2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions What are the operating parameters for the remote start function?
      09-11-2019, 12:18 PM   #1
Sandpiper
Drives: 2023 M340i xDrive
I want to get remote start, but first want to understand how it works. For example our Honda has remote start. On the remote you press the lock button twice and then hold the start button. This starts the car, and it runs for 10 mins. It runs the AC/heat to bring it to 72F. So how does the BMW Remote Start work? Do you need a monthly subscription and have to use the BMW app on the smartphone? Is the temperate setting changable? Does it automatically shut off after X minutes? Any other details you can provide would be good.
      09-11-2019, 01:00 PM   #2
gofast182
Drives: 2020 M340i xDrive
I can speak for our new G05 (X5). You can start it by rapidly pressing the lock button 3x. It will run for 15 minutes before shutting off. You can also start it from the app. where it will also run for 15 minutes before shutting off. There is no monthly subscription for the app.
      09-11-2019, 01:17 PM   #3
premier3is
premier3is's Avatar
1632
Drives: 2019 BMW 330i M-Sport
Press the lock button 3 times, it'll start the car. Press it 3x again, it'll turn it off. You can set the climate control rules for remote start as well from your settings in the vehicle to get it to a desired temperature when you remote start the car.
Also available is the app (no subscription). You can remote start from there as well, lock, unlock, turn lights on and locate vehicle.
      09-11-2019, 02:25 PM   #4
Sandpiper
Wow, that's sound pretty neat! Thanks for the info gofast182 & premier3is
      09-12-2019, 03:11 PM   #5
azwillnj
Where are the climate rules for remote start?
Current: 2023 G20 LCI M340i xDrive
History: 2005 E90 325i > 2008 E90 328xi > 2011 E90 LCI 335i xDrive > 2013 F30 328i xDrive > 2016 F30 LCI 340i xDrive > 2020 G20 M340i xDrive
WE ARE!
      09-12-2019, 09:19 PM   #6
premier3is
premier3is's Avatar
1632
Settings > climate control. I believe you can set it under preconditioning. Also under the Installed Apps > climate control rules (settings for your seats I think). Not near my car so you can go there and check for yourself.
      09-13-2019, 10:56 AM   #7
shawntech
The Wolf
shawntech's Avatar
Drives: stuff
  [0.00]
2019 BMW M850i conv ...  [0.00]
I had to enable it in climate control settings in the car, now pressing lock 3x quickly and it starts... range is quite good too, also can schedule from idrive or connected drive app
