BIMMERPOST Universal Forums General BMW News and Cars Discussion Planning to Buy E36 for track
      05-02-2013, 02:00 PM   #1
GregSen
GregSen's Avatar
Drives: 120d
Smile Planning to Buy E36 for track
Hi there!!
So as the topic says, i'm planning to buy a E36 320i for track & occasional road use... I know the E36's chassis is one of the best but i'd like to know a little bit more about the motor and the mechanics.
Can u guys tell me if there's anything to be careful about when i'm having a test drive with the car? Is the motor know for having special diseases ???
Thanks so much for your help...
I can't wait to grow my bimmer garage
      05-02-2013, 03:01 PM   #2
MisterSkiMask
Drives: I Can not say
e36 subframe
      05-02-2013, 03:31 PM   #3
7786
Drives: 2011 535xi
Definitely check for subframe and rear shock mount tears. The coolant system is made of cheap plastic parts that will fail eventually, so keep an eye on that.
      05-03-2013, 09:51 AM   #4
MMMCOOKIES55
MMMCOOKIES55's Avatar
Drives: '17 M3 ZCP/ '16 ATS-V
Like everyone said, rear subframes are an issue, as well as the cooling system. I would recommend replacing the entire cooling system right off the bat, as well as all your bushings and checking the rear subframe. I replaced my E36 track rat with a Stewart pump and after many track events it still held up just fine.
      05-04-2013, 04:33 AM   #5
GregSen
GregSen's Avatar
Drives: 120d
thanks for the advice guys! i'll be careful about all the points you marked up!
gonna check it at tje beginning of the week! i'll keep you posted!
