02-01-2021, 07:14 AM | #23 |
Rep 56
This is my first BMW with the charging tray, and I too experienced the "hot phone" with my new iPhone 12 Pro from the beginning. I can't imagine it's good for the phone to get that hot. I didn't notice the light going to orange, but probably wasn't checking.
I tried to like it (and CarPlay, which I use and prefer in the Mercedes), but have since broken down and gone back to my "old" system - mount the phone near the 3 o'clock position of the steering wheel, turn on Waze, connect lightning to USB power cable, and use iDrive instead of CarPlay. The Scosche magnetic mount I got for this car (quite inexpensive) adheres just at the left edge of the center display but doesn't obscure anything, while the metal plate (to which the magnets grip) fits in the TPU phone protection case at the bottom, and it all works well. |
02-01-2021, 09:09 AM | #24 |
Rep 110
Its been really frustrating for me as well - makes carplay unusable after any drive lasting longer than 20-30mins. I started using the usb-c plug under the armrest but its not clean looking and I really liked having the phone tucked away.
I did some light searching but couldn't find anything is there a setting to turn off wireless charging, so we can just use the tray? |
02-01-2021, 10:48 AM | #25 | |
Rep 309
02-01-2021, 03:36 PM | #26 | |
Rep 168
02-01-2021, 08:32 PM | #27 | ||
Rep 259
02-02-2021, 02:55 AM | #28 |
Rep 309
It was in another menu, once I get to my car either later today or tomorrow I'll have a look.
Btw an option to not have your phone charged is to pull it to the front or back of the tray or just to put it screen down, I simply put it screen down once it starts overheating. |
themnmd1691.00 |
02-02-2021, 09:49 AM | #29 |
Rep 168
02-04-2021, 11:33 AM | #30 |
Rep 168
Actually you were right, even I don't see the option to disable the wireless charging in the car settings. I can see only the notification reminder option. But I thought I have seen the option to enable/disable the wireless charging in some option. If I come across again, i'll keep you posted.
achk132.50 |
02-15-2021, 09:21 PM | #31 |
Rep 616
Drives: Little of this, little of that
I have an iPhone 12 Pro Max. Inductive charging with the Qi standard creates heat due to inefficiency. Using the maglock charger, the connection area gets even hotter. However, in the case of the iPhone, if it were to overheat, it would shut down. I can get into my car and putting the phone on the charger will produce an amber light. I know that this is not over-heating but rather just poor connection. A re-adjust will produce a charging blue light. I tried different cases, all with the same result.
The owners manual does state that excessive heat will cause an amber "no charge" light but there is no specification as to what temp will cause this. What I really am interested in is the signal booster that is built into the charging pad area. All I see in the owners manual is that I have it and that I need to register the booster with my carrier. Does it even work? |
02-16-2021, 11:52 AM | #32 | |
Rep 1,479
Drives: 2020 M340Xi (G20)
How do I know if I even have a signal booster? If I do, who do I register it with -- my cell phone provider or the car's WiFi hotspot provider? Very interesting
Al
02-16-2021, 05:29 PM | #33 | ||
Rep 616
I have to make it a point to RTFM. I usually do but have been slacking. Quote:
02-18-2021, 10:35 AM | #34 |
Rep 1,479
Here's what I found on another model sight -- this might address your question; an also checking with my dealer
Al
2020 M340Xi| ZDA| ZDY| ZPP| ZPX| 1CR| 1PL| 688| 6NW| 2VFH| Retired: 2014 328i BMW CCA Last edited by RSnic; 02-18-2021 at 03:51 PM.. |
Rux643.50 |
02-18-2021, 09:34 PM | #35 |
Rep 616
02-18-2021, 09:36 PM | #36 |
Rep 2,699
Drives: 23 X5MC
Have same issue. My phone S9, has an otter box case. It's a rubber case because I am hard on my phones. If I put in the charger it will over heat but not all the time. If I have it out of the case does not seem heat up. Most of the time I plug it in, charges faster too.
02-26-2021, 09:38 AM | #37 | ||
Part of the bimmer family!
139
Rep 293
Drives: BMWG20; BMW E90
02-27-2021, 06:01 AM | #38 |
Rick James
305
Rep 784
Do any of you think the overheating might be influenced by the option to “optimize charging” option in settings? Not sure, but if it stops at 80%, as per the function of that option) and continues to heat up and “slowly” charge after 80% to protect the battery. I wonder if the charging tray eases back at all? That’s the only scenario I can think of that would cause this....
02-27-2021, 08:32 AM | #39 | |
Rep 309
That's why apple's magsafe chargers are tiny, so that the least possible heat is generated and thus energy lost. |
randybobandy304.50 |
03-06-2021, 02:17 PM | #40 |
Rep 285
My S20 phone gets pretty hot, but the blue light is always on, no problem.
Charging is quite slow, it is really more preventing battery drain than actual charge especially when using phone for NAV and music. I noticed no difference with plastic phone cover or without. |
05-06-2023, 05:54 PM | #41 |
Rep 4
After reading these replies, I recently started using Android Auto and previously used Idrive7 and my phone did not overheat until I started using it as another post mentioned something about it being in use when compared to night time charging and phones not being used. I am going back to Idrive7 and see what happens.
05-17-2023, 05:15 PM | #42 |
Rep 8
The problem is automotive designers not understanding how wireless charging works. Wireless charging always generates more heat than regular charging. At home, your wireless charger sits on a table or desk out in the open where the heat can disipate. And often times you aren't using your phone when it's sitting there charging. But for some reason car makers always put the chargers in a cubby so there's limited airflow, and often times you're using CarPlay or Android Auto which makes the phone even hotter, and if the sun hits the phone just right it gets even hotter. Car makers need to start putting cooling vents in the charging pad, similar to what Samsung does for it's fast wireless chargers.
10-26-2023, 07:23 AM | #43 |
Rep 4
I had same phone overheating issue with Android Auto. I recently disabled Android Auto on my phone and only use idrive 7, which I like better btw. The overheating issue has stopped and my phone charges just fine now. I like idrive 7 maps better and audio quality is much cleaner also.
11-13-2023, 05:28 PM | #44 |
Rep 71
I have the same problem with overheating and the battery draining rather than charging in my new G21 using a Samsung Galaxy S21 Ultra.
My "solution" is to use an external wireless charger plugged into the 12V just beneath the cup holders. |
