Technical Topics DIYs and Coding Discussions Coding More Ambient Colors And Amber Sidemarker Delete?
      08-05-2020, 09:34 AM   #177
VipinLJ
VipinLJ's Avatar
Originally Posted by Joedeejay View Post
Well I've run into an issue. When I go into expert mode on bimmercode and into 360A / 360D there is nothing in there. Blank page "No results".
That's weird. Did you update the app? Mine did that once a while back but all I needed to do was close bimmercode and then reopen it. It worked fine after.
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      08-05-2020, 09:36 AM   #178
Joedeejay
Drives: BMW G20
Running latest version of the app ye, think it updated itself last night. Tried opening and closing etc. Just blank still. I've emailed him see what reply comes back. Gutted hah
      08-05-2020, 09:41 AM   #179
VipinLJ
VipinLJ's Avatar
Yes there was an update yesterday for bug fixes according to google play. But I did the coding after the update. Hopefully it fixes itself. Usually a disconnect and reconnect is all that is needed. Keep us updated.
      08-05-2020, 09:57 AM   #180
Joedeejay
Drives: BMW G20
Uninstall and reinstalling also done nothing. Hope it's not to do with being on 07/2020 software too
      08-05-2020, 03:04 PM   #181
andy5468
andy5468's Avatar
88
Drives: BMW G20 M340D LCI
I had some free time today to try and "decode" the three sets of hex values under 360A.
In my car, bronze has been changed to red. Bronze and white is red map spotlights/door handle & pocket lights/footwell lights and blue dash/door strips. Now the issue we had was, when the ambient light is set to the bronze white (red blue) option on the idrive, the map lights wouldn't turn on until we switched it to another color and back again. The work-around I found was to reduce the intensity of the red by a notch so that the map lights turn on as well. While it wasn't very obvious, there was a slight pinkish hue to the red and it was bothering me a wee bit (though it didn’t bother me initially). I wanted it to be pure red.
andy5468 and Joedeejay gave me an idea. Since coding became significantly faster with a wired enet cable and USB c adapter (I wouldn't have done it if I was using obdlink), I thought I'd try and decode the values. I decided to replace bytes 18,19,20, 23,24,25, 28,29,30 individually with 90,E0,90 to see which lights turned white and which stayed red.
My findings:
1. Bytes 18,19,20 - door handle and door pocket lights
2. Bytes 23,24,25 - Footwell lights
3. Bytes 28,29,30 - Map lights front and rear (small spot lights next to the dome lights)
So I replaced bytes 18,19,20 and 23,24,25 with FF,00,00 and left bytes 28,29,30 as is (FE,0A,0A). Result is pure red lights in easily visible areas (door handles, pockets, footwell) and a map light that always turns on (though with a slight pinkish hue noticeable only to me and not the others in the car since they aren't crazy like me).
Managed to get this coded tonight. Worked a treat. just did bytes 28,29,30 as recommended with the new FE,0A,0A and this fixed the issue for me too. Nice one.
VipinLJ1936.50
      08-06-2020, 01:44 AM   #182
Joedeejay
Drives: BMW G20
Got a reply which is odd. Are you guys able to access them on latest bimmercode on Android?
"Hi,
the mapping for these groups is not available yet. This is something we are working on, but at the moment I can not tell when this will be available, sorry."
Edit just got another reply. Its a problem with latest bmw software 07/2020. Damn you android auto
      08-06-2020, 01:54 AM   #183
VipinLJ
VipinLJ's Avatar
"Hi,
Mine got an update on the 3rd (3 days ago). I did the coding on the 4th. No updates after that. Bimmercode for Android, version 2.26.2-6781 (beta tester).
      08-06-2020, 02:33 AM   #184
Joedeejay
Drives: BMW G20
Unfortunately its the cars software that's at fault! 07/2020 latest version. Said a fix is in the pipeline but no idea when.
      08-08-2020, 10:08 AM   #185
mmo011
Drives: BMW 320d MSport (G20)
Anybody tested to code the real M Color Scheme instead using pure colors like RED #FF0000?
here below the HEX for the right colors:
https://www.schemecolor.com/bmw-m.php
Name: Light Sky Blue
Hex: #81C4FF
Hex: #16588E
Hex: #E7222E
      08-08-2020, 12:56 PM   #186
VipinLJ
VipinLJ's Avatar
Hex: #81C4FF
Hex: #16588E
Hex: #E7222E
I tried using E7222E before I used FE0A0A and it looked like a pink. Definitely didn't look like red. Which was why I searched for something closer to red and got FE0A0A.
      08-10-2020, 02:35 PM   #187
hkleyman
hkleyman's Avatar
Drives: 2019 BMW X5 50i M-Sport
In my car, bronze has been changed to red. Bronze and white is red map spotlights/door handle & pocket lights/footwell lights and blue dash/door strips. Now the issue we had was, when the ambient light is set to the bronze white (red blue) option on the idrive, the map lights wouldn't turn on until we switched it to another color and back again. The work-around I found was to reduce the intensity of the red by a notch so that the map lights turn on as well. While it wasn't very obvious, there was a slight pinkish hue to the red and it was bothering me a wee bit (though it didn't bother me initially). I wanted it to be pure red.
My findings:
Nice catch. I can confirm that ANY of the three colors (RGB) set to FF with all 0000 in the other bytes results in the built in ambient lighting on the roof function module not working until switching colors.
I was able to replicate the issue with 00FF00 and 0000FF for the other solid / non mixed colors.
VipinLJ1936.50
      08-10-2020, 04:46 PM   #188
hkleyman
hkleyman's Avatar
My findings:
Strange bug since red / green / blue look better at the full value. I have this issue on most of my presets as I changed base colors to full values across the board.
      08-29-2020, 09:01 PM   #189
tturbolife
tturbolife's Avatar
Drives: None
2020 BMW M340i  [0.00]
Thanks for the values to fix the overhead LED issue. I replaced green with red and green/white with green/blue.
360A:
Red/Blue:
Default Green (10,FE,32) at bytes:
63,64,65 -> FF,00,00
68,69,70 -> FF, 00, 00
73,74,75 -> FE, 0A, 0A
360D:
Red/Blue:
Byte 17: 00 —> 03
(This changes the white (00) in Green/White to Blue (03))
      09-01-2020, 01:51 PM   #190
dominguez255
Drives: BMW Serie 1 F40
Two issues:
1- Is it possible to change the name and color that appears on the idrive display? bronze to red, the real ambient color has already changed and it works.
2- Is it possible to turn on the underfoot light that comes on when the doors are opened, using coding?
      09-01-2020, 07:00 PM   #191
VipinLJ
VipinLJ's Avatar
Originally Posted by dominguez255 View Post
Two issues:
1. So far no one has been able to figure out how to change the color names on the idrive in any of the cars (3 series, X3, X5 etc).
2. Which underfoot lighting? Do you mean the light in the footwells?
      09-02-2020, 03:39 AM   #192
dominguez255
Yes the light in the footwells
      09-02-2020, 08:45 AM   #193
VipinLJ
VipinLJ's Avatar
Are they not on for you? In my car, when the ambient lights are on, the footwell lights are also on, in the corresponding color. When I open a door, the footwell light turns to white.
I think that’s how it is supposed to work?
      09-02-2020, 12:24 PM   #194
dominguez255
The problem is that my car is 118i F40 not G20, but i think that we can coding this option, all is code in this cars.
      09-22-2020, 04:40 AM   #195
takky
takky's Avatar
Thailand
18
Drives: 330e 2020 -->> m340i Lci 2023
Mine was the same, after my car was updated software to 07/2020.48
      09-28-2020, 11:22 PM   #196
tturbolife
tturbolife's Avatar
Drives: None
Same... I hope BMW didn't lock us out
      09-29-2020, 11:26 AM   #197
VipinLJ
VipinLJ's Avatar
I'm on 07.2019.38 and I used bimmercode yesterday. I could access all modules without any issues.
      10-01-2020, 04:30 AM   #198
Joedeejay
Drives: BMW G20
The issue is with 07.2020 software mate, you are on last July 2019 which is fine
From Bimmercode
The Android version will receive an update as soon as the mapping is available.
Kind regards / Schöne Grüße
Stephan Gauch
VipinLJ1936.50
