06-25-2020, 07:41 PM | #89 | |
1937
Rep 3,520
Edit - What she looks like now. I'm contemplating switching the red and blue (red strips and blue handle and door storage lights). Or maybe just replace the green and white with the red and blue alternative. Sorry for the non-central steering wheel. Should've thought of that before I took the pic.
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige Last edited by VipinLJ; 06-25-2020 at 11:02 PM.. |
06-26-2020, 12:07 AM | #90 | |
Rep 398
Am I right in saying that your white colour is now red everywhere? So if you select blue/white in I drive you’d get all blue? Cheers |
06-26-2020, 12:56 AM | #91 | |
1937
Rep 3,520
With that coding, you get blue where it was originally white (ONLY when you choose bronze and white; it remains white in the other options such as orange and white, green and white, blue and white etc) and red where it was originally bronze. When you choose only bronze, all the lights turn red. Basically, the photo I posted of my car in my previous post. Hope that helps.
dragoon41581.50 Mmilani11.50 |
06-26-2020, 02:54 AM | #92 | |
Rep 36
Amazing! Could you provide to us step by step what you do via bimmercode expert. I think it will be much easier for us and other colleagues on our forum to understand and add this position to coding directory. As I noticed , did you add custom value, because on iOS I couldn’t edit profiles like g05g20 etc via bimmercode |
06-26-2020, 03:13 AM | #93 | |
1937
Rep 3,520
When you open 360A, you’ll see two sub modules. Choose the second one and scroll down to the one that is already selected (I forgot the name but it’s already selected). There, choose custom value at the bottom and it’ll take you to the screenshot I posted showing 150 different bytes. Refer to my previous post for the changes I made. Similarly, go to 360D lcilci......., choose the second option there, scroll down to the preselected option and choose custom value there too. It’s 3am here and I’m not near my car or my phone. I forgot the exact names but I can check later in the morning if you need me to.
06-26-2020, 03:25 AM | #94 |
Rep 243
06-26-2020, 03:28 AM | #95 |
Rep 243
That looks amazing mate! I might do the same.
It's a shame you can't ADD more colours though so you could for example keep the bronze and have blue/red. Has anyone actually tried just adding more values into the werte list instead of just replacing them? |
06-26-2020, 03:51 AM | #96 | |
Rep 398
I'm planning on replacing the blue in 360A with a lighter blue so fingers crossed this works too! |
VipinLJ1936.50 |
06-26-2020, 04:19 AM | #97 | |
Rep 36
the same path is on 360D section? |
VipinLJ1936.50 |
06-26-2020, 06:16 AM | #98 |
Rep 156
I have the HK with no lights in the speakers.
06-26-2020, 08:58 AM | #99 |
Rep 398
06-26-2020, 09:03 AM | #100 | |
Rep 398
I replaced Bronze/White with a new blue and red - these are the shades from the M logo Will try and take a pic later tonight! Would be cool if we could add new colours, I daren't try and add new values in case I end up bricking my ECU in some way. I figure though even if you can add the values in there, I'm sure they'll be other areas/values to change elsewhere in order to get them to show up in the iDrive menu. Also the screens/images in the iDrive of each colour profile are likely hardcoded and would have to be manually updated so doubt it's possible although would be very cool if it was possible! Pity btw didn't add a 'create your own' option where you can specify 1 or 2 colours, I don't think it would have been that difficult. |
06-26-2020, 11:08 AM | #101 | ||
Rep 59
Make a video for everyone. It will be worth it. Screen record it. |
VipinLJ1936.50 |
06-26-2020, 03:18 PM | #102 |
1937
Rep 3,520
hottroc - I believe I'm wrong regarding the HK system having lights behind the speaker grills. In some countries, I believe the 3 series has an optional B&W system which is better than the HK system? He probably has that? Or it could be aftermarket covers like in the link below.
https://www.incarpassion.com/bmw-3-s...ambient-light/ Regarding adding more colors. Even if it might be possible in 360A since there are lots of unused bytes, when we go into 360D which is what shows up on the idrive, there are only 22 bytes, all of which are used. We can't add extra bytes there. Again, I could be wrong since I'm no expert whatsoever. sharepointalex - I thought of replacing the blue with a lighter blue too. But my wife likes the dark blue and I left as is. I also replaces the green and white option with a blue and red option (pic below). Basically I inverted the options I had for bronze and white. sztmek - You don't need to retype all the values. When you click custom values, it shows all the original values there. You just replace the values of the color you don't want with the new values and save it. It automatically gets saved as a whole new setting under 360A and 360D. The original values stays there under g20g28...... Swagasaurus-R3X - I have no idea why I didn't think of screen recording it. I should have done it before making changes. Reason being, once you make a change, the original selection under 360A and 360D changes to a new one called unassigned values with the new values I've added. But I'll try and do it again and screen record it.
Swagasaurus-R3X44.50 |
06-26-2020, 04:17 PM | #103 |
1937
Rep 3,520
I'll do a write up since it'll be a bit before I can make a video.
1. Changing the actual color for the ambient lighting (White, bronze, orange, blue, green, lilac) BDC module > Expert coding > 360A LicLciColorLibrary > LIC_LCI_COLOR_LIBRARY_DATA > G20G21G26G28G80_Lichtpaket_code1 (selected option) > Custom value Byte 0 to byte 151 present, screenshots of which can be found here. Original RGB hex codes are: 90,E0,90 - WHITE D7,6E,14 - BRONZE 93,1A,01 - ORANGE 00,20FE - BLUE 10,FE,32 - GREEN 78,3C,FE - LILAC Any of these colors can be changed. As a result, that color will be removed completely and replaced with the new color you code. The only change I made there was to the default bronze (D7, 6E, 14) at bytes 18,19,20, 23,24,25, 28,29,30 to red (FF, 00, 00). When you click save and then code it, all 151 bytes get saved as a new unassigned value which is the new selected option. I have no bronze color in my ambient light anymore. All the other colors are present along with the newly coded red color. 2. Ambient light option in iDrive BDC module > Expert coding > 360D LicLciColorProfiles > LIC_LCI_COLOR_PROFILES_DATA > G20G21G26G28G80_Lichtpaket_code1 (selected option) > Custom value Byte 0 to byte 21 present, screenshots of which can be found here. Original values are: 00 - white 01 - bronze 02 - orange 03 - blue 04 - green 05 - lilac In my car, bronze has been replaced with red. So 01 becomes red instead. Also, I've replaced bronze and white with red and blue (byte 2 left as is and byte 3 changed to 03 from 00) AND green and white with blue and red (byte 16 changed to 03 from 04 and byte 17 changed to 01 from 00). When you click save and then code it, all 21 bytes get saved as a new unassigned value which is the new selected option. A screen recording of the locations of the two options can be found in the link below. It's not extensive. Just so you can get an idea. In the options in the video above: A. Under LIC_LCI_COLOR_LIBRARY_DATA (360A): 1. Original hex values: Byte 18 - D7 Byte 19 - 6E Byte 20 - 14 Byte 23 - D7 Byte 24 - 6E Byte 25 - 14 Byte 28 - D7 Byte 29 - 6E Byte 30 - 14 2. New hex values: Byte 18 - FF Byte 19 - 00 Byte 20 - 00 Byte 23 - FF Byte 24 - 00 Byte 25 - 00 Byte 28 - FF Byte 29 - 00 Byte 30 - 00 B. Under LIC_LCI_COLOR_PROFILES_DATA (360D): 1. Original hex values: Byte 2 - 01 Byte 3 - 00 Byte 16 - 04 Byte 17 - 00 New hex values: Byte 2 - 01 Byte 3 - 03 Byte 16 - 03 Byte 17 - 01
2020 BMW 330i xDrive 2018 Audi SQ5 Prestige 2017 Audi A7 Prestige Last edited by VipinLJ; 07-18-2020 at 01:01 PM.. |
10
murderedg2089.00 Rednose_M340i66.50 fkyang20.00 130FeetDeep274.50 andy546888.00 Silver.Solid116.00 bimmerelectric14.50 Cinco156.00 540iSUP703.00 CyclingBroStyle232.00 |
06-26-2020, 09:39 PM | #105 |
Rep 156
Thanks VipinLJ
VipinLJ1936.50 Rednose_M340i66.50 |
06-26-2020, 09:58 PM | #106 |
1937
Rep 3,520
You're welcome. I love the look! Makes the cabin livelier at night, at least for me.
06-27-2020, 10:31 AM | #107 |
Rep 36
Hi mates!
I also coded successfully red and blue color. It’s possible to increase the brightness of ambient lights of doors and bottoms led? I scroll to full in indrive but I think it is medium level of brightness compare to main cockpit main line. I looked for something in expert mode and I found rgb brightness control. There are few byte 14-15 with FF and the byte 1,2,3,4 have some other values maybe I have to type also FF to increase light ? What do you think? |
06-28-2020, 01:53 PM | #108 |
Rep 1,037
I coded the red/blue and it looks awesome. Does anyone know what values to change to replace white with a warmer white?
06-28-2020, 02:10 PM | #109 |
Rep 219
Anyone know if it's possible to make the lights for the AC and radio controls white instead of orange?
'20 Portimao Blue M340i – Current '17 Dark Graphite 530i – Retired '14 Alpine White 328i – Retired |
06-28-2020, 02:33 PM | #110 | |
1937
Rep 3,520
That might be possible but not sure. I only know that it works depending on if the headlights are on or off. 😬 But it might be possible to code it to stay white or orange all the time?
