03-21-2022, 08:16 PM | #23 | ||
Rep 1,352
Air pressure is lower at higher altitude, so power is decreased, even on forced-induction motors. Just because one journalist says otherwise doesn't make it true. They're also different cars, so they aren't directly comparable. I have only ever heard that turbo motors lose less power than NA motors at altitude... but they still lose power. |
03-21-2022, 08:23 PM | #24 | |
Rep 5,484
Drives: 23 X7 40i; 23 M3; 24 cooper s
My comment on potential increases in power was in reference to the table from one of the articles (below) showing elevation change impacts on power output (the example is from a 500 hp 3.5L single turbo engine). Not only did it not see a drop in performance at altitude, it actually saw a slight increase. Like I said I'm willing to admit if I'm wrong but I'm just calling it like I see it. So let me know if I'm misinterpreting something.
2023 BMW X7 xDrive40i
2023 BMW M3 6MT 2024 Mini Cooper S Convertible '20 BMW m340i... '20 BMW X5 40i... '16 Infiniti Q50 RS 400... '10 Lexus RX 350... '08 Lexus IS 350... '00 Nissan Maxima... '93 Nissan Maxima |
G30M3789.50 |
03-21-2022, 08:26 PM | #25 | |
Rep 1,352
03-21-2022, 08:30 PM | #26 |
Rep 5,484
Possibly... heat soaking? I know the standard m340i without the ZTK cooling package is susceptible to heat soak at consistent heavy load... but if OP is experiencing this drop in performance at all times, I'm not sure that's the issue.
03-21-2022, 09:57 PM | #27 |
Rep 751
It says those cars are tuned to not lose power for the race. This means adjusting boost pressure to compensate as altitude increases. Turbos are not more efficient at altitude, they just make compensating for it easier if there is enough overhead left in the stock turbos (to safely and reliably crank up boost)
03-21-2022, 09:59 PM | #28 | |
Rep 4,143
i should have qualified, assuming the turbo does not increase the boost psi to compensate, there will be less oxygen molecules to burn the fuel. as you can see the ECU has been programmed to increase boost PSI. do we know if the M340i is programmed to detect lower air barometric pressure and increase PSI to compensate? maybe there's another detection method - i'm not a mechanical engineer. MAFS? O2 sensor? other sensor? |
wtwo317971.00 |
03-21-2022, 10:03 PM | #29 | |
Rep 4,143
it's all in the boost. at sea level if you increase the boost you will have more power. at altitude if you did not increase the boost you will have less power. we are observing the wrong cause-effect relationship. higher power is not caused by higher altitude. it's caused by the ECU. |
siegester344.50 |
03-21-2022, 10:05 PM | #30 | |
Rep 5,484
Someone in Denver should conduct a launch control to 60 and give us results... if it falls closer to 4.9 than 3.8 then perhaps bmw is limiting boost.
03-21-2022, 10:15 PM | #31 | |
Rep 5,484
I don't know enough about the tuning of each car to know for sure. And there's conflicting things I've read. Some places suggest that you shouldn't see a dip in performance as a blanket statement across all turbocharged motors.
03-21-2022, 10:55 PM | #32 | |
Rep 751
You will see a dip in performance (less than NA) at the same turbo loads given a higher altitude. To keep power the same the turbo must work harder and put more stress (psi) on the motor. The journalist hints at this by saying these cars were tuned for the altitude change |
03-21-2022, 11:16 PM | #35 |
Rep 4,143
i found the table that is posted above it's from garrett.
it specifically says the ECU compensates to adjust the boost to match the horses at sea level. (whether that statement is correct or not i don't know, someone said the boost should be the same ... ??? though in garrett's table the boost is definitely maxed out!) so i still think it could be that Germans did not think about tuning the ECU to Bolivia's elevation? i think the easiest thing for OP to do is to tell us the boost he's getting when he's launching maybe someone smart will figure out if that boost is normal or less than normal i don't launch my baby so i can't help. i launch EVs Last edited by G30M; 03-21-2022 at 11:22 PM.. |
wtwo317971.00 |
03-22-2022, 05:23 AM | #36 | |
Rep 5,484
However - now if we're suggesting that OP's car has reached the point of critical altitude (let's say BMW limits boost pressure so critical altitude is reached sooner than other manufacturers, like with the civic type R), then shouldn't the car be throwing up an overboost code when he's launching it? All this is why I still think there might be some other issues going on beyond elevation increase.
03-22-2022, 12:40 PM | #37 |
Rep 701
That chart and Pike's peak examples are apple or orange comparison to what we are talking about here.
If you wanna know if altitude affects HP in turbo cars, you compare the same boost at sea level and at altitude. You can't compare 10psi at sea level and 20 psi at elevation and claim that Turbos dont lose power. |
03-22-2022, 01:11 PM | #38 | |
Rep 5,484
In the below video if you skip to 2:14, he explains how a Ford Fusion sport will perform very similar at sea level as it does at altitude. So perhaps BMW turbo doesn't operate in a similar fashion and limits boost? That's the question then - what causes cars like a fusion sport or civic type r to not experience much performance loss, but an m340i does? Or maybe these guys are wrong.
03-22-2022, 01:14 PM | #39 |
Rep 140
I live in Mexico City, 2.2 km altitude and some highways out of the city (which is in a valley) can go up to 3.0 km or more. Altitude has always been an issue in the comments about hp in our cars, turbo or not.
With that in mind, I made around 4.2 in my 440i xDrive. My guess is that altitude, tires, even the kind of carpet the road has on it has a lot to do. Regards, JI |
wtwo317971.00 |
03-22-2022, 01:24 PM | #40 | |
Rep 701
Yah... I personally dont know if certain cars have variable boost management build into any stock cars. Maybe they do. But that only means the ECU modifies/tunes the cars to the environment. The fact that the ECU has to do that means altitude also affects turbo. It is just there are ways to compensate that loss with turbo (to a certain extend)and not much you can do with NA cars. If the FI cars dont have variable boost capability, then it will lose power for sure. Here are some examples. https://www.reddit.com/r/FiestaST/co...is_ridiculous/ |
wtwo317971.00 |
03-22-2022, 01:49 PM | #41 | |
Rep 5,484
Still doesn't explain why some sources suggest loss would be minimal for certain turbo cars. I'd like to get to the bottom of that...
03-22-2022, 02:05 PM | #42 | |
Rep 701
If your OCD is really that bad , Just take a road trip to a 10k peak and see if you could feel the difference yourself. That is the most reliable way. Everyone's 0-60 is gonna be different. From the way he described, he was not even using launch control. He was just torque braking. But he also has DP, so who knows.. there is a chance that someone messed it up or his airfilter lid is open from his KN filter. All possible. |
wtwo317971.00 |
03-22-2022, 02:17 PM | #43 | |
Rep 5,484
03-23-2022, 12:19 AM | #44 | |
Rep 16
