11-08-2021, 11:08 PM | #926 |
General
10523
Rep 41,123
Drives: 2018 Alpina B6 650ix GC
Your Receive PM function is disabled. PM me when working.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
11-08-2021, 11:17 PM | #928 |
General
10523
Rep 41,123
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 11-09-2021 at 10:33 AM.. |
domi12346.00 |
11-09-2021, 04:12 PM | #930 |
General
10523
Rep 41,123
I replied to your same PM.
11-10-2021, 07:01 AM | #932 |
General
10523
Rep 41,123
PM sent.
11-10-2021, 10:12 PM | #933 |
Rep 44
hello
i hawe the stalk buton for 5ac high beam assistant, when you click it you can purchase at conected drive store? whenn i add 5ac to salapa and code it to car, could than work? hawe anybody tri with this method, because i found nowhere in web that somone code high beam assist?? |
11-11-2021, 10:53 AM | #934 | |
Rep 1,805
domi12346.00 |
11-11-2021, 08:14 PM | #936 |
General
10523
Rep 41,123
PM sent.
11-13-2021, 06:42 PM | #937 | |
Rep 452
Drives: 2017 X5 & 2020 X5
Also looking for a solution to my outdated E Sys Launcher setup. Tried to pm dayvg and reply to him on a discussion on the bimmerfest forum but it had been closed Any help would be greatly appreciated Thanks
Current: MY 21 X5 3.0d xDrive MSport
MY 20 X5 2.5d xDrive MSport MY 17 X5 2.5d sDrive |
11-13-2021, 07:44 PM | #938 |
General
10523
Rep 41,123
PM sent.
11-15-2021, 04:24 AM | #939 |
Rep 16
Hi everyone.
I have a G20 with i-STEP07/2021.50. I will have to LauncherPro3.7+E-sys but coudn't connect in my car. I used LauncherPro3.7+E-sys when I befor up date i-STEP07/2021.05. I don't know What probrem is this. Would everyone adviced for me Please. Thanks. |
11-15-2021, 11:40 AM | #940 | |
General
10523
Rep 41,123
1) The Target Connection Window should not be blank (It should show multiple target connections for different chassis') 2) ENET Cable must be good and making good contact in OBDII Port 3) Car must have proper voltage (Make sure motor is running if car is not on a Charger). 4) Laptop must not have Firewall or any Antivirus software running. 5) PC Lan Adapter should get a fallback IP address of 169.254.xxx.xxx (Make sure it is using DHCP and does not have a Static IP address assigned to it)
11-15-2021, 09:43 PM | #942 |
General
10523
Rep 41,123
PM sent.
11-21-2021, 03:06 PM | #944 |
Rep 51
Hi Shawn,
Hope you’re keeping well. I know I had this discussion with you awhile back, but can’t find that conversation and now have a new computer and am confused. So I need to use esysx which I have purchased Can you send me what I need to use in conjunction with esysx please. I remember you said I need both versions of esys installed but which is the one to use with esysx plus and that I need full data Thanks for your time |
11-21-2021, 03:26 PM | #945 | |
General
10523
Rep 41,123
11-26-2021, 02:37 AM | #946 |
Rep 452
Launcher Pro 3.7.0.315 Bootup
Good day all those software gurus
I have the above software and every thing was working as normal until a few days ago I had a Windows 10 update on my PC and since then every time i start the program the PC clock reverts back to a certain date & time. The software appears to run ok but as soon as i change the date/time to the current time the program freezes and is unable to load files etc I then have to use Task Manager to close it. I think it may have something to do do with the Java software as it appears there is a new version that was installed with the windows update I have tried contacting the Vendor on eBay without much luck and uninstalling the program and the base E-Sys program and then reinstalling it but to no avail. Any assistance would be much appreciated Thanks
MY 20 X5 2.5d xDrive MSport MY 17 X5 2.5d sDrive Last edited by Bambazonke; 11-26-2021 at 02:49 AM.. |
