Technical Topics DIYs and Coding Discussions added wireless charging tray and coding for phone reminder
      09-18-2021, 10:35 PM   #133
mhannis
Drives: M4
Originally Posted by X54TH View Post
Has anyone installed the OEM wireless charging pad that did not come with an NFC pad?
Looking for the same info. Have a 2022 M340xi that didn't come with NFC or Wireless.
      09-19-2021, 07:45 AM   #134
X54TH
Member
X54TH's Avatar
Drives: 2019 X5 40i M Sport
Unfortunately we don't have the harness to plug it in that any of us could find. I just did the aftermarket one that has an easy connection to the 12V.
2019 X5 Alpine White M-Sport
Software Version 11/2022.31
2023 M2 (HEA) Brooklyn Gray
2021 330i XDrive Alpine White M-Sport
ssgm1x418.50
Cstef6.00
      09-22-2021, 02:02 PM   #135
ssgm1x
ssgm1x's Avatar
Drives: 2020 M340i & 2018 M3
Very Nice. What did it cost and where did you purchase from ?
2020 BMW M340ix Dravit Grey
2018 BMW M3 Alpine White
      09-22-2021, 02:08 PM   #136
X54TH
Member
X54TH's Avatar
Got it on eBay and it was $60 USD. This was an easy plug in connection to the 12v. No splicing or anything like that. The only challenge, which wasn't much, was to enlarge the second hole on the tray (the one in the back) to feed the black wire.
My only beef about the unit is the indicator light. Wish it was on the bottom. The larger phones with a cover would hide that light.
      10-21-2021, 06:52 PM   #137
X54TH
Member
X54TH's Avatar
Originally Posted by lerivid View Post
If I have the NFC mat in my 330 and want to swap to the wireless charging mat, is the new mat the only part I need to purchase? [COLOR="White"] vidmate app save insta video[/COLOR]
It's my understanding you'll swap out the NFC for the OEM charging pad. It's an easy swap.
      10-22-2021, 06:38 PM   #138
Wstellin
Drives: 2012 328i conv
Rear head rest removal on 2021 BMW M440i convertibles.
Pry up the grey trim cap at the base of each leg of the head rest. Underneath is a squeeze clip similar to the exposed squeeze adjustment for the front seats. Squeeze the clip and lift the head rest out of its holder. It slides out very easy. Snap the grey decorative cover back. That's it. The only tool needed is something thin bladed like a knife to pry up the decorative cap
      10-28-2021, 10:54 AM   #139
Frank The Bunny
Drives: 2022 BMW M340i
Originally Posted by minakoto00 View Post
To enable both display option and audio/visual reminder in the gauge cluster, code the following params,
1. BDC -> WcaWirelessChargingAblage-> WCA_ENABLE -> aktiv
2. HU_MGU -> 3000 HMI_SPEECH -> WCA -> aktiv
Will this work without having the BMW wireless charger installed?
I have an aftermarket wireless charger on the way, and hoping I can code this without the actual BMW pad installed.
My ODBLink is also on the way, otherwise I'd just test it out myself.
Thanks!
      10-30-2021, 03:38 PM   #140
X54TH
Member
X54TH's Avatar
Thanks!
I tried coding it on the aftermarket one and it didn't work.
      10-30-2021, 10:59 PM   #141
Tim@codemybimmer
Tim@codemybimmer's Avatar
Drives: 2022 X4 M Competition F98 LCI
This DOES NOT work with the aftermarket chargers, as they are only connected to the 12V and ground.
You can retrofit the OEM charger by splicing the 12V, ground, and the KCAN4 connectors on the BDC module. Then you can code for the reminders to work.
I am unsure however if the Digital Key functionality can be retrofitted as well, since technically you can acquire the OEM Wireless Charger with NFC pad but the activation will likely require ConnectedDrive services - I will be retrofitting the OEM one once I get the part for my F98 LCI however, since the Digital Key was removed.
      11-05-2021, 11:48 AM   #142
minakoto00
minakoto00's Avatar
Drives: G20 330i xDrive Luxury Line
Thanks!
Hi,
I've only tested it on the OEM pad myself so I'm doubting that would work though I hope it would. But if the connector's wiring of aftermarket pad is similar or even the same as the OEM one (so the BDC would still be able to detect the electrical signal from the charging pad when engine is shutoff in this case), it wouldn't surprise me if it works.
But it wouldn't do any harm to try it Post it here if it works.
Thanks
      11-17-2021, 04:11 PM   #143
Sbm007
Sbm007's Avatar
614
Drives: G80 M3CX (Oxide Grey)
Just retrofitted this on my G80 M3 using part number 84-10-5-A1D-B18 (cost $150)
Literally took me 20 mins to fit, just need plastic trim removal tools, and a hex screwdriver, some photos:
Wireless charging and NFC both work. I tested my iPhone digital key start engine, and the credit card digital key start engine.
Just need to code in the forgot phone reminder via the Bimmercode app (for when you leave the phone on the charger), which I will do on the weekend.
Gone:
2011 E90 318d (Alpine White) • 2016 F83 M4 (Mineral White) • 2019 F83 M4 Competition (Sapphire Black)
2022 G80 M3 Competition M xDrive (Oxide Grey)
helmet91299.00
Cstef6.00
      11-18-2021, 04:08 AM   #144
helmet91
helmet91's Avatar
Netherlands
299
Is 84-10-5-A1D-B18 the newest revision then?
      11-18-2021, 05:46 AM   #145
Sbm007
Sbm007's Avatar
614
I believe so but I am not 100% sure, if someone has access to BMW parts catalog maybe they can check?
Gone:
      12-04-2021, 06:41 PM   #146
bmwjh
Drives: bmw 330xe
I have a 2022 330xe (no nfc) and I bought 84-10-5-A1D-B18. When it arrived I just realized it's just a tray without any connector so I can't install it on my vehicle. (I believe if my car has nfc then it should be fine) Does anyone know what's the connector part I need to get for it to work? Thanks!
      12-12-2021, 06:53 PM   #147
X54TH
Member
X54TH's Avatar
I had the same blank tray (no NFC) and couldn't find the connection so I went with an aftermarket one.
      12-15-2021, 09:25 AM   #148
hottroc
Drives: BMW 330e
I posted it earlier in this thread, (about post 84). But knowing what it is and actually being able to get it are different things, let me know if you have any luck.
      02-20-2022, 03:54 PM   #149
Bimmerli
Drives: m340i
Has anyone who has installed the latest hardware version of the oem wireless charging pad experienced the orange light / phone not charging / phone overheating?
Nardo Grey M340iX LHD / leathers & loaded
      02-27-2022, 03:17 PM   #150
Cstef
Drives: G23
Originally Posted by greekcs View Post
This was a relatively easy install. The hardest part was unplugging the USB and 12V socket connectors to remove the cupholder. It works just as advertised and even reminds you (with some coding) if you've left the phone in the cradle.
Total cost: $120 Shipped from EU
Thank you helps me out perfect I did the switch with succes !
I only must remove the rfid and iPhone digital key and reinstall them to work everything is fine now !
kind regards Stef . I did the coding with bimmercode advanced setting.
      02-27-2022, 03:19 PM   #151
Cstef
Drives: G23
i have only a blue led light al the time .
kind regards Stef.
      03-07-2022, 05:41 PM   #152
13307
Drives: 18 F82 M4 ZCP Black/Black
Try turning nfc off on your phone and see if it fixes your issue
      10-28-2022, 09:59 PM   #153
Fragmaster
Drives: e90 335
is there a chance you know where this type of harness can be bought/ordered?
where is the BDC module's location?
trying to retrofit 340/22 without NFC option.
      11-04-2022, 09:15 PM   #154
j luke
I'm in the same boat. My 340/22 came with NFC deleted. The center console has just a plastic tray with a rubber mat. I purchased the OEM wireless charging tray from BMW (Part# 84-10-5-A3E-813) and when I tried installing it I ran into two problems.
1. There is no connector to plug the charging tray into. When I ordered my car the wireless charging tray was an option, I just didn't select it. So with it as an option I assumed that the connector would be there even if there was no NFC. Wrong.
2. The charging tray will not fit into the space on the plastic tray. I removed the rubber mat but there are tabs on the edge that prevent the charging tray from sitting flat on the plastic tray. Very frustrating.
So, I put everything back together and will now see if BMW will take the charging tray back.
