05-01-2020, 11:42 AM | #177 |
1945
Rep 3,521
I had to access it through Google chrome. The desktop software didnt let me choose maps and stuff. It just showed that the car was connected and stuff.
05-01-2020, 01:37 PM | #178 |
Rep 320
It's simultaneous, you run the desktop client and the website at the same time.
05-02-2020, 01:29 AM | #179 |
Rep 36
OK! The new cable worked! I got the more expensive one the first time but it backfired, lol.
Anyways, first impression! - WOW! What a difference. I flashed the OTS Stage 1 93 Octane. No traction issues whatsoever. Traction light never went off and I was flooring it. I haven't played with any settings besides setting the burble aggression to 5.5 (recommend 5.6 by PTF). My car is completely stock. I don't know if I haven't driven the car enough or what, but I don't feel like the kick in the first gear. I feel it later on in like 3rd gear. What do you guys think the 0-60 and quarter mile is? Any way to track these numbers on via BM3 data log? I'm new to this tuning stuff so any advise on making adjustments is much appreciated. Can I adjust the cold start on the car? Somehow make it more aggressive? |
05-02-2020, 02:07 PM | #181 | |
1945
Rep 3,521
Also, any idea when your car was manufactured? Yup. I had th issue because my car was manufactured in 08/19 and had the newer software. Earlier 2020s had the older software and can be flashed. I also know of someone in the UK who had an older software and had BM3 installed and had taken his car in for a recall wherein they flashed the newer software and he couldn't reflash his car with BM3. He bought a JB4 instead and is happy with his car.
pneumodoc235.00 |
05-02-2020, 02:47 PM | #182 | |
Rep 424
05-02-2020, 03:40 PM | #183 | |
Rep 36
I actually wasn't aware of this being an issue until after the fact. Glad it worked for me. My car was manufactured in 09/2019. Hopefully its not an issue in the future. Another thought, the first gear pull isn't as quick as I was expecting. |
05-02-2020, 03:49 PM | #184 | ||
1945
Rep 3,521
And first gear pull being not as quick. Is that your butt Dyno saying so? Or did you use some software to get numbers? Also, any idea how much boost the BM3 map produces?
05-02-2020, 05:22 PM | #185 | |
Rep 36
I'm only speaking from my driving experience. I haven't really looked at any numbers yet. I'm new to this tuning stuff so not sure where to look. |
05-04-2020, 10:31 AM | #186 | |||
Rep 320
05-04-2020, 01:54 PM | #187 | |
1945
Rep 3,521
05-04-2020, 08:20 PM | #188 | ||
Rep 320
05-04-2020, 09:59 PM | #189 |
1945
Rep 3,521
Possibly. But he is based in Florida. Which makes it interesting.
05-08-2020, 12:09 PM | #190 |
Rep 36
0-60 and quartermile
So I was testing the 0-60 on my Stage 1 330.
I've read across the forums that the BM3 stage 1 should put 0-60 at around 4.7s. I did about 5 runs with my friend in the car running a stopwatch. The best time I got was 5.45. Traction wasn't an issue, first gear pull isn't as quick as I expected, like I mentioned in my first post, then car really takes off in 2nd/3rd. I haven't tested quarter-mile BMW claims stock: 0-60 time 5.5s and quarter-mile 14s. what do you guys think? Has anyone else tested? |
05-08-2020, 12:27 PM | #191 | |
1945
Rep 3,521
The best way would be, of course, to get a dragy box or Vbox or some official timing gear. Those are very accurate. The BMW ECU speed (not what is shown on the speedometer) is very accurate (at least in my car). The ECU speed reads 2MPH less than the speedometer reading in my car and it’s exact all the time I’ve tested it. Did you contact PTF regarding your 1st gear issue? What did they say? 5.45s is real slow for a tune. A stock car should do those times I believe.
05-08-2020, 05:52 PM | #192 | ||
Rep 320
Our cars are rated at 5.6s stock, but I believe that means 6-7s in real time, when you're just driving locally without the tires, engine and everything fully warm. I believe my car is much faster after I fully warm up my tires and engine after doing a long run on the highway, and then when I exit the highway onto local roads, the car feels much quicker and throttle is much more responsive than if I didn't warm my car up on the highway. Best timer is never a stop watch but a dragy. The next best thing is an OBDII lap timer, but that's still not as good IMO as a dragy. |
pneumodoc235.00 |
06-03-2020, 06:42 AM | #193 |
Rep 17
Hi
I am going to flash to a stage1 and now I have version 07/2019.75. OTA updates are appearing in my country to go to version 11/2019.70. If I update, will I have any problems flashing due to any anti-tuning measures? If I update after flashing, do I lose the reprogramming? Thank you! |
06-03-2020, 06:55 PM | #194 | |
1945
Rep 3,521
06-04-2020, 04:30 AM | #195 |
Rep 17
OTA updates do overwrite the DME. Before, I had loaded the 330i engine map in my 320i and when I went from the version of iDrive 03/2019 to 07/2019 via OTA, I lost it.
06-04-2020, 01:22 PM | #196 |
Rep 258
I'm looking at purchasing bootmod3 for my 2020 320i
Car was produced in Feb 2020 so I'm aware the DME will be locked. Reading about bootmod3 it seems to able to get around this for my car. One question I have is: When I take the car to the dealer for a service, I expect they'll likely reflash the ECU. Can I simply take the car home and reflash with bootmod3 to my chosen map? Or is it a one time flash? |
Dawko193.50 |
06-04-2020, 02:47 PM | #197 |
Rep 881
06-04-2020, 02:52 PM | #198 | |
Rep 881
You should be able to easily flash back to stock and again to the stg1 tune afterwards. Just keep in mind that it will still be able to be noticed by BMW should there be any warranty related issues. |
