04-27-2023, 12:17 PM | #1 |
Rep 69
Those with Dinan lowering springs on G20 - did it achieve advertised height?
I have a 2020 330i RWD. Installed the Dinan lowering springs and bump stop kit. Their advertised drop is 1 1/4" front and 3/4" rear for the RWD platform.
Measurements from center of hub to bottom of fender on OEM springs was 15" front and 14 3/4" rear. After 500 miles of driving it measures 14 1/4" front and 14 5/8" rear. That is only a drop of 3/4" front and a whopping 1/8" rear. I contacted Dinan and the only thing they have asked is if I had a full tank of gas (LOL) and asked for photos of the spring perches - which I provided and they said looked good. The only other thing he has suggested is to hilope they settle over time. I would think 500 miles of driving would be plenty and I've never seen springs settle 1/2" before. My question is, has anyone else had this issue with the RWD on Dinan springs? If so, did you find the cause? Thanks! Mike |
04-27-2023, 12:45 PM | #3 |
Rep 69
04-27-2023, 03:43 PM | #4 |
Rep 15,858
04-27-2023, 03:53 PM | #5 |
Rep 69
Thanks for the reply. The thought crossed my mind, but the Dinan site shows the same part number for both 330i and M340.
04-27-2023, 04:35 PM | #6 | |
Rep 15,858
Another thought. You did relax the appropriate bushing bolts and then re-torque at the new loaded positions. |
04-27-2023, 04:54 PM | #7 | |
Rep 69
I did definitely torque the rear bushings at the correct ride height. The front doesn't have any bushing components that are removed or loosened, so I just tightened those while suspension was drooped. I've done countless suspension installs on American, German and Japanese cars, so I'm confident that install is correct. I think there is something else at play, but who knows. |
HighlandPete6658.50 |
04-28-2023, 01:53 AM | #8 |
Rep 302
I don’t think I got the full advertised height by just a smidge which is fine by me. I know the H&Rs go a little lower but I heard it’s more of a squishy ride with those
2022 M340i xDrive, Mineral White/Tacora Red, Modesta Coated
05-01-2023, 02:02 PM | #9 |
Rep 69
Thanks ks for the reply. I would be ok with a little variation but it's off by 1/2" in front and nearly 3/4" in the rear. They ride great, but bummed about the drop.
jiimmmayyy235.00 |
