Technical Topics DIYs and Coding Discussions Coding Sport+ On G20 w/ Bimmercode
      06-24-2020, 06:19 AM   #177
BlackG20E
Drives: BMW 330E G20
Just coded sport + on my 330E and I don't have the upshift farts. Does anyone know how to fix it? That would be awesome!
      07-07-2020, 06:41 AM   #178
relaq
Drives: BMW
Hey all
Due to the fact it's my first post here and cannot make new topic I will post it here.
Can you code sport mode to 1 series F40? G20 forums is way more advanced in every aspect compering to the one about 1 series. Are g20 and f40 systems the same?
      07-07-2020, 03:52 PM   #179
VipinLJ
VipinLJ's Avatar
Originally Posted by relaq View Post
Hey all
It should be the same since I believe it has the latest iDrive version?
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      07-09-2020, 12:56 PM   #180
Headwreck9
Drives: G20 320D Xdrive
Hi Guys, just joined to say thanks for all the info, finally coded Sport+ and also for it to show on iDrive. The difference between Sport and Sport+ is very noticeable, better throttle response and more aggressive on gear changes.
Glad I was able to code this in as I was a little disappointed in the way the car drove in standard sport mode, this is my first BMW, now it feels like a car that is fun to drive.
I would like to add if you’re driving in Sport+ mode then I wouldn’t recommend switching the shifter left to sports gearbox, to me it felt as though it lost the throttle response and sportiness, just stick with the Sport+ mode put your foot down and have fun, of course still driving safe and obeying all driving and traffic laws ��
      07-10-2020, 02:26 AM   #181
330e
330e's Avatar
Drives: G20
Could u make a photo of settings in bimmercode/esys?
I cant run this is my g20 330e :-/
Or maybe photo of idrive with all sport modes?
      07-26-2020, 07:53 AM   #182
AlexxZeman
AlexxZeman's Avatar
Germany
23
Drives: BMW G20 320iX
Thank you all for the info. Finally I was able to code sport+ and comfort+. At first I did it with M skin for live cockpit and without edits to iDrive and was shocked that didn't worked, but once I rolled everything back I saw in default skin all modes and than found how to bring them to iDrive.
Now I stuck because of modes visibility to default skin, though I'd love to keep M one. Any ideas how to get drive modes onto? Also if there would be a possibility to lower max speed and rpms of engine that would be super cool. Red line from 7000-6500 make more sens here ))
      07-26-2020, 10:46 AM   #183
rlaffey
Drives: 2020 G20 330e mSport+
Does it make much of a difference in the drive vs. Sport mode?
      07-26-2020, 11:04 AM   #184
VipinLJ
VipinLJ's Avatar
With the M cluster, there is no notification on the live cockpit telling us which mode the car is in. Only difference is that, in sport vs comfort, there are two small red lines or curves near the bottom of the tacho and speedometer. It's present in one mode but goes away in the other. It's near the 0-1k rpms and 0-20mph mark near where the needles should be.
      07-26-2020, 02:49 PM   #185
AlexxZeman
AlexxZeman's Avatar
Germany
23
Got it. And that's kinda sad ))
Went back to default one, coded to start in "Sport individual" with comfort presets, so I can start slowly with additional M-badge on top ))
Still wonder if there is an option to add M-cockpit font into default skin? has anybody tried to do that?
      07-27-2020, 11:18 AM   #186
3some!
Germany
15
Drives: BMW G82, BMW G21, BMW E91
You can get the text font in M-Style at DKOMBI4 with AG_MPA_MSP_VIEW --> "mpa_ansicht_260_skala"
      07-27-2020, 11:48 AM   #187
Bluebrain
Bluebrain's Avatar
Austria
Drives: BMW E63 645Ci, BMW F45 218i
Is the Sport+ mode even available on the M340i by factory?
FYI, if you did not know so far:
the latest update of Bimmercode added support for ENET cable on Android devices. (you will need an USB OTG Ethernet adapter)
Coding via Ethernet/ENET is way much faster, than Bluetooth. (really, really faster!)
      07-27-2020, 03:00 PM   #188
AlexxZeman
AlexxZeman's Avatar
Germany
23
Thanks will try first thing tomorrow
      07-31-2020, 07:03 AM   #189
Pwong88888
Drives: 328i
Originally Posted by g20beam View Post
Because you coded off fes_aktiv instead you chose m_aktiv (or something like that) in M_DRIVE, that’s why comfort/sport/sport+ won’t work anymore on centre control. You have to switch it back or restore to an older backup for it to work again. Also don’t code in M menu (that goes for anyone attempting to do this right now unless they seriously know what they’re doing) right now, it’s not stable as it is. I’m just putting those codes out there for the people that are interested in finding a solution.
Hi g20beam, would you mind to help me out code in the sport plus mode to my 330i? I guess we live in the same area in Markham, cause I saw your car pass by my house few times.
      07-31-2020, 10:37 AM   #190
VipinLJ
VipinLJ's Avatar
I think he’s more active on IG. How does his car sound?
      07-31-2020, 03:28 PM   #191
Pwong88888
Drives: 328i
His car sounds great, thats why I notice is different from mine.
Let me try to look for hime at ig.
      08-07-2020, 02:24 AM   #192
Joedeejay
Drives: BMW G20
For anyone without coding options at the moment, you can get sport plus on a different way. It certainly worked this way in my M235i auto and gave more exhaust noises. Changed transmission and engine response ever so slightly.
Put car into sport, and push the gear knob to the side into "manual sport". As long as you don't push up/down on paddles or the gear knob it will still stay automatic, even in 'manual' mode. Enjoy
      08-07-2020, 06:48 AM   #193
Bluebrain
Bluebrain's Avatar
Austria
That's nothing new and even my 1997 5 Series E39 had this.
I also doubt that this switches the driving mode to Sport Plus, but instead in normal Sport mode.
      08-07-2020, 10:09 AM   #194
Joedeejay
Drives: BMW G20
Well having driven in Sport and gearbox in Manual Sport, and then in Sport Plus and normal auto car felt identical. Looking in the coding options too Sport Plus only has adjustments to the Transmission and Engine. Nothing for suspension or steering. My F22 sport plus would change the dsc as well but it doesn't seem to do that on the G20
      08-09-2020, 07:39 PM   #195
scotes
Just seeing this post and not wanting to read through 9 pages I just wanted to add that if you can add Sport+ through coding just do it!
I went full boat on my M340i order so I have Sport+ from the factory but didn't realize it was there till a few months into having the car and when I did it was holy sh!t! I would usually keep the car in Sport and have some fun with the paddles when the road would encourage it but in Sport+ the throttle response was just a bit quicker but even better the gear changing was just spot on. Up, down, and holds were better than I could even plan and I ended up stopping using the paddles and just let the computer take over it was that good. Seriously. I'm still stunned as to how well the transmission works in Sport+.
      08-09-2020, 09:05 PM   #196
Bluebrain
Bluebrain's Avatar
Austria
Still waiting for my M440i to be delivered. (~Oct.)
scotes, does your M340i also have the "Comfort Plus" mode by factory?
      08-22-2020, 10:23 AM   #197
chris_portimaog20
Drives: 2019 Bmw 330xi
very true, takes me seconds to code with my OBD2 cable
      08-22-2020, 10:31 AM   #198
Bluebrain
Bluebrain's Avatar
Austria
No, I mean in comparison to the Bluetooth adapter which takes several minutes instead of seconds.
