Technical Topics DIYs and Coding Discussions Turn headlights fully off while car running
      04-06-2020, 07:43 PM   #1
Preciseyyc
Preciseyyc's Avatar
Drives: F15 35i G20 m340
Has anyone figured out a way to code the lights to he able to be fully turned off when engine is running?
Drives me insane to have exterior lights on if I'm just sitting parked somewhere with engine running for heater, was able to do to this with DRL option in my last 5 cars.
      04-07-2020, 02:38 AM   #2
Kokosnoot
Drives: G21
Hi,
You can code the MGU menu to have the option to tick the DRL’s to off. Unfortunately this will only work during daytime as the function “auto” on your light switch panel will remain on and as soon as it gets darker your drl’s + low beams will switch on.
      04-07-2020, 09:24 AM   #3
Preciseyyc
Preciseyyc's Avatar
Originally Posted by Kokosnoot View Post
Hi,
Yes this is what I did. Hoping for more.
      04-07-2020, 05:31 PM   #4
TTG
TTG's Avatar
Drives: M340
I HATE HATE HATE Auto headlights. They are designed for idiots who go around without their headlights on.
I would love to be able to code them off.
      04-07-2020, 06:55 PM   #5
IndotagSwizz
IndotagSwizz's Avatar
525
Drives: F30 320i
Are you serious??? Lol turn your headlight off by pressing the off switch and then go to i drive, car, settings, exterior lighting, daylight off... that simple 0 coding needed I do it all the time
Edit: sorry was using the app and didn't see you are in another country, your set up might be different and you might not have that option
      04-08-2020, 01:21 AM   #6
Preciseyyc
Preciseyyc's Avatar
When my car is running at night the headlights are on. I can do parking light but can't go full blackout . But I even have the daytime running light option to turn them coded, and at night the lights still come on.
When I press off the car says lights not off while engine running or some dumb bs.
      04-08-2020, 10:43 AM   #7
TTG
TTG's Avatar
Drives: M340
That must be a Canadian thing (You guys have slightly different DRL laws up there). In the US spec car, when you push the off button, lights will completely go off.
Did you try switching the auto light function in bimmercode? Our is set to zero, I bet you anything, yours is set to 1.
      04-08-2020, 10:45 AM   #8
Preciseyyc
Preciseyyc's Avatar
No I haven't.
Do you happen to know the code line ?
That's good info tho. Thanks
      04-08-2020, 11:57 AM   #9
TTG
TTG's Avatar
Drives: M340
No I haven't.
Its under BDC module and look for auto-headlights. (you don't need to go to expert mode)
It gives you an option:
Auto headlights in position 0
Auto headlights in position 1
US cars are set to 0, see what yours is set to.
Back in the day, I imported a Volvo from Canada and had this very same problem. Couldn't turn off the headlights. That one just required a US spec headlight switch (before coding days )
Poochie9104.50
      04-08-2020, 12:07 PM   #10
Preciseyyc
Preciseyyc's Avatar
No I haven't.
Stupid Canada lol
greekcs773.00
      04-08-2020, 03:46 PM   #11
TTG
TTG's Avatar
Drives: M340
Stupid Canada lol
Exactly what I was talking about! Did that work?
      04-08-2020, 03:52 PM   #12
Preciseyyc
Preciseyyc's Avatar
Stupid Canada lol
Yours shows the same way?
It came set as A
      04-09-2020, 10:02 AM   #13
TTG
TTG's Avatar
Drives: M340
It came set as A
Sorry, just saw this. Yes, mine is on A.
      04-09-2020, 10:06 AM   #14
Preciseyyc
Preciseyyc's Avatar
It came set as A
Weird, doesn't change anything for me.
Still says lights not off while engine running or some bs.
Must be something different in expert.
      04-09-2020, 11:10 AM   #15
TTG
TTG's Avatar
Drives: M340
Interesting. We get a similar message if you try to turn the auto headlights off while they are on and driving.
"Lights off not available while driving" or something like that.
I hope we can find a way to code them so it remembers the last setting. Off means OFF
      04-09-2020, 11:12 AM   #16
Preciseyyc
Preciseyyc's Avatar
Yea that's the one.
I miss being able to go fully dark in my e93/f32 😑
      04-09-2020, 02:38 PM   #17
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
No I haven't.
Stupid Canada lol
It's mandatory in Canada (or will be), that as long as the engine is running and it's dark, the headlights must remain lit.
I'm not sure it can be removed via coding, it might be hardware specific but don't quote me..
https://www.tc.gc.ca/en/services/roa...le-lights.html
      04-09-2020, 02:40 PM   #18
Preciseyyc
Preciseyyc's Avatar
No I haven't.
Stupid Canada lol
Yea I know our stupid laws.
We never had the option in idrive to turn them off either always needed coding.
It's because we have so many damn morons driving dark thinking they have lights on cause the drl does faint heads and cluster, but no tails. Ruin it for us people with a brain
Poochie9104.50
      04-09-2020, 02:55 PM   #19
Poochie
Poochie's Avatar
Drives: 2016 M2
No I haven't.
Stupid Canada lol
It sucks but laws exist so stupid people don't hurt themselves or others..
I encounter at least one neanderthal, per week, on the expressway, late at night, with no lights on but I digress..
If it's that serious to you, maybe one of the coding vendors here might be able to possible code it remotely for you. Won't hurt to ask..
Try Steve @ codemybimmer
      04-18-2020, 05:02 AM   #20
advrider6510
advrider6510's Avatar
Drives: E36 M3, F80 M3, Ford Mustang
Check the below video tutorial I found on you tube.. hope this helps you
      04-18-2020, 03:45 PM   #21
TTG
TTG's Avatar
Drives: M340
Seriously??? At least catch up to the correct generation of the forum that you are posting.
      04-19-2020, 03:31 AM   #22
jaimeen77
jaimeen77's Avatar
68
Drives: BMW 330i
You can turn off the headlight while engine is running by coding
OFF_IN_PWF_FAHREN_ERLAUBT : 01 (ja)
this is in 17BD (BDC), also you need daylight coding as well.
