03-17-2024, 02:17 PM | #1 |
Rep 22
Easy Upgrade - Air Conditioned Seats…sort of
For the cost of free as I already had a 6” piece of 1.5” aluminum angle I’ve really improved my ventilated drivers seat. It”s now semi air conditioned instead of being merely ventilated.
The aluminum angle goes on the floor in the back below the drivers seat and gets wedged under the plastic rear seat feet vents and redirects the cold air up into the 4 seat fans. I used 3m double sided tape to insure it stays put. This was initially going to be a rough test but after discovering there are 4 fans and lots of stuff in the way of running flexible hose (to what I thought was going to be a single fan) I’m leaving it as is. Works well and nobody can see it anyway. You can set the rear air to full feet or a mix. Either way there’s lots of air coming out of he floor feet vents. So go get some metal angle and cool your butts off! |
9
forcefed2562.50 John4C864.00 CCM11285372.50 Needsdecaf6599.00 MT6722.00 Dnshift156.50 Pool Shark488.00 Vectors2final1356.50 BEAR-AvHistory-2277.00 |
03-17-2024, 05:11 PM | #3 |
Rep 851
Maybe 3D print something that sticks on the vent kinda like the different vacuum attachments do so it’s a cleaner solution.
03-17-2024, 05:41 PM | #4 |
Rep 1,366
Drives: 2020 X3MC
I like the idea, but the seat fans pull not push so this will have zero effect.
03-17-2024, 06:00 PM | #5 | |
Rep 22
It’s hard to tell using a hand but I put a small piece of wax paper on the seat. It floats from the front (higher) part of the seat down to the back (lower) with the fans on and it stops and remains in place with the fans off. Just like the ol’ air hockey tables. |
Vectors2final1356.50 |
03-17-2024, 06:05 PM | #6 | |
Rep 3,403
I agree with OP- the more air I can get underneath the seat, the cooler the ventilation is. It’s unfortunate BMW didn’t opt for A/C on the seats like Audi used to or may still do on the SQ7. Those seats get frigid. |
03-17-2024, 06:06 PM | #7 | |
Rep 1,366
Drives: 2020 X3MC
03-17-2024, 06:07 PM | #8 |
Rep 1,366
Drives: 2020 X3MC
Fan direction. Pull vs push. Pull the seats pull air into the seat. Push the seats push air out of the seat.
03-17-2024, 06:08 PM | #9 | |
Rep 3,403
Disagree with you, but got it. https://www.bmwoffremont.com/researc...ated-seats.htm |
03-17-2024, 06:14 PM | #10 | |
Rep 1,366
Drives: 2020 X3MC
03-17-2024, 06:17 PM | #11 | |
Rep 3,403
Yeah, OP, this solution should work. I wonder if Audi has better angling of the car’s A/C because I don’t know if those are actually cooled seats in the SQ7 but they get very cold. The BMW’s seats are helpful but subpar to say the least. |
03-17-2024, 06:18 PM | #12 |
Rep 2,614
Drives: 2024 M4 Convertible
I was under the impression they pulled air away for the following reasons:
1) They're not cooled, so it would be more beneficial to pull hot air away than it would be to blow room temp air at you 2) I could never feel any air coming out of the seat perforations which to me would imply air being pulled away from your hand and not blown at it. I imagine if there were air being blown at you, you could at least feel it somewhere, but some older threads I found seemed to imply the point is to cool the seat and not the person, which makes some sense, but then doesn't really explain why the seat needs perforations in the first place. |
03-17-2024, 06:25 PM | #13 | |
Rep 3,403
But the problem is they don’t work well. And it’s not just a BMW issue. If it’s a cold day outside, try rolling the windows down in the back and see how much that helps cool the seats down because it’s sucking in the air from under the seat. This is how the aftermarket seat pads work too. I don’t see how pulling air away from the seat would help that much. |
03-17-2024, 06:38 PM | #14 |
Rep 22
I think the main reason there’s confusion as to which way the fans are moving air is because as mentioned above, the system isn’t great. There’s not a lot of
air flow even on the highest speed and therefore difficult to even hold your hand near the seat to confirm. I rented a Ford something or another once and the airflow from the seats was double that of ours. Loved it but at the same time, it’s probably a tougher design than we think. For one thing, how do you maintain a decent amount of cushion while still having holes for airflow. Seems like dirt and debris would start clogging the holes over time as well. |
03-17-2024, 07:54 PM | #15 | |
Rep 2,614
Again, I think if the point is to actually cool the seat, which then would cool you, and not cool you directly, then it makes sense that you don't feel a whole lot of air coming out. I do generally feel better with the ventilation on than not so it's at least helping. |
03-17-2024, 08:24 PM | #16 |
Rep 929
And if you put a Pop-Tart on the dashboard…
————————————————————————————————————— 2024 Tanzanite Blue II M4 Convertible |
03-17-2024, 09:03 PM | #17 |
Rep 2,614
Well here's an actual answer:
From the G05 documentation, the function works to cool the seat itself and not you directly, air we feel is probably just residual of what the goal itself is. TBF this is from the G05 but I doubt it works much differently in the G8x. |
03-18-2024, 07:47 AM | #18 | |
Rep 6,696
03-18-2024, 08:32 AM | #19 |
Rep 851
03-18-2024, 08:46 AM | #20 | |
Rep 1,422
The ones in the M3 are weird. In operation, they feel to me more like the ones in the Audi, where air is being drawn away from you than others I've experienced that blow air directly on you. But if I turn up ventilation to the highest setting, put a grocery bag open end down on the seat bottom, and hold the edges down, the bag very slowly inflates. Air is coming out, but the amount is very slight. So my theory is that they're intended to work on a principle similar but not identical to the VWAG ones, where the primary goal is to cool the seat mass and not the occupant directly. This in turn allows more heat to be absorbed from the occupant as a secondary effect. They do this by circulating air through the internals of the seat, a small amount of which can escape through the perforations. But the air coming out is not the primary source of cooling effect. I don't know if it even comes out at all when you're actually sitting there. Again, this is my supposition based on observation and not a statement of fact. An alternative explanation is that they are intended to blow out at the occupant, and even with nine fans, they still barely push any air at all. |
Berzerker2885.00 |
03-18-2024, 09:57 AM | #21 | |
Rep 6,696
03-18-2024, 10:09 AM | #22 |
Rep 851
