08-03-2017, 10:59 AM | #1 |
I know a thing or 2 about a thing or 2...
3101
Rep 3,470
Drives: E36 M3 Coupe, e39 M5, i3s
Advice needed - close credit cards vs. reduce credit limits
It's taken me a few years since my divorce to pay off all my credit cards. (Freedom isn't free!). I am now in a position where I am only using my AMEX and paying that off each month. My credit score is almost at 800 which I'm pretty happy about. I need some advice on what to do with all the credit cards I have. I read that it's not good to close them all out, however, the one thing I get dinged on my credit report is the amount of credit available. So, the question is do I get rid of the cards or reduce the amount of credit on each card to it's minimum? Which is the better practice for your credit score? Thanks for the advice in advance.
2019 Imperial Blue Metallic i3s BEV
2003 Le Mans Blue e39 M5 Dinan S1 1997 Alpine White e36 M3 (the old gal) 2013 Mineral White e92 M3 (sold ) 2014 Carbon Black 650i M-sport (sold) |
08-03-2017, 11:09 AM | #2 |
Rep 1,204
More credit cards can increase your overall limit, it reduces your balance to limit ratio, which can positively effect your credit score. However having very low balances on a few cards like you do now, allows you to also have higher scores.
if those cards don't have an annual fee, you don't need to close them out. |
08-03-2017, 11:12 AM | #3 |
Rep 6,287
Closing your cards with a balance of zero on them will not affect your score.
Personally, I like to have just one card with a higher limit. I had three 300$ limit cards before and now got a 2000$ limit card and closed the others. |
08-03-2017, 11:23 AM | #4 |
3101
Rep 3,470
Ok. Two different opinions. This is what I've been getting all along!
08-03-2017, 11:25 AM | #5 | |
3101
Rep 3,470
08-03-2017, 11:26 AM | #6 |
Rep 2,957
Closing a card reduces your amount of available credit. As mentioned above if there's no fee to keep it open why close it?
2015 335i Msport/6 JB4/EWG/E30/VRSF DP/ER CP/ VRSF Race Exhaust/ Injen Intake/Verde Axis 19x8.5/9.5 245/35/275/30 Conti Extreme CS/ H&R Sports / Motorsport Hardware Stud Conversion
Lucky John616.00 |
08-03-2017, 11:34 AM | #7 |
Rep 11,843
Drives: MY24 G01 AW Msport
I would keep them open, and just check them on monthly basis for fraud.
Lucky John616.00 |
08-03-2017, 12:02 PM | #8 |
3101
Rep 3,470
Thanks. Makes sense. It was feedback I was getting on my credit score that stated I had too much open credit. My goal is to be in the high 800's.
08-03-2017, 12:32 PM | #9 |
Rep 5,728
Drives: 2019 M2 Competition
I'm not a credit expert (although my score is over 800 - brag) but i believe that having a lot of available credit is a good mark on your credit. Used/Available = lower the ratio the better. I think you're getting marked down by the number of open accounts. Now if i was you i'd keep amex and the card with the highest limit. The Amex and remaining card should probably have been open long enough to keep your "long credit history" good mark ok. Doubt that would hurt your credit. The only reason i'd do it is to avoid unnecessary fees and make things easier to manage because i doubt doing this will help your credit much.
08-03-2017, 12:58 PM | #10 |
Rep 216
Having a good amount of available credit does work in your favor, but if I'm not mistaken the age of the accounts has a larger impact. With that said, use them minimally to keep them active, and allow them to age. I wouldn't avoid taking out any more, of course, but closing will likely leave you at the same point you're at now, if not marginally better.
08-03-2017, 01:00 PM | #11 | ||
Rep 4,365
Personally I would not close a card and if I did it would be just because I was worried about keeping track of all of them and I would do the one I was most recently issued. I think you have to get WAY up there for available credit to poorly affect your score (I have ~200% of my annual income as available credit on credit cards alone and my score has not indicated anything negative from it)
2007 Z4 3.0si Coupe 6 MT Black Saphire Metallic PP SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4 2017 Harley StreetGlide Denim Black V&H Tune 2021 BMW x30i Phytonic Blue Metallic Fully loaded |
08-03-2017, 01:03 PM | #12 |
Rep 3,982
Do not close any card if it is your oldest card with history.
Try reducing your limit on a few cards first. Then look at closing any newer cards if needed. Congrats on the freedom! What is your end goal? What do you plan on doing with that high score? After a point it doesmt really matter what your score is. |
Pyrat 21417.50 |
08-03-2017, 01:34 PM | #13 |
Primo Generalissimo
4672
Rep 4,022
Drives: All of them
Garage List 2017 Porsche 911 Ca ... [10.00]
2023 BMW M2 [9.00] 2023 Porsche Macan GTS [10.00] 2022 Ford F-250 Tremor [8.50] |
I went through something similar in my divorce. Ten years later my score is 809-864. I keep all my cards but havent opened any either. I have some fairly high limits on some of them, like $50k and $30k so keep them around just in case I have a huge emergency.
Haywood3100.50 |
08-03-2017, 01:37 PM | #14 |
Rep 6,287
No. You credit history is only 15% of you fico score. And even closed cards keep contributing to your average age of accounts until 10 years is passed.
https://www.reddit.com/r/personalfinance/wiki/fico |
08-03-2017, 01:45 PM | #15 |
Rep 5,776
The way to increase your score is to have a card, use it for everything and pay off almost all the balance each month. You will pay interest each month but what increases the score is demonstrating that you can have debt and always pay on it. I learned this from a credit guy. I currently have a score of 820( have been at that or higher for ten years) and used this method for my wife and got her score to 790.
That only applies to the score and not how large a loan or credit you are qualified for.
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP Last edited by jgoens; 08-03-2017 at 02:18 PM.. |
Haywood3100.50 |
08-03-2017, 02:00 PM | #16 | |||
Rep 4,365
15% would only be 82.5 points. Having 82 points based just on the length of history is pretty significant. FICO doesn't release their proprietary formula so any % impact from any one criteria is purely a guess. There are also different scores based on what you are applying for credit wise (house, car, credit card, etc). I am also pretty sure it is closer to 5-7 years that credit accounts drop after they stop reporting to the bureaus. I think it is good you're on finance forums and whatnot, but perhaps you should pay more attention and not tell people closing cards will have no effect. Maybe if they are relatively new cards with $300 limit but some of us have $30k+ average card limits and that does have a big effect.
2016 GMC Sierra SLT Z71 Premium Plus 4x4 2017 Harley StreetGlide Denim Black V&H Tune 2021 BMW x30i Phytonic Blue Metallic Fully loaded Last edited by Hawkeye; 08-03-2017 at 02:14 PM.. |
08-03-2017, 02:04 PM | #17 | |
Rep 88
08-03-2017, 02:12 PM | #18 |
Rep 476
What do you guys do with store cards? For example I bought a pottery barn couch with their zero interest CC. I just paid it off before the year is up. What should I do? Open or close?
08-03-2017, 02:13 PM | #19 |
17980
Rep 9,377
You should give up your man-card for admitting to having a pottery barn cc
08-03-2017, 02:15 PM | #20 | |
Captain Fatbelly
1422
Rep 1,994
2013 c63 Amg coupe p31, v7 tune, plm headers, armytrix downpipes, EflexFuel
2008 dct coupe, evolve engine/dct tune, ttp, ms intake, megan exhaust, cf ds. Sold. |
08-03-2017, 02:15 PM | #21 |
Rep 5,728
08-03-2017, 02:15 PM | #22 |
Rep 4,365
Keep it open, they will close it for inactivity after a while on their own. Only reason to close a card is if it charges a fee and cannot be product changed into something without a fee.
