Technical Topics Wheels and Tires 285 or 295 on 10" rear wheel?
      03-16-2023, 05:07 PM   #1
upstate650
upstate650's Avatar
Drives: 2014 650xi Gran Coupe Msport
2020 BMW M340xi  [0.00]
Things are warming up and my summer wheels will be arriving soon. I have a G20 m340xi lowered on Dinan springs. Rear wheel is 10x18” with 38 offset. I can go with either a 285/35 or 295/35 rear tire (front will be 255/40 on 9” wheel). I know the 285 will work, but not sure about the 295. I’d prefer to go with the 295, but worried about rubbing. Is anyone with xdrive and Dinan springs running a 295/35/18, 295/30/19, or 295/25/20 tire that can tell me whether they get any rubbing?
For clarification, concerned about tire rubbing the wheel well liner. It’s assumed you will get rubbing from your passenger with a 10” rear wheel.
2014 BMW 650xi Gran Coupe Msport Black Sapphire Metallic on full black merino leather. 20" M5 343M wheels for summer, 20" 373 wheels for winter with Nokian Hakkapeliitta 8 studded snow tires. M6 CP exhaust with M6 Diffuser and ///M Performance carbon fiber finisher. Mission Performance stage 1.5 and transmission tune.
      03-17-2023, 12:15 PM   #2
bimmerstar
bimmerstar's Avatar
Drives: 2020 BMW M340xi
i plan to run 295 on my 19x10. off set is important though. You are running max offset for poke. not sure if it will rub or not especially lowered. I am at stock height. my guess is that it will be tight.
2024 G87 Zandvoort Blue M2 w/ Buckets - Stock 93| 0-60 TBD | 1/4 TBD | 60-130 TBD
2020 G20 Tanzanite Blue II M340 xDrive - E30 BM3| 0-60 3.28 | 1/4 11.39@123 | 60-130 9.56
Past:
2017 W205 Black C43 AMG - E40 FBO No Turbo | 0-60 3.21 | 1/4 11.18@124 | 60-130 9.17
      03-17-2023, 01:51 PM   #3
upstate650
upstate650's Avatar
Not max offset. A lot of people use a 35 offset on 10” wheel, including apex. I brought it back in 3mm. But yeah, I just don’t know. You should be fine with 295 if you are running a stock height tire with stock suspension. What offset are you using?
      03-17-2023, 03:11 PM   #4
bimmerstar
bimmerstar's Avatar
i run et44 in the rear and im worried about rubbing on stock height.
Past:
      03-10-2024, 01:22 AM   #5
yos3.0t
Drives: 2020 m340i xdrive
Were you able to try the 295s in the rear ?
