08-07-2020, 03:05 PM | #23 |
Rep 18
Got my 330e in December (just before Christmas) now done 28,000 miles and had first service (delayed service due to coronavirus and dealers not calling me back) my rears are still good with a few more 1000 miles left in them.
Pressures checked on the idrive all ok. I drive a mixture of light and hard dependent on mood. Mostly motorway She should be due for some rears soon. But gotta wait till it reaches the lease companies minimum. |
08-08-2020, 07:20 AM | #24 |
Rep 146
Mines even more strange as only one of mine wore down in the middle.
I had it checked by the garage in relation to tyre pressure (2.6b) and all were at the same recommended pressure. Now the other one is getting a little low. Had the car since Oct and done 13000 miles. I had a Lexus IS300h F Sport before the BMW and in the 3 years of having it (70,000 miles) only ever had to change the tyres due to punctures. Last edited by Burnzie’s BM; 08-08-2020 at 07:26 AM.. |
08-08-2020, 09:22 AM | #25 | |
Rep 1,041
01-12-2021, 10:33 AM | #26 |
Rep 3
Hi
I've got the 330i with the 255 Bridgestone turanza's also got terrible mileage and the only wore out in the middle. I played around a lot with preassure the first and second set of tyres and nothing helped. As a matter of interest, it wore out faster when a ran lower preassure. After a lot of research the general consensus is that this specific tyre suffers from centrifugal growth. So like a dragster tyre middle of the tyre gets taller as speed hence the middle wearing out quickly. I'd suggest changing brands. |
verysideways958.50 Andy75012.00 |
01-12-2021, 12:20 PM | #27 | |
Rep 86
01-12-2021, 01:19 PM | #28 | ||
Rep 1,159
01-13-2021, 02:46 AM | #30 |
Rep 1,159
You shouldn't get any warning - just inflate to 2.3Bar and then perform a TPMS reset, which will recalibrate the system to your chosen pressure
01-13-2021, 03:36 AM | #31 |
Rep 15,858
Just a little reminder in these pressure discussions, are we all on the same page?
Door plate recommendation, or TPMS 'real time' pressure and recommendations? |
01-13-2021, 03:38 AM | #32 |
Rep 1,159
I got off the door plate generally, with a view that adjustment may be needed based on external temperature, and use the monitoring system as a guide. Will always check properly with a pressure gauge though.
01-13-2021, 03:45 AM | #33 |
Rep 1,234
I once read that you can run into insurance issues if you don't use the manufacturer recommended (i.e. door plate) pressures. Don't know how much truth there is in that, but knowing the insurance industry I wouldn't be surprised.
01-13-2021, 03:58 AM | #34 |
Rep 320
I imagine if you had no air in the tyres at all and wrote your car off then the insurance examiner may have something to say.
Arrived: '20 330e M Sport in Mineral Grey
'03 MY 996 Turbo in Arctic Silver Gone: '18 Golf GTI Performance DSG in Tungsten |
01-13-2021, 04:01 AM | #35 |
Rep 619
I know it's not Apple with Apples, however on my G30 (i'm soon to get a 330e)... I have following:-
Front: 245s (2.2 iDrive and Door) Rear: 275s (2.2 iDrive and Door) Reason I mention that is rears on 330es are 255s and so 2.6/2.8 just seems very wrong, even with Extra weight of batteies, G30 must be as heavy over rear axle... I found the Pirelli's were rubbish and wore out quickly, I've had Goodyear F1's for nearly 2 years now and they are as good as new still - 13,000M Cheers
Sunset Orange G20 330e xDrive M Sport Pro - Tech/Pro Pack, Park Assist Plus
Bluestone G30 M Sport - Gone to Stud Alpine White F10 M Sport - Gone to Stud |
01-13-2021, 05:04 AM | #36 |
Rep 257
Always set to the door plate setting, and measure the pressure with a pressure gauge. The main purpose of the TPMS is to detect a significant drop in pressure, the absolute readings are not all that accurate.
01-24-2021, 03:11 PM | #37 | |
Rep 285
It's a company Lex Autolease vehicle so no worries about when and how much, but even so, that's a shocking amount of wear. |
01-25-2021, 05:56 AM | #38 |
Rep 242
Drives: X3 xDrive30e M Sport 2020
4.8 after nearly 2000 miles
First time with run flats so checked mine today after reading this. 7mm all round after 3300 miles. Pirelli P Zero 19" runflats. Plate on door for light load 39psi/2.7bar. My screen shows 38psi. |
02-02-2021, 09:53 AM | #40 | |
Rep 243
And back to topic, it seems like the Bridgestone T005s are no good on the rear so what's the recommended alternative without decreasing performance much? If we keep to pairs on each axle can we mix front to rear. The T005s seems fine on the front. |
02-02-2021, 10:07 AM | #41 | |
Rep 320
Blackers62.00 |
02-03-2021, 05:20 PM | #42 |
Rep 243
02-04-2021, 01:22 AM | #43 | |
Rep 57
My company now insists that new lease cars have a spare. As the 330e I have ordered doesn’t have that option, it got upgraded to 19” wheels and run flats. |
02-04-2021, 02:06 AM | #44 |
Rep 8,110
I've had no issue with the gel cannister and compressor (only needed it once though).
Ian
