04-27-2024, 12:36 PM | #1 |
Rep 15
New iX, first charging at EA with Plug and Charge issue
I just picked up my new 2024 iX last week. I’m loving my first electric vehicle. Such a nice car!
I did my first charge at a public station yesterday and had an issue and wondered if this was normal. This was a fairly new EA station. I have the EA Plug and Charge contract properly loaded in the car, and the feature is turned on. I also have the EA account set up in the MY BMW app. I had never used it before yesterday. When I plugged the car in, the charger took a moment to communicate with the car, then came up with a “guest” screen showing prices. I figured it needed a moment to notice the Plug and Charge account, but it sat there quite a while and then the car said “Charging Error.” I unplugged and plugged in again and tried again with the same result. I then remembered that I had put the BMW free charging card into the Apple Wallet, so I pulled that up and, after unplugging/replugging, tapped the card reader. That gave an error that the reader wasn’t working, and I should use the app. Finally, I used the My BMW app and tapped “Charge Here.” It knew where I was, and I chose the charger number. It then came up and asked me to accept Terms and Conditions, which I did. After that, it started charging and worked well. I wonder if Plug and Charge didn’t work because I needed to accept the Terms and Conditions first? That seems plausible. I’ll definitely try again the next time I use an EA charger. I’d really like Plug and Charge to work, especially for my wife. Does this seem normal? Does anyone have advice or similar experience? And any tips and tricks for charging would be appreciated. This is all very new to me. Thanks. |
04-27-2024, 12:59 PM | #2 |
Rep 269
Same thing happened to me, exactly the same thing.
When I went back to the plug and charge section in the car, the EA contract was gone and I can’t get it back. When I first got the car the contract loaded without an issue within the day, now it’s gone. I called Genius , they couldn’t help, they told me to call EA and they told me to call BMW. Someone else on the forum has had success finally getting thru to EA and having them resend the contract to the car. |
04-27-2024, 01:07 PM | #3 |
Rep 94
So the guest screen issue happened to me a little over a week or two ago in Seattle. I told them exactly what I was seeing and had a little translation issue between me and the representative. What was confirmed is that the EA servers communication with BMW's server was "down"/"Malfunctioning" so plug and charge won't work when that happens. But you can open the BMW app and do it manually and it will work normally as usual.
I did discover how to get that stupid apple wallet EA card that is connected to the vehicle finally that some have it and others can't figure it out. You have to set up an EA account in the EA app and just use the same login credentials to make it easier. Once that is set up with a card, then you go back to the myBMW app -> charging -> Electrify America -> manage my plans -> payments & apple wallet -> add to apple wallet and just make sure the default is at the top "membership" area for the 30 minute charging contract. THEN you can share that card with your spouse or person if something like this happened if the plug and charge doesn't work from the apple wallet part when you bring up the card and share from there. |
Kennethjk160.00 |
04-27-2024, 01:08 PM | #4 |
Rep 15
The contract is still showing up in my car, so hopefully it will eventually work.
For me, after I got the car, it took 3 days before the Plug and Charge contract showed up in the car. |
04-27-2024, 01:43 PM | #5 |
Rep 1,193
So when you picked up your car, and assuming the software was current, Plug & Charge was available within the car.
This is a totally separate procedure to activate from the 2 years of free 30 minute charging you’re entitled to at EA as the first owner of a new iX. Most salespeople will activate the free charging at time of delivery. However, either your Salesperson or yourself had to call EA directly to have the Plug & Charge certificate sent to the iX; BMW does not activate this; only EA. This is how P&C gets activated, and it generally takes at least a few days for EA to send it. Also, some EA reps get the free charging and the P&C feature confused! |
04-27-2024, 02:06 PM | #6 |
Rep 15
When I picked up the car, the genius that ran me through the car’s features and set up Plug and Charge. The contract did not show up in the car, though, until 3 days later. It now shows up properly and shows active.
04-27-2024, 02:35 PM | #8 |
Rep 748
Drives: '24 iX M60 '23 Tesla Model Y-P
You don’t need to setup an EA account, and this is generally not recommended as some have reported it causes a conflict. Through the myBMW app charging section just click the green “active” next to Electrify America and then the “manage my plans” on the next screen. It should take you to a special pass through EA page where you can click “payment and Apple wallet” to put the free charging card into your Apple wallet.
04-27-2024, 06:10 PM | #9 | |
Rep 15
04-27-2024, 06:35 PM | #10 |
Rep 748
04-27-2024, 09:15 PM | #12 | |
Rep 269
Plug and Charge works perfectly with my Mach E. |
04-27-2024, 10:51 PM | #13 |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3539
Rep 4,222
Try again at another charger and see. Perhaps you hadn’t accepted everything yet. You should simply just be able to plug in and it will take a shirt while then it will start charging.
04-27-2024, 11:13 PM | #14 | |
Rep 94
04-28-2024, 08:55 AM | #15 |
Rep 189
It is useful to have an EA account along with plug & charge. When it's working correctly, you get the free 30 minutes without interaction beyond plugging in, and if you stay connected and need a few more kwh it will continue without needing intervention but billing your account for the overage beyond 30 minutes.
There are a few good service reps at EA who can straighten out account issues, but in my case it seemed to take having dealer mgmt make a call to get their attention & call me to kindly offer help. |
Kennethjk160.00 |
04-28-2024, 06:37 PM | #16 |
Rep 15
A quick follow-up:
I went back to an EA station today to charge, and Plug and Charge worked perfectly. Plugged in, it communicated with the car for a moment, and then started charging. This is very, very nice! |
thebishman608.50 |
04-29-2024, 05:37 PM | #18 |
Rep 269
After e mailing EA a couple of weeks ago I just heard back and they resolved the problem. My EA contract is now back in the car and plug and Charge should be fine
04-29-2024, 08:36 PM | #19 |
Rep 408
Fantastic…nice indeed. This is how Tesla superchargers work…all the time. I’m hoping Plug and Charge becomes a reliable norm in the next few years.
