BIMMERPOST Universal Forums General BMW News and Cars Discussion Updated: Fire hazard: BMW recalls 1.4M vehicles due to risk of under-hood fires
      11-07-2017, 08:29 AM   #45
M3 Adjuster
Albania
7905
Drives: 1M, X1 M Sport, E46 325ic
Originally Posted by bradleyland View Post
The mental gymnastics that some people will go through to defend a brand is... Mind boggling
I'm not suggesting we get out our torches and pitchforks, but this is bad. The failure mode for any electronics equipment should not be "fire". Specifically, electrical engineers go to great lengths to prevent fires.
So yeah, it's good to keep a sense of perspective. BMW is doing the right thing here, but this was a mistake. There's no need to jump in and defend this as some kind of expected result of owning an aging car. It's not.
Agree. Any electrical connector that can cause a fire on its own without tampering is a serious issue. May be a case of bean counters saving a few cents on a tin plated connector design vs. silver plating, crimping vs. soldered connectors, etc. Will cost BMW much more in the recall cost than what they saved with the cheaper connector.
@bradleyland. LOL at your mental gymnastics comment.
First off I would like to know exactly how you can guarantee that the fail safe regarding an electronic component NEVER is fire ?
Second, Do you seriously think that vehicle fires are so uncommon?! You are totally going overboard here.
Indeed , let's keep this in perspective!
While a serious issue indeed, this is certainly not an issue limited to or specific to ,BMW , it affects many manufacturers and many SUPPLIERS of parts for OEM equipment.
Do I even need to utter the word. TAKATA?
Aside from vehicle airbags , there are many components that have led to fires in many different vehicles.
BMW had an issue with this in the X5 years ago and issued like this go back to the Ford Pinto or before.
I've already had a battery cable replaced on my 1M- do you think failures of it wouldn't have resulted in a potential fire risk ?
https://en.m.wikipedia.org/wiki/Vehicle_fire
According to the page above approximately 280,000 ACTUAL vehicle fires occur in a year. I wonder how many of those began due to an electronic component or part like a battery, fan, cruise control module , etc etc.
https://www.cbsnews.com/news/engine-...ecalled-fords/
https://www.nbcnewyork.com/news/loca...374150891.html
Lamborghini and Ferrari models are well known for fire risks particularly in older models.
Take a surf on over to the NHTSA web site and play around and see how many vehicle recalls are due to an eventual fire hazard.
Moral of the story - it's a recall. Check for your model and if it's affected then look for your notice and call your dealer. When fire hazard is a concern you seriously may wish to consider parking your vehicle away from the residence.
      11-07-2017, 09:16 AM   #46
bradleyland
TIM YOYO
Drives: 2013 M3
Did you even read my comment?
Have you ever heard the saying, two wrongs don't make a right? Just because Lamborghini and Ferrari models are known to catch fire doesn't make this a good thing.
Like I said, I'm not advocating anyone get out their pitchforks, and I really don't see how anything you said contradicts my statements. Other than the fact that you apparently didn't learn what most of us learned in pre-school.
His: 2019 R1250GS - Black
Hers: 2013 X3 28i - N20 Mineral Silver / Sand Beige / Premium, Tech
Past: 2013 ///M3 - Interlagos Blue Black M-DCT
Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport
      11-07-2017, 09:28 AM   #47
M3 Adjuster
Albania
7905
I haven't matriculated to primary school.
Don't rush me either !
      11-07-2017, 09:52 AM   #48
lan4
Drives: 2008 M3, 2010 550i, 2015 M3
Not sure which of us you are responding to, but I didn't say you can guarantee anything. What I said was "Any electrical connector that can cause a fire on its own without tampering is a serious issue." Fire is an immediate threat to life and property, it's not just getting stuck on the side of the road. The reason I commented and as Bradleyland said was to not "get the pitch forks out", but more because I think it's likely there are similar issues lurking on newer models as well. Should we also park newer BMW's outside so we don't burn our house down and risk our family's lives?
The most common way to minimize electrical fire risk is to over design for current and voltage handling capacity of wiring and connectors, use high quality metals (i.e. non corrosive) especially at high current contact points, and use fusing to protect the wiring. Apparently they (BMW) knew this and according to the NHTSA report ["The recall component (blower-regulator wiring harness) has tin coated connectors at the end of the harness, while the non-recall component has silver coated connectors at the end of the harness"] the connector was changed to silver (more expensive than tin) contacts at some point in time.
Being an engineer myself for many years I realize it 's not possible to make something perfect, but this is bad engineering and cost cutting.
      11-07-2017, 11:16 AM   #49
boss2k
Drives: 2021 M2C
Does this affect F80/ F82,built after 2015
      11-07-2017, 01:22 PM   #50
bradleyland
TIM YOYO
Drives: 2013 M3
All the affected vehicles are listed in these documents:
Originally Posted by mirob View Post
NHTSA document/report for affected 3-series vehicles in HVAC wiring recall (includes production date ranges:
https://static.nhtsa.gov/odi/rcl/201...7V676-9625.PDF
Other document/report for affected vehicles in PCV heater recall:
https://static.nhtsa.gov/odi/rcl/201...7V683-7475.pdf
At first glance, these are all N52 & N53 equipped cars, which is the naturally aspirated 3L I6 engine used before the move to the 35i model designation that accompanied the arrival of the 3L turbocharged I6 N54 engine. The F80 / F82 has the S55, which is a much, much newer engine.
boss2k1064.50
      11-07-2017, 08:38 PM   #51
boss2k
Drives: 2021 M2C
Bmw fire recall
Hope it doesn't affect our cars as the models recalled are 2007 to 2011
Does the M' s have latest technology ?
2021 M2C HS/6MT/Exec/Moonroof
      11-07-2017, 08:55 PM   #52
RickFLM4
RickFLM4's Avatar
Drives: M4
https://www.bmwusa.com/safety-recalls.html
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82
      11-07-2017, 09:08 PM   #53
boss2k
Drives: 2021 M2C
I saw that and checking if our cars are affected
Tried putting my VIN in the 2nd link and doesnt work
      11-07-2017, 09:11 PM   #54
SakhirM4
SakhirM4's Avatar
Drives: '15 SO M4/'20 Z4 M40i
2020 BMW Z4 M40i  [10.00]
2015 BMW M4  [8.76]
Worked fine for both my cars - you only enter last 7 digits, not whole VIN
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
      11-07-2017, 09:14 PM   #55
boss2k
Drives: 2021 M2C
Yes worked now , looks good for our cars I think
      11-07-2017, 10:00 PM   #56
Bemo
Bemo's Avatar
Drives: E92M3 LRP Edition
Not that I would have it any other way, but the Porsche always sleeps in the 1-car garage of my house, while the Bimmers slum it out on the driveway.
Hope I get the recall notice soon, that and ignore "fire sales" at the stealer!
      11-07-2017, 10:03 PM   #57
Katin
Drives: 2015 328i XDrive
Fake News.
      11-07-2017, 10:15 PM   #58
Gangplank
Gangplank's Avatar
Drives: 2011 e82 135i n55 Sport w/ DCT
2011 135i  [0.00]
Originally Posted by Katin View Post
Fake News.
Or Naked Fuse...?
:haha
2011 135i w/ DCT | ZSP Sport Pkg | PPK | Ohlins R
      11-08-2017, 07:31 PM   #59
gotgemini2000
Drives: G80 & E46 M3, 6 speed manuals
Originally Posted by MilehighM3 View Post
A fire in the trunk related to a headlight harness? Are you serious? More likely that it was an improperly install battery with a loose connection.
Per mechanic, wiring harness had a short in the wiring that ran towards the headlights.
      11-08-2017, 10:31 PM   #60
superduty
superduty's Avatar
Drives: 2010 E91 M Sport
This is driven more by the EU than the bean counters at BMW. The use of pure tin is the result of the EU prohibition of the use of Sn/Pb on connectors & component leads. A case of environmental concerns over riding practical concerns. The transition to pure tin has not been without unforeseen consequences and the mitigation costs have been huge.
"Did I say something abnormal?"
"You're an engineer, everything you say is abnormal."
lab_rat394.50
      11-09-2017, 07:48 AM   #61
MilehighM3
MilehighM3's Avatar
Drives: Harrop E90 M3
2009 E90 M3  [6.50]
Find a new mechanic
      11-09-2017, 08:54 AM   #62
lan4
Yes, forgot about the the EU regs. Thanks for the clarification and info.
      11-09-2017, 01:09 PM   #63
chris82
chris82's Avatar
Drives: 128i
2009 BMW 128i  [9.80]
These recalls are such a pain in the ass. I had the battery cable recall, airbag recall, and now most likely this shit? Takata may not have been directly their fault, but this is now 2 recalls related to electronics most likely caused by cutting corners in the wrong places. Again, another wire that could corrode. Oh well, they're out about $2 billion in market cap since this news came out. Surely that + dealer expenses to fix these issues is enough for them to learn the lesson.
      11-15-2017, 11:23 PM   #64
Eagle1oh7
Eagle1oh7's Avatar
Drives: '11 328i Sedan
Can't wait to wait over a year to have the recall performed. At the end of this month I'll finally have the airbag recall performed on my E90.
DONE: Seibon CF Hood, M3 Rep, MSport rear w/DD CF Diffuser, M3 Rep Skirts, Seibon CSL trunklid, Forgestar F14 18s w/Michelin PSS, Eisenmann catback, AA Headers, BPC Stage 2, Charcoal Delete+revMotor+AFE Drop In filter
FUTURE MODS: LED headlights, CF rooftop, M3 Suspension Conversion, Dinan CAI Mod
      11-17-2017, 04:35 PM   #65
Droshki
Drives: 2008 335i
So this is the issue that BMW told me about: Blower motor wiring?
      11-22-2017, 12:24 AM   #66
vilord
Drives: E91, Tundra, TT, SV650
I wonder if they'll perform the recall on the PCV heater if the intake manifold was replaced... My '07, and the '09 that the 3-stage IM that's in my car came from are both in the recall...
