BMW M3 and M4 - The Icons
home
      03-27-2024, 06:13 PM   #67
RUNSOK
RUNSOK's Avatar
237
Drives: 24 M4 COMP XDRIVE
Originally Posted by adc View Post
Sorry, but this is most emphatically not true. I mean yes to the physics, but the pressures will go up significantly. The CS is a heavy fast car, it will definitely heat up the tires and the brakes.
Even in the middle of summer, I start my first morning session at 26PSI, to end up at 34-35PSI hot.
For the rest of the sessions, it depends on how much the tires get to cool down in between runs. So ambient temps, sunny vs. cloudy, which side of the car gets heated by the sun - all are variables the driver must take into considerations. In my case, I re-adjust the tire pressures before each run - not doing so tends to ruin both the fun and the tires. Since the M cars come with a tire compressor, why not.
After a year on track you tend to develop a sense for it.
Sorry to hijack the thread but what tires are u running when you are starting with cold 26psi to reach 34-35 hot. ?? Thx
      03-27-2024, 10:00 PM   #68
edi221
Drives: 2023 G80 M3C
Originally Posted by BackOnBlack View Post
You can see it in this video @ 46 sec. mark:
Wow, I learn something new. Can the cover be taken off permanently? I mean just take the cover off permanently for daily use too?
CJ4211559.00
      03-27-2024, 10:49 PM   #69
BackOnBlack
Learning to drive again
BackOnBlack's Avatar
714
Drives: M3CS
2024 BMW M3 CS  [10.00]
That’s what I do, although it is not recommended. It is very easy to take it off and put it back on, its a just clip.
Cheers,
BoB
      03-28-2024, 11:46 AM   #70
willyp
Drives: M5C, M3CS, X5
Thanks for sharing, I am curious as to why it wouldn't be recommended for daily driving also?
IG- thewillpeoples
      03-28-2024, 12:39 PM   #71
BackOnBlack
714
Drives: M3CS
Supposedly, according to BMW, during inclement weather it allows more water to reach the brakes.
Cheers,
BoB
willyp158.50
      03-29-2024, 01:01 PM   #72
BiHT4
Drives: BMW M4
Thats a hell of a car! You drove it like a mad lad!
      03-29-2024, 05:27 PM   #73
//M235ixD
//M235ixD's Avatar
Drives: 2015 //M235i xDrive
Great video!! Thanks for sharing
      04-01-2024, 10:40 AM   #74
adc
Drives: 2018 F80 M3 ED
I've run various. Nitto NT01, Yoko 052, Toyo R888, slicks of various denominations. I run the advanced or instructor groups, the pace is fairly high and these are fast/heavy cars, tires do heat up quickly. The OP's car is very fast, so if he is a decent hand behind the wheel...
I think I'd still recommend a difference of 6PSI to begin with even in the Intermediate group. See where that takes you, and adjust accordingly. Since it isn't a race, if something feels off, you can pull into the hot pits and adjust mid-session if needed.
You need to experiment and understand how precise the onboard TPMS is, if you are using it for monitoring (I use it but mine typically shows about 0.5-1PSI low on the track setup).
Naturally you need to know what hot pressures to aim for, and that is tire-dependent (follow the tire manufacturer recommendations).
Many tires start to get greasy once they go past the recommended hot pressures and/or temps. Once the pressure/temp shoots up past the recommended values, it is very hard to bring back down while lapping. Managing that aspect basically lets you either enjoy the full 30 min session, or just a peak of 2-3 laps.
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
RUNSOK237.00
      04-01-2024, 10:45 AM   #75
adc
OP, if you itch to go back on track soon, the Colonial Challenge Cup runs 1 day at Summit Point on April 11. I've run with them for many years.
It's a relaxed group, who donates the proceeds towards a worthy cause
(sponsoring scholarships for kids in need).
I've signed up, and so have a few of my friends. Hope to see you there if you decide to come. Look for the only Santorini F80 in the paddock.
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
RUNSOK237.00
      04-01-2024, 10:55 AM   #76
RUNSOK
RUNSOK's Avatar
237
Thanks for the info. I am aware of cooking the tires when you get passed the recommended pressures and temp. I am on stock oem michelin stars on a completely stock car g82x. If I am looking for a 6psi gap between cold and hot pressures do you know what hot pressure I should shoot for the michelins?? I have been on track many times on formula cars in scca and road bikes as well. Just want to know what is a good hot pressure/temp for the oem michelins these cars come with. Thanks.
      04-01-2024, 11:30 AM   #77
BackOnBlack
714
Drives: M3CS
The itch is strong with this one!
Unfortunately, work/family schedule is not suitable. My entire schedule is now focused on the May event with the NCC. I hope I'll see you there. Be safe and run fast!
Obviously, I cannot give specific recommendations on cold pressures, but I just wanted to suggest that you probably should plan on 7-9 psi increase, not 6
Cheers,
BoB
      04-01-2024, 03:19 PM   #78
vlo
vlo's Avatar
Drives: G80 M3 Competition xDrive
Excellent write up. Loved this track when I lived in Arlington. Did ~10 track days there with my s2000 and 370z. If it wasn’t 2k miles away now I’d definitely bring the m3 there!
      04-01-2024, 03:42 PM   #79
kiysersosae
kiysersosae's Avatar
436
Drives: 1M, M2CS, M3CS
I just completed a track day at Knockhill in the M3CS, great weather with 14degc outside temp.
First time I’ve been on a track day with the car and only the 2nd or 3rd at knockhill. I put a 58 sec dead on a recorded lap using PS4S which with a full tank and 2 of us i was happy with, the tyres were melting and I couldn’t adjust pressures when warm as I had no pump so just ran with slightly over inflated rubber. I was seeing about 2.9 bar and 60-70degC tyre temp
I ran the car mostly in 4WD sport mdm on, comfort steering, sport brake, sport +suspension and sport engine. I did shift to 2wd traction 7 for a few laps and it was fine, just as planted really.
      04-01-2024, 03:53 PM   #80
kiysersosae
436
Thank you! I hope you have a great time, I am sure you will
I was using the Sport for steering, and it felt fine to me. The instructor suggested I use the Normal setting. I did not feel anything different frankly, it was a non-issue either way.
I experimented with Normal setting for brakes initially, then I tried Sport for the sake of trying, and it felt much better. The 'better' part wasn't about how applied the braking, but more during the release of the brakes. I was much smoother releasing the brakes, but I cannot say why that was the case. So, I left it in Sport afterwards.
Other M settings that worked really well for me were:
- Engine: Sport
- Suspension: Sport+
- Trans: S3
- MDM
- AWD Sport
As I mention in my write up, there is much I can write on the tyres, and I did not for the sake of not boring everyone. One thing I can mention about my PS4S experience is that how the tyres behaviour changed depending on the initial 4-5 miles of heat build up. If I pushed the tires a bit too early, they did not do well throughout the whole session. If I took my time, stayed patient, then they performed at an acceptable range.
That initial heat build up, btw, wasn't during the corners, but under braking. If I used all of the braking available too early, the tyre would shoot up in temp, which you don't realize because the screen only updates once per minute, I believe. That rapid build up, screwed 2 sessions for me, until I figure it out. So, I used about 70-80% of the braking for the first two laps, then went on as usual.
Best of luck to you.
Hey
I ran the same as you but only difference was I left the steering in Comfort, as you said, I couldn’t really tell the difference.
One thing, my fronts were in worse condition than the rears by the end, did you experience the same?
I only had 2 hrs of track time.
      04-02-2024, 12:18 PM   #81
m2for2
m2for2's Avatar
Germany
225
Drives: 2024 M3 Comp xDrive
Originally Posted by jeremyuhh View Post
How did you like the ZF transmission on track ?
Good question
      04-02-2024, 09:19 PM   #82
BackOnBlack
714
Drives: M3CS
Originally Posted by butraymond View Post
nice car! I’m in the black m2c.
Will you be at the May event with the NCC?
Originally Posted by kiysersosae View Post
Hey
Firstly, I hope you tell us about your experience
I will take pictures of the tires to compare, but I think my tires may look a tad better than yours. Then again, I only ran about 110-120 miles on dry track due heavy rain. And I was timid and slow, so I don't think my tires even noticed they were running on a track, besides the high temps and pressure gains
Originally Posted by m2for2 View Post
Good question
Please see post #11
Cheers,
BoB
      04-02-2024, 09:37 PM   #83
adc
NCC is a little too crowded for me, especially at Summit Point. That means you end up spending time in long trains behind slower cars.
My advice in general, look for events run by Chin (best organization, best drivers), Trackdaze, Hooked on Driving, and others. And most definitely sign up for a 2-day event at VIR. That track was *made* for our cars, much better than Summit.
I know, I know, one step at a time. But I had to get it out.
2018 F80 Santorini
2019 Z4 3.0i
2022 X2 M35i
PDOT130.00
      04-02-2024, 10:15 PM   #84
BackOnBlack
714
Drives: M3CS
I actually like traffic . Of course, if it gets so bad that I cannot run even a single clean lap, that's different. We'll see...
I love VIR. I was there, I think, last time in 2013. I quit tracking around 2015 or so, if I remember right. Now I want to try a new track I never been to, like Thunderbolt or PittRace. I am not sure I will be able to do it this year, but for sure next year.
Cheers,
BoB
      04-03-2024, 11:24 AM   #85
BackOnBlack
714
Drives: M3CS
Hey
As I suspected, I think my tires overall look a tad better than yours. And I imagine, you were pushing the car/tires more than I were
These are the front left:
Name:  PostTrackRun - LF Tire.png
Name:  PostTrackRun - LF Shoulder.png
Here is the right front:
Name:  PostTrackRun - RF Tire.png
And the left rear:
Name:  PostTrackRun - LR Tire.png
Cheers,
BoB
      04-03-2024, 02:11 PM   #86
kiysersosae
436
Good question
I found it was great! I had it in its quickest setting and I never felt like it was slow or unresponsive, it’s fast but definitely not the fastest change I’ve had. It never made any difference to the experience.
One thing I like more with the Zf than the DCT cahnge is that with the DCT in its quickest setting it felt like it unsettled the car a bit, so I think Zf is better in this regard.
      04-03-2024, 04:57 PM   #87
BackOnBlack
714
Drives: M3CS
One thing I like more with the Zf than the DCT change is that with the DCT in its quickest setting it felt like it unsettled the car a bit, so I think Zf is better in this regard.
Yes, I completely agree as well.
Cheers,
BoB
      04-13-2024, 02:44 AM   #88
imperfectluck
imperfectluck's Avatar
427
Drives: 20' F87
Reminds me of why I had my DCT tuned on XHP to find a better clamping force sweet spot which I did and made me appreciate the gearbox even more.
adc curious your thoughts on the F8x DCT box in stock fashion vs the ZF8HP tuned for the CS in particular.
g80
