Dinan for the rear. IMO Future Classic makes the best spacers - and I’ve tried a handful over the years, though they are on the pricey side. In regards to the tire pressure, I’m running 38 psi all around - I did recalibrate the system, so there is no light on the dash. From all the research I have done regarding this, I’ve seen mixed opinions. As it is now, I like how the car runs. What psi are you running?? Last edited by GD1981; 12-28-2021 at 10:10 PM.. |
Chubbiejones891.00 |
12-29-2021, 06:07 AM | #15 | |
BMW Enthusiast
170
Rep 221
30 rear |
01-01-2022, 10:55 AM | #16 |
Joint Chiefs of Staff
24171
Rep 190,750
Looks great
01-06-2022, 09:19 AM | #18 |
BMW Enthusiast
170
Rep 221
01-10-2022, 10:41 AM | #19 |
Rep 524
01-10-2022, 11:19 AM | #20 |
BMW Enthusiast
170
Rep 221
