04-11-2020, 12:44 AM | #1 | |
Rep 3,535
Drives: 328d Wagon, M2 Comp, i4 eD35
G20/G2x Springs and Shocks Installation DIY Guide
So I had a new G20 330i for a bit the other day and decided to make a DIY guide on how to change the springs/shocks on this latest generation platform (including all torque specs as I always do). In general, the suspension layout and process are VERY similar to the F2x/F3x generation, and the methods I used are the same as I do for F2x/F3x xDrive cars. Hope this helps!
If you're a quickjack user, pay close attention to the raising the car section at 2:26. I'm pretty disappointed BMW chose to make their jack points so far apart! F2x/F3x springs look like they fit the mounts of G2x, but it also looks like G2x uses longer springs in general, so I'd hold off on trying to use F2x/F3x springs to lower the car for now, plus we don't know the G20 spring rates. As usual, damper travel before bump stop engagement is important to understand before lowering your car. For this base suspension car, the front doesn't have much travel at all, but the rear has a good amount. I was actually quite surprised and impressed with the base suspension on this G20. I liked it better than the M340i's adaptive suspension in sport mode at the UDE autocross. BMW did a good job of firming up damping without making things harsh IMO.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
04-11-2020, 10:57 AM | #2 |
1942
Rep 3,521
Somewhere in the beginning you say it’s an easy job (or something very similar) If that is easy for you, I wonder what easy to me is like for you!!! My “expertise” is limited to removing the plastic cover under the hood and that’s it.
Very impressive!
04-11-2020, 12:44 PM | #3 | ||
Rep 3,535
Believe it or not, but before I got my F31, I hadn't so much as changed my own oil. kpgray on the F30 forums suggested and kindly made a "checklist" for those more detail oriented for this job. His list is below: Quote:
04-13-2020, 04:06 PM | #4 |
Rep 140
Thanks for the video and writeup! This will really help me a lot when I change my G20s suspension to BC Coils.
Few questions though: 1. Do you think lowering the front shocks without removing top hat work for G20? Didn't have to remove the top hat of my F30 when i replaced my springs. I just supported the brake disc with a jack, removed the strut nut from the engine bay and slowly lower the entire assembly down, then pulled the springs out. This method works for my M2 also. 2. I tried to find all the torque specs for the bolts and nuts but newtis.info still doesn't have most of the torque specs listed on the website, I initially decided to use the torque specs of the F30 for the G20. If you don't mind sharing where you found the torque for all the bolts and nuts? or are you also using the F30's? 3. Do you have any experience with BC coils? Planning to get this for the G20 as daily driver. Thanks! |
04-13-2020, 05:03 PM | #5 | |
Rep 3,535
2) NewTIS is still missing a lot. For the items NewTIS didn't cover I looked at the bolt diameters and thread pitches for G20 and compared it to F2x/F3x, and while the PNs were different (due to minor differences in the bolts, like the length) the thread pitches and the nuts were the same, so the same torque spec could be used. 3) I don't have any first hand experience with BC, but everything I've seen suggests they're a lower quality part. Good for making things "feel stiff" but not the best for longevity or creating a smooth, coherent, and controlled ride. Also, the spring rates they usually suggest don't have flat ride frequencies, which the OE suspension does, and helps the car settle faster to create a smoother ride.
oln0881.50 |
04-13-2020, 05:54 PM | #6 | ||
Rep 140
I may just go ahead and try my luck with BC. I really dont want to use springs anymore to lower my car, been doing it since my JDM days. Although eibach springs isnt too bad with F30, still have it till now for about 5 years already. I just dont like the occasional bounce at high speed. The G20 is a daily, so hopefully I will find the right rebound with BC's 30 click adjustable. This car needs to be lowered so bad but cant justify buying more expensive coilover. |
08-21-2022, 08:10 PM | #7 |
Rep 471
Drives: G20 330i xDrive M-Sport
Anyone have advice for disengaging the bottom of the strut from the knuckle? I removed the knuckle bolt and opened the knuckle using a spreader and was able to slide the knuckle about 3in down the strut body but couldn't get get it far enough down to angle the strut and free it from the knuckle.
08-22-2022, 05:29 AM | #8 | |
Rep 1,519
pdxdbo331.00 |
08-22-2022, 10:49 AM | #9 | ||
Rep 471
Chubbiejones890.00 |
08-22-2022, 11:53 AM | #10 | |||
Rep 1,519
pdxdbo331.00 Rural Enthusiast73.50 |
08-29-2022, 12:38 PM | #11 | ||||
Rep 24
08-29-2022, 01:27 PM | #12 | |||||
Rep 1,519
Ohlins R/T Coilovers with Swift Springs - Installation & Review https://g20.bimmerpost.com/forums/sh....php?t=1936802 |
08-29-2022, 05:16 PM | #13 |
Rep 58
Drives: 2019 330i RWD SportLine
For some reason, both of my front struts are stuck to the knuckle. We tried using pb blaster, air hammer, hammer, and body weight. The strut didn't move a bit at all. We followed this and kies video. I guess no lowering springs for my g20.
08-29-2022, 06:10 PM | #14 |
Rep 1,519
Had the same issue on the drivers side of my car. You will have to remove the entire assembly from the vehicle in order to have enough room and force to separate the strut from the hub assembly.
08-30-2022, 12:36 PM | #15 |
Rep 24
Thanks for your reply. I do not see the "below thread". I am using a Firefox for my browser. Thanks again!
08-30-2022, 12:38 PM | #16 | |
Rep 1,519
08-30-2022, 12:40 PM | #17 |
Rep 24
Thank you!
08-30-2022, 06:57 PM | #18 |
Rep 1,519
09-21-2022, 03:42 PM | #19 | |
Rep 129
FaRKle!4006.50 |
