04-16-2020, 05:35 AM | #23 |
Rep 448
Drives: G20 330i M Sport
It might!! I came in from the other end as per the BMW instruction. Give it a go or follow my method but release the two clips as done in the video. Its worth a try and let me know how it goes.
04-26-2020, 08:27 AM | #24 | |
Rep 207
Check with you, does your model come with ambient lighting? Do you need to recode after installing the dashboard trim for the ambient lighting?
04-28-2020, 03:22 PM | #25 |
Rep 448
I can confirm that I have ambient lighting and that the central trim requires no coding. Did you manage to get the gear trim off in the end and how did you do it?
05-05-2020, 09:04 AM | #26 |
Rep 207
05-08-2020, 02:12 AM | #27 |
Rep 448
Sorry but I cant help you further. I did manage to remove mine without any damage so keep trying and it will come off !!
06-19-2020, 12:11 PM | #28 | |
Rep 22
I just had mine installed today and have found out that half of the ambient lighting strip is weaker illuminated than the other half. Told the dealer, they removed it to check the fiber or any bad contacts, but everything turned out ok. However, half of my ambient lighting strip is still weaker than the other half and it’s driving me crazy. The dealer said they took photos and will write BMW, but if you could, could you also attach photos of your dashboard with the ambient lighting on to see if it’s a common situation? Thanks |
06-20-2020, 12:22 AM | #29 |
Rep 22
06-20-2020, 01:12 AM | #31 |
Rep 448
I see what you mean. I will check this evening and take photos
06-20-2020, 05:39 AM | #32 |
Rep 3,948
What's going on with your AC vent? It doesn't look like they installed it properly.
06-20-2020, 06:49 AM | #33 |
Rep 22
Looking at it now and other photos of the original, yeah I see it. Anyway, I’m either looking to have a new part installed to repair that shitty ambient half-lighting or the original back. I’ll ride their asses about the ac vent too, thanks for noticing
06-20-2020, 08:29 AM | #34 |
Rep 3,948
It could be why your ambient light strip looks like that (if they didn't install the trim piece on that side properly it could be block a little bit of the led strip making it look more dim).
06-20-2020, 09:42 AM | #35 |
Rep 22
Most definitely not, as it’s only there on the a/c vent that’s sticking out a bit, not lowered. It’s definitely a light problem. Anyway, it was installed properly in the beginning and when I noticed the problem, I went back to the dealer in a hurry, but it was the end of the schedule, they tested it, didn’t see a fault in the wiring, and what they did was probably hurry to install it back to get home quicker and made a mess of the vent part. But the problem was definitely there before that “bad reinstall”. Anyway, still nice catch and first thing on Monday, I’ll be giving them a call.
Burrcold5277.50 |
06-21-2020, 04:40 AM | #36 |
Rep 22
06-21-2020, 03:40 PM | #37 |
Rep 448
Hi. There is defiantly a point where there is a colour change however my trims lighting is not as bad as yours. See what you think!!
06-21-2020, 04:27 PM | #38 |
Rep 22
Thanks a bunch. I’ll show them your photos and try and coerce them to order a new part. It doesn’t make any sense that the original was perfect and now the M-Performance trim has this ambient light issue. I mean it’s supposed to be an improvement, not a downgrade...
06-22-2020, 10:20 AM | #39 |
Rep 448
Also phoned my local dealer who have asked for the above photos so will see what they think
06-24-2020, 08:51 AM | #40 |
Rep 22
Please let me know if they offer any valuable info in the matter. I’m not in the UK, but I’d guess that my dealer could see it as a precedent if your guys manage to solve the problem. Thanks
06-26-2020, 01:42 AM | #41 |
Rep 448
I had a call from my local BMW dealer yesterday and they have asked me to take my car in. They have acknowledged that the photo's indicate a problem and will do whatever is required to fix it including replacing the trim under warranty
06-26-2020, 04:25 AM | #42 |
Rep 22
Apparently, my dealer ordered one already since I showed them the problem as well. Anyway, it’s weird that 2 separate parts have the same issue and I don’t recall any original trims of any G20s having that same problem...I’m hoping it’s not gonna be a thing related to the build process and all M trims being like this. If that’s gonna be the case I’m gonna switch back to the default hexagon stuff...shame.
07-09-2020, 02:38 PM | #43 |
Rep 448
Have you had the replacement trim fitted yet?
07-09-2020, 02:54 PM | #44 |
1942
Rep 3,521
I have a tiny bright spot too like Xsapper has. But it’s just that one spot. The rest of it has the same brightness.
