05-28-2023, 11:33 AM | #1 |
Rep 2
iDrive recommended tire pressure values
iDrive recommended tire pressure values assume maximum rated payload capacity. If I follow the recommended settings (F-35psi, R-42psi) and drive empty (single driver no cargo) most of the time, my tires (especially the rear ones) will begin to show over inflation wear, i.e. wear in the center of the tread.
Knowing that my G20 has an almost 50/50 weight distribution in this configuration, I have determined through careful analysis, including consulting Bridgestone's tire pressure tables, that my G20 with Bridgestone 225/40R19s RFs at all four corners wear uniformly if they are all maintained at 35psi (with no handling impacts and marginally better ride quality). Unfortunately, the iDrive doesn't like this setup. Is there a way to change the iDrive recommended tire pressure settings so that I can run 35psi at all four corners and keep iDrive happy? |
05-28-2023, 02:51 PM | #2 | |
Rep 15,858
Also remember the suggested pressure in iDrive is the temperature related, running/working pressure, not a cold setting pressure. |
05-28-2023, 03:01 PM | #3 | |
Rep 605
As I always set my tire pressure to the door jamb numbers cold, why would I need to be concerned about what drive says I should follow for running/ working pressure? Unless after some time driving, and a tire lost pressure for some reason, and needed to fill with air, I could see what Idrive says to use. |
05-28-2023, 04:27 PM | #4 | |||
Rep 15,858
I know from my own experience that the recommended cold setting pressure isn't always appropriate for all ambient temperatures and trip duration. May need some adjustment to run at the optimum pressure for performance and wear. |
06-18-2023, 05:14 PM | #5 |
Rep 2
Highland Pete, thanks for the response. When you say that when running low rear pressures it is "easy to knock off the inside shoulders", do you mean under-inflation wear, or something else? I am keeping a careful eye on the wear patterns of the rears after having reduced them to 35psi. And yes, they are run flats.
06-19-2023, 10:06 AM | #6 | |
Rep 15,858
This wear is affected by both static camber settings and dynamically, when driving lots of sharper bends and faster turns. Many users have learned the hard way, being caught out with rapid inner shoulder wear, due to being on the lower side of optimum. See how local and extreme it can be. |
calbearz2437.00 |
06-21-2023, 06:41 AM | #7 |
Professor
2406
Rep 1,911
Drives: '23 M2 & '22 X3 M Competition
I think the BMW I-drive recommendations are unnecessary. I set my pressures to the cold pressure listed on the door jamb sticker in all my vehicles and have no issues with abnormal tire wear. My 330e has uniform wear front & rear at 20k mi. I drive solo in my vehicle 99% of the time. I think I've looked at the I-drive once & paid no attention to it.
calbearz2437.00 |
06-21-2023, 08:27 AM | #8 | |
Rep 15,858
Even with door plate/sticker recommendations, it surprises me how many topics we have on this forum, asking "what tire pressure should I use?" |
calbearz2437.00 |
06-23-2023, 06:54 AM | #9 | |
Professor
2406
Rep 1,911
HighlandPete6663.00 calbearz2437.00 |
