03-14-2023, 06:31 PM | #23 | |
Rep 25
NLJ82.50 |
03-14-2023, 06:43 PM | #24 |
![]() ![]() ![]() 6261
Rep 15,398
There are different HP ratings (up to 18 hp) for different models with the 48 V motor integral with the transmission. I'm seeing 200 Nm (147.5 lb ft) as the nominal figure for torque on different setups, like the X5 and 7-series.
03-14-2023, 06:56 PM | #25 |
![]() ![]() 83
Rep 237
Drives: 2023 M340i
I don't think there are official torque numbers for the mild hybrid. I've looked. But it is between 10-11hp.
03-14-2023, 08:24 PM | #26 |
BMW Master Technician - HV Gen 5 and HV Specialist
2841
Rep 3,714
If this is updating to TU2 for 6 cylinder then yes it is still 48v but no longer has a starter motor generator on the belt drive. It has a 48v trans that can allow for better starting and smoother operation of MSA. Almost always starts from trans and not starter whereas the previous 48v cars would primarily start cold with starter and then once warm through the 48V SGR
TheMaxXHD450.50 dhock_holiday27.00 |
03-14-2023, 08:52 PM | #27 | |
![]() ![]() ![]() 451
Rep 314
According to what I’ve found, the HP remains roughly the same between Gen 1 and Gen 2 (low to mid 10s depending on the vehicle). Torque numbers were never given for Gen 1, likely because it was limited torque added across the range due to where it was mounted. Having Gen 2 be trans mounted means the ability to access more torque when needed is possible. That said, others have stated the torque fill is fairly limited. A good post I’ve found from xlover : https://f30.bimmerpost.com/forums/sh...14&postcount=7 |
03-14-2023, 09:57 PM | #28 |
![]() 2529
Rep 4,765
Drives: 2020 Dravit Grey M340i xDrive
Garage List 2020 BMW M340i xDrive [10.00]
2018 BMW 340i M Sport [0.00] 2006 BMW 330i Sport [0.00] 2004 BMW 330i ZHP [0.00] 2000 BMW 328i [0.00] |
I didn’t even notice that! I couldn’t figure out how an ///M2 came into the conversation.
![]() www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
03-14-2023, 10:56 PM | #29 | |
![]() 1736
Rep 2,206
the formula is HP = Torque X RPM plus some constant (1/5252 for ICE, no idea what it is for the mild hybrid motor) so if decent torque at low rpm then low hp but ... yeah ... who knows ... it sounds like it needs to be at very very low RPM. which does make sense, if it's for getting the car moving from standstill. Last edited by g21; 03-15-2023 at 12:38 AM.. |
03-15-2023, 04:34 AM | #30 | |
Rep 15,398
Typical belt drive motor generators are limited in torque, even with designs up to 12 kW. Figures in the 50 - 60 Nm range are used in association with recuperation torque. I sense the belt performance limits the torque, both as motor and generator. |
03-15-2023, 11:51 AM | #33 | |
![]() 1208
Rep 4,574
I do wonder if Gen 2 requires bigger MH battery than Gen 1, and if there is extra wear and tear on that battery. |
03-15-2023, 12:03 PM | #34 |
![]() 1439
Rep 2,753
B58 upgrade adds port fuel injection (PFI and DI) to improve emissions. PFI and DI offers greater flexibility to meet emissions requirements across load/speed range.
03-15-2023, 12:14 PM | #35 |
Auto/DCT Zealot
![]() 350
Rep 301
Drives: M3, Miata
Not to mention that port injection also helps with carbon valve fouling commonly found in direct injection turbo engines. Big win.
- 2017 BMW M3 Competition / Silverstone II / DCT
- 2020 Mazda MX-5 Grand Touring / Machine Grey / Soft Top / (Awaiting CARB-EO) Edelbrock Supercharger |
03-15-2023, 12:16 PM | #36 |
![]() 151
Rep 1,132
Is the official announcement of the LCI 4 series with TU2 engine supposed to be this month? From OP it says March? Hopefully we'll learn for certain very soon what specific changes have been made to power and torque (aside from emissions improvements)
03-15-2023, 12:19 PM | #37 |
Rep 314
2024 as in calendar year 2024, so MY2025. Still a year away. Don’t think 4 series LCI will start with this engine. I think that is the point being made.
momo3605151.00 dhock_holiday27.00 |
03-15-2023, 12:24 PM | #38 | |
Rep 15,398
As an example, data is for the 740d. |
03-15-2023, 01:48 PM | #39 |
![]() 2529
Rep 4,765
Maybe I’m crazy or uninformed, but this “belt” talk about the M340i mild hybrid is the first time in four years I’ve heard anything like that. From the very first introduction of the mild hybrid into the 2021 M340i what I read and what my understanding was is the traditional starter was replaced from the very beginning and the mild hybrid motor/generator was integrated into the transmission from the very beginning. That was the thing that was talked about that made the ASS engagement so smooth in the new car. This has been my understanding right from the start. This is what I was reading. I’m pretty sure I didn’t dream that, since I knew nothing about the system until I read about it.
This interview from January 2019 seems to indicate “Generation 2” was what was about to be introduced. “The engineering chief at BMW says that the company built some first-generation 48V applications just to learn the systems, but the focus is really on the second-generation. “Generation 2 means that I double the electric power. I’m going to 20kW and instead of going to the belt motor alternator, I will go into the transmission. So we are partnering with ZF and at the beginning of the next decade, we will have the latest generation transmissions. We will not only have double the power, but also an integrated 48-volt system and because it’s behind the engine, we can do some crawling and some other things without using the engine. And the other thing is, that it has boost!”” Again, this interview was in January 2019. https://www.bmwblog.com/2019/01/30/b...e-48v-systems/
03-15-2023, 02:01 PM | #40 |
![]() ![]() 291
Rep 1,712
Drives: 2014 650xi Gran Coupe Msport
Feeling pretty pleased with my 2020 non -MH motor and stage 2 tune. Don’t want the headaches and complexity of the hybrid motor. Is this the last great true ICE motor BMW builds?
2014 BMW 650xi Gran Coupe Msport Black Sapphire Metallic on full black merino leather. 20" M5 343M wheels for summer, 20" 373 wheels for winter with Nokian Hakkapeliitta 8 studded snow tires. M6 CP exhaust with M6 Diffuser and ///M Performance carbon fiber finisher. Mission Performance stage 1.5 and transmission tune.
03-15-2023, 02:34 PM | #41 |
![]() 2529
Rep 4,765
Yes, most likely it is. Which is exactly why I just bought a 2020. I did the same type of thing in 2009 when I chose a 2006 E90 330i, because I wanted the last of the naturally aspirated inline six motors. If the B58 and the ZF8 hadn’t turned out to be so great I’d still have that 330i.
03-15-2023, 02:42 PM | #42 | |
Rep 15,398
Only recently have BMW introduced the 2nd generation integrated MH system as in the latest 7-series. I remember press releases last autumn time for the integrated systems starting to be fitted to top end models. All the technical details of the belt drive system and repair procedures are documented for cars like the G20 M340i. |
03-15-2023, 03:19 PM | #43 | |
![]() 2529
Rep 4,765
03-15-2023, 05:03 PM | #44 | |
Rep 15,398
https://www.bmwblog.com/2022/08/23/b...-mild-hybrids/ It is difficult to remember all the press releases, but the one that does 'debut' (according to BMW) the 2nd generation system, was in the 2-series Active Tourer press release, in February 22. Integrated with 19 hp and 55 Nm of torque. Same setup followed into the X1. Keeping up with how BMW is implementing the different systems on the different platforms, is a bit of a challenge. Good to now see the integrated system being rolled out with the ZF 8-speed drivetrains. Last edited by HighlandPete; 03-15-2023 at 05:16 PM.. |
