06-03-2021, 01:14 AM | #1 |
Rep 263
Drives: BMW G20 330e MSport Xdrive
Drivers window wont go up?
Anyone experienced this? Warm day window down, got home went to put window up and nothing
Luckily ive a garage so left over night, tried this morning and still wont go up, tried all other windows and they wont go down?
JohnBoySAFC
BMW Msport 330e xdrive 2020 |
06-03-2021, 01:20 AM | #2 |
Rep 8,081
Does the window go up with comfort close? (Hold the lock button down on the key).
You can try to Turn it off and on again, i.e. disconnect battery for a minute. |
06-03-2021, 04:28 AM | #3 |
Rep 263
Ive managed to get it up now, but its just odd? Ill see if it sorts itself out if not ill do that disconnect battery if no better ill ring dealer, thanks
JohnBoySAFC
06-03-2021, 04:40 AM | #4 |
Rep 1,215
Viagra?
wolvesatthedoor71.00 |
06-03-2021, 06:13 AM | #5 | |
Rep 1,030
previous F30. This worked in resetting the windows. Hold down both left and right front window buttons in driver's door for 30 seconds. Then use button to raise windows. |
06-03-2021, 10:16 AM | #6 |
Rep 156
Did the mirrors fold? Sounds like when the mirror motors die and cause the entire window/mirror panel inside the car to stop working. You'll notice it's not illuminated like other buttons.
06-03-2021, 10:40 AM | #7 | |
Rep 1,030
It was intermittent. New control module fitted for this. |
06-04-2021, 09:11 AM | #8 | ||
Rep 263
Ill try the two buttons together see if that does it
JohnBoySAFC
06-07-2021, 02:13 PM | #9 |
Rep 177
This is the most likely cause. Faulty electronic module in one of the mirrors can cause such issues. It will behave erratic at first and finally will give up completely.
06-08-2021, 02:15 AM | #10 | |
Rep 263
About 6 weeks ago the drivers side mirror didnt fold out Just put it done to sticking so oiled it and it worked from then on When the window didn't go up i noticed the wing mirror hadnt folded out either Everything is working normally now
JohnBoySAFC
06-08-2021, 03:01 AM | #12 | |
Rep 263
Just didnt use til yesterday after id got window up
JohnBoySAFC
06-21-2021, 02:30 AM | #13 | |
Rep 263
Wing mirrors folding in and out fine, but drivers window not responding at all to door buttons The windows do drop using the key fob and the app. So I'm guessing not a motor issue, but software?
JohnBoySAFC
07-01-2021, 11:15 PM | #14 | |
Rep 263
Was there for 08:30 for "an hour, hour and a half max" job Been there all day and still not fixed, haven't had a full story back other than the obvious didnt work and now they are trying to find the root cause? See what today brings
JohnBoySAFC
07-02-2021, 09:22 AM | #15 | ||
Rep 263
Not the fix they thought, its now getting a new wiring loom fitted, but wont get done today They dont know if this is the cause, they are now changing things until they find it
JohnBoySAFC
07-02-2021, 11:17 AM | #17 | |
Rep 263
Im ok that way, but a diesel passat estate is a big step down lol
JohnBoySAFC
07-05-2021, 09:04 AM | #18 |
Rep 263
Its back
3 days, for an hours job. But at least its fixed and i have it back Electronic module and new wiring loom required
JohnBoySAFC
07-05-2021, 09:27 AM | #20 |
Rep 263
Yeah indeed
Its sad but was a little lost without it
JohnBoySAFC
07-05-2021, 01:41 PM | #21 |
Rep 49
Finally is back..well done and thanks for the update.
johnboysafc99.00 |
