10-27-2023, 03:24 AM | #68 |
Rep 533
I'm beginning to wonder if there was a problem with the 2023-4 version and that's why it appears to have been withdrawn.
Where would that leave those who did manage to install 2023-4? |
10-27-2023, 03:25 AM | #69 |
Rep 8,083
I'm on 2023-4 and it seems to work OK.
Ian
10-27-2023, 03:38 AM | #70 |
Rep 1,241
Same here.
That being said I might try to reinstall when it comes back on stream just to be sure.
10-27-2023, 03:48 AM | #71 |
Rep 533
10-27-2023, 04:15 AM | #73 |
Rep 533
10-27-2023, 06:32 AM | #74 | |
Rep 2,176
No doubt some 'genius' at Connected Drive won't have a bloody clue either! |
10-27-2023, 06:40 AM | #76 | |
Rep 1,060
G15, 840i M Sport
bmnut813.50 |
10-27-2023, 06:42 AM | #77 |
Rep 2,176
That would be excellent and really helpful. If it works then there may be others on here will give that a try, I may well be one of them!
10-27-2023, 07:54 AM | #78 | |
Rep 1,060
USB device does not contain a more recent version of the navigation data. Start update anyway? Update Now Cancel Obviously didn't want to go any further as I'm running 2023-4 with no problems to note, hope this helps regarding installing previous versions.
G15, 840i M Sport
bmnut813.50 |
10-27-2023, 08:30 AM | #79 | |
Rep 2,176
Keeps fingers crossed! |
11-01-2023, 11:08 AM | #80 |
Rep 2,244
Just an FYI here:
2023-4 LIVE is out(for idrive 7). 2023-4 JOY is NOT out (for idrive 8). These are the full Europe updates. The UK IE part is available for JOY as on OTA update. Joy 2023-4 should be out in the next 3 weeks Each Head unit revision has a different kind of maps (the 8.5 systems get "JOY EVO") |
11-01-2023, 11:43 AM | #81 | |
Rep 533
I managed to get 2023-4 when it first appeared fleatingly, and was intending to re-install 2023-4 when it became available again, just in case there was something wrong with the first release. Having said that, if there was a problem, I would expect BMW to release the fix as a new version number to save confusion. |
11-01-2023, 01:15 PM | #83 |
Rep 1,241
Do you know if the 2023-4 that went up briefly is OK or does it have errors?
11-01-2023, 01:17 PM | #84 |
Rep 2,244
Rhino at Work713.50 |
11-01-2023, 04:30 PM | #85 |
Rep 2,176
Fortunately haven’t encountered any issues yet, but hoping I haven’t spoke too soon!
If you’ve already loaded the pre QA map as I have done then if you download the future officially released map will the idrive let you replace the already installed map? |
11-02-2023, 01:53 AM | #86 |
Rep 2,244
So long as the build number is higher yes. The same build might make it past QA and be released
11-02-2023, 03:52 AM | #87 |
Rep 2,176
11-02-2023, 03:56 AM | #88 |
Rep 1,241
2023-4 is back on the download manager today. I'll see what happens when I try and overwrite the 2023-4 I previously installed and report back.
