Technical Topics DIYs and Coding Discussions added wireless charging tray and coding for phone reminder
      03-26-2020, 11:10 AM   #1
greekcs
greekcs's Avatar
Drives: 2020 M340i xDrive
This was a relatively easy install. The hardest part was unplugging the USB and 12V socket connectors to remove the cupholder. It works just as advertised and even reminds you (with some coding) if you've left the phone in the cradle.
Total cost: $120 Shipped from EU
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD
2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive
Appreciate 6
      03-26-2020, 11:25 AM   #2
possible335i2008
Drives: 335i
Do you have the part numbers?
      03-26-2020, 11:30 AM   #3
greekcs
greekcs's Avatar
Part number: 84109434000
Installation instructions:
https://www.newtis.info/tisv2/a/en/g...one/1Vndu0qEK0
To add the phone reminder, add 6NW to FA and code MGU and KOMBI. I believe this option also adds enhanced BT.
Appreciate 9
pneumodoc235.00
VipinLJ1949.00
hamera441.50
37b86.00
E__F6.00
      03-26-2020, 01:06 PM   #4
pneumodoc
pneumodoc's Avatar
235
Drives: G20, G01
assuming this is with Esys, not bimmercode? Great write up, by the way.
      03-26-2020, 05:17 PM   #5
jcrosa
Brazil
13
Drives: BMW X5 45e M Sport 2022
Did you buy it from BMW?
      03-26-2020, 06:25 PM   #6
greekcs
greekcs's Avatar
I purchased second hand from a salvage vehicle.
jcrosa12.50
      03-31-2020, 12:36 PM   #7
NorrisContender
NorrisContender's Avatar
Drives: 2001 3.0 Z3, 2019 330i
Sorry folks I'm a total rookie at this stuff.
If I have the NFC mat in my 330 and want to swap to the wireless charging mat, is the new mat the only part I need to purchase?
Then just follow the steps greekcs outlined above?
Thanks for the info.
      04-02-2020, 09:13 AM   #8
hottroc
Drives: BMW 330e
So was the wiring in place to retrofit this? Or did you have to tap into wiring somehow?
      04-02-2020, 12:34 PM   #9
greekcs
greekcs's Avatar
No tapping required. The wiring is already in place. You just unplug the NFC pad and replace it with the Wireless Charger.
      04-02-2020, 03:10 PM   #10
pneumodoc
pneumodoc's Avatar
235
Drives: G20, G01
How did you code it? And did you try using your NFC cardkey after to make sure that still works?
Thanks!
      04-03-2020, 05:16 AM   #11
hottroc
Drives: BMW 330e
Thanks for your reply but don't think I have an NFC pad (?), think it's just a plastic tray. Would the wiring still be there do you think?
Is it sort of just tucked away nearby ready for the wireless charger pad?
When I look at a second hand tray on ebay it looks like there is a connector and an aerial socket. Does that make sense?
      04-03-2020, 09:45 AM   #12
NorrisContender
Do you have an iPhone? I'm wondering if the wireless charging tray still has the issue the NFC tray has where it's constantly triggering the wallet app.
      04-05-2020, 04:54 PM   #13
Fpangalos
Fpangalos's Avatar
Drives: 2019 BMW 330i
Thanks for figuring this out!!! Can you add a little color to the coding process once swapped out? Can it be done in bimmercode? Thanks for your help!
      04-08-2020, 10:08 AM   #14
Fpangalos
Fpangalos's Avatar
Bueller!
Bueller!!
I will play around in bimmercode and if I can figure out what is needed apart from what Greeks provided once this is installed I will share.
Thanks again for testing this, I just ordered one!
      04-08-2020, 10:32 AM   #15
NorrisContender
Originally Posted by Fpangalos View Post
Bueller!
Bueller!!
Where do you order from? Everywhere I find one it says it's discontinued and no longer available.
      04-08-2020, 10:35 AM   #16
Fpangalos
Fpangalos's Avatar
Bueller!
Bueller!!
I just ordered one off eBay for about $130 usd.. there are some listed for $300 but looking at sold listings they pop up occasionally and sell for around $100.
Trouble your having is Greeks listed the incorrect part number. He listed the part for the wireless/lte system sku number. This specific part number is 84109437712
      04-08-2020, 10:37 AM   #17
Fpangalos
Fpangalos's Avatar
Bueller!
Bueller!!
Here's one for $150 or best offer. Good luck!
https://www.ebay.com/itm/123980961861
      04-08-2020, 11:59 AM   #18
minakoto00
minakoto00's Avatar
Drives: G20 330i xDrive Luxury Line
Thumbs up
Thanks for the link! Can you give an update here once you've done the installation? My car doesn't come w/ wireless charging and I regretted not adding this option instantly upon driving a loaner car that is equipped with it.
      04-08-2020, 12:01 PM   #19
Fpangalos
Fpangalos's Avatar
Will do! I'm in the same boat. May be a few weeks, mine is coming from Australia
      04-08-2020, 12:02 PM   #20
Fpangalos
Fpangalos's Avatar
Also found these in the meantime on disassembly
zanicwb12.00
      04-08-2020, 12:23 PM   #21
greekcs
greekcs's Avatar
I have the most up to date version according to bimmercat. But it shows up as being discontinued when I search.
hamera441.50
      04-09-2020, 02:48 AM   #22
hottroc
Drives: BMW 330e
Wonder what the difference is between those part numbers? Is there any way to find out? And also if they're interchangeable?
