11-15-2018, 12:17 PM | #24 | |
Rep 14,115
Drives: G82 M4C X-Drive
11-15-2018, 12:40 PM | #26 |
Rep 1,077
i think this is a decent amount of range and makes a ton of sense. Real world its probably about 25-30 miles electric with like AC on etc. I sadly don't have a charger at my apartment building but i'd at least consider this and move or something. My commute right now is about 8 miles.
A lot of you other commenters make it sound like it doesn't also have a gas tank? If you for whatever reason don't want a car that also has a gas tank I'm sure they will sell you an i4 or whatever in a few years based on basically the same platform. If this is priced aggressively like the 530e I think it will sell super well in a place like LA or NY or SF where 30 miles is probably plenty especially if you charge it at work too. I drove the 530e at the UDE also, and thought it felt like a huge car just because it actually is large, a 330e for a huge number of urban current 330i owners probably makes sense. |
11-15-2018, 01:01 PM | #28 |
Rep 103
Drives: BMW F30 330d M Sport
11-15-2018, 02:14 PM | #29 |
Moderator
7512
Rep 19,368
The 3 Series has been a RWD car since its inception in the 70s. And AWD options have been a regular part of the lineup for well over a decade.
This new model will do nothing to change that formula - both RWD and AWD variants will be available |
11-15-2018, 03:11 PM | #30 |
Rep 12
So essentially they took 75% of the new X5e's battery pack and paired it with a 320i. The range is enough for most people's needs, however it'll likely stay niche in the U.S. This will likely sell well in Europe, however. 138 mpg & those low emissions are impressive.
Progress is progress, whether an inch or a mile. |
11-15-2018, 10:44 PM | #31 |
Rep 4,128
Drives: M235i & G30 540i
Did I read correctly that electric alone range is 37 miles? This is releasing in 2019 and the range is only 37 miles???
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
11-16-2018, 12:19 AM | #32 |
Rep 101
Yes 37 miles. BMW has to make something that consumers are willing to pay for. Every 3 extra miles is another $200 or so. If you read the forums here and on leasehackr, people are buying X5 40e and 330e for less than standard variants. Or another way to say it is that BMW is having to "give away" the electric components. Why would they voluntarily put a bigger battery in so they can lose more money? When people start paying for range, they will certainly offer it.
11-16-2018, 09:52 AM | #34 | |
Rep 74
And I had the i3 when it first came out. That car was awesome but the range was laughable. |
11-16-2018, 10:01 AM | #35 | |
16423
Rep 8,418
You cannot do everything with electronics.
Dog Face Pony Soldier9719.50 |
11-16-2018, 10:31 AM | #36 |
Rep 4,210
I had a 2016 330e which had problems and I replaced it in December 2017 with a 530e.
Personally, I prefer a smaller car (so long as I can fit my golf clubs in it). The specs look pretty similar to the 530e with the exception of the extra boost feature and the larger battery pack (9.2 in mine). I wonder if the 530e can be programmed for the extra boost (apparently the same electric engine)? |
11-16-2018, 10:38 AM | #37 | |
Rep 2,499
You say that you don't even have to "think" about range when you drive your Model X but admit that you have a short commute. So you realize that a 330e would mean you almost never use gasoline on a daily basis right? Also, you technically have more range and far more refueling options when you drive a 330e. You talk about pure electric range as if it's this huge technological advancement. All it is are more batteries. That's it. A bunch of super heavy batteries that weigh your car down. I'm not saying Teslas aren't cool. The bigger battery packs allow for the massive power delivery that allows for the insane performance figures. But from a practicality standpoint, from an engineer's perspective, the PHEVs like the 330e are the best compromise. You don't get any of the drawbacks of either a pure EV or a pure ICE car, which are significant. |
11-16-2018, 04:19 PM | #38 | |
Rep 199
One says "Uuuh those heavy batteries", I say "Geee, those heavy gasoline motor", you say "What, only 37 miles?" In a pure electrical car however you have not only no motor (and its ancillaries) but no transmission and no tank. A lot of saved space and weight. And since the battery tech becomes better every year (refer i3), it's only a question of time before we'll see very different cars than this. Cars that will rock our minds... |
11-16-2018, 06:03 PM | #39 | |
Rep 2,499
ted99242.00 |
11-16-2018, 11:06 PM | #40 |
Rep 3,456
Drives: Harrop E90 M3
2021 they will have just the car you're after. A year later, but I'm sure the wait will be worth it. A quality luxury electric vehicle without the cheap feel of a Tesla.
11-16-2018, 11:19 PM | #41 |
Rep 3,001
The EV mileage is OK, like most of us agree here, but it is the step in the right direction. This car is perfect for those who have challenges charging at home or in an apartment/condo lacking the charging infrastructure. I would upgrade to this actually
re
11-17-2018, 09:39 AM | #42 |
Rep 6,029
I understand that conclusion, but I think the evidence shows the terrible build quality is primarily related to their novice status as a car company. The body in white is poorly designed (compared to "Kias of the 90s" by one teardown expert), assembly has been overwhelmed with technical failures in robotics, Elon set up an extended assembly facility under a tent in their parking lot. This has cost them more than "doing it right the first time", not less. Tesla should have outsourced assembly to a competent subcontractor, but that is not his style. I withdrew my deposit over a year ago as I learned more, and the vehicles I have seen on their owner's forum and in person have been very sub-par. They do make the best BEV drivetrain right now, but the car they wrapped around it is still "in development".
2015 228i 6MT/Track Handling/Tech/Cold/Premium/Lighting/Driver Assistance/KCDesign Strut Brace/M2 LCAs/Rogue SSK/BBS SR/PS4S/ER Chargepipe/AA Intercooler/Dinan Shockware/MPerformance Spoiler/Black Grilles/Xpel Ultimate PPF & Prime XR+ Tint/Adam's Ceramic/no CDV
2024 X3 sDrive30i/MSport/Premium/Dynamic Handling/Shadowline/Parking/Xpel Prime XR Plus/Weathertech Cargo Liner |
11-17-2018, 09:42 AM | #43 |
Rep 535
I just did a test drive of the Jag i Pace. An all-electric with 200+ mile range for a mid-$70's price (after the "First Editions" are gone). I think my current 330e is a better proposition and the new 330e even better. The Jag i Pace is a no compromises EV (skateboard) with no ICE vestiges, like the Tesla. Why do I think the 330e is a better proposition? An all-electric car is not currently viable as an "only" car if one does more than purely local travel. Current battery range is good for a half-day's travel and the charging infrastructure means a search for a mid-day stop and needing at least an hour for charging if a 100Kw system is available. So, if you are only using it for local travel and you have at-home charging, you are lugging around a very heavy and expensive battery whose capacity you don't need. This large battery is only useful if you don't have at-home charging and need to use a public charger; which you can defer to once a week. With daily charging, a 30 mi electric range will satisfy 100% of my local needs and I have an ICE (which weighs less than the extra battery I don't need) for trips.
My impressions of the i Pace: In person, it looks like the X2. The interior is fantastic--Bentley quality. The ride in "comfort" over potholed streets with the optional 22" wheels is about the same as the i3--coal cart-like. The performance is near "Tesla-ludicrous" and the steering precision near-perfect. Love the "one pedal driving"--very i3-like and vastly superior to the low regeneration of my 330e. Is it worth the $20K difference over the 330e? Not if you are a rational person. Would I buy it? Yes, except it's a Jag and I think it'll spend a lot of time in the shop. Luckily, I have 18 months before my 330e lease tolls to gauge the Jag's reliability and to see what kind of car my wife wants to replace her X5 40e with. Will it have a long trip capability so that my choice is "free"? Given "free" choice, would I rather have a reliable i Pace or a BMW M340i? |
11-17-2018, 01:10 PM | #44 |
Barge driver
8656
Rep 12,425
The MPG figures are a nonsense, what they should also tell you is the MPG you can expect on a 200 mile run, CAR once tested the G30 530e from Edinburgh to Bristol (some 400 ish miles) and averaged 34mpg, well my F80 M3 could do that.
730d/Z4C
