Technical Topics Wheels and Tires Will F30 wheels fit on a G20? Or is the bolt-circle different?
      11-17-2018, 12:03 PM   #1
ted99
Drives: former i3>330e, 528i>X5>530e
I was just looking at a site that reports on the wheel bolt circle sizes of all makes of cars and they report a surprising piece of info. They list the G20 wheels as 7.5j x 18 with a bolt circle of 120mm and center of 72.6mm. They do not record the offset.
This is a big surprise as I thought all the next generation of BMW's had gone to the 112mm x 66.6 hole.
The new 112 mm x 66.6 size was disappointing to me as it meant that I could not reuse my old wheels/tires.
This is a big deal if true. Can anyone else confirm that BMW has continued with the 120 x 72.6 mm size for the G20?
      11-17-2018, 01:47 PM   #2
HighlandPete
Drives: BMW F11 535i Touring
Has BMW actually put the detail in their media/technical data releases? Not seen it myself in any tech' data. What I understand, BMW changed PCD and bore size for all new models.
This was stated in BMW G30 technical data.
Wheel Hub
The hub and hole circle diameter on current vehicles produced by the BMW Group was modified in 03/2014. The hub diameter was reduced from 72.5 mm to 66.5 mm. The hole pattern was modified from 5 x 120 (F01/F10) to 5 x 112 (G12/G30).
I'm expecting G20 hubs to follow the same revised dimensions.
      12-03-2018, 01:41 PM   #3
upsidedownfunnel
Drives: 2014 335i
2014 BMW 335i  [0.00]
Considering G20 is on the CLAR platform, it seems more likely that the site you were reading was just plain wrong and assumed something they should have.
It would be illogical for BMW to migrate to 5-112mm on all their cars except for just the 3 series.
      12-04-2018, 02:21 AM   #4
mathys
mathys's Avatar
Drives: G82 - G01 - F56
+1
      12-04-2018, 10:35 AM   #5
ted99
I just WANT the site to be correct, so badly. Checked and the site is still listing it that way, though it makes no sense, unless BMW is going to revert to 5 x 120mm across the line and the G20 is the first one up.
      12-12-2018, 03:27 PM   #6
harperium
harperium's Avatar
1312
Drives: G80 M3cx
Will my aftermarket F30 wheels fit on a G20?
Would love to keep the aftermarket wheels + tires and just put them on a new M340. Will they be the same as the F30?
      12-12-2018, 04:19 PM   #7
HighlandPete
G models are using new/different wheel bolt PCD and hub spigot dimensions.
      12-12-2018, 06:07 PM   #8
arciga18
arciga18's Avatar
1729
Drives: LeMans/ Chestnut E90, RWD
Don't count on using old wheels w/o hub adapters.
      12-13-2018, 07:57 AM   #9
JayPichardo
BMW Client Advisor
JayPichardo's Avatar
3452
2020 BMW M340i  [0.00]
Wheels from an F car do not fit G cars.
jpichardo@tulley.com
jojo753.00
      12-21-2018, 06:08 AM   #10
greasypeanut
Drives: F87
The different bolt pattern blows. I was hoping to be able to reuse my track 18s
      01-24-2019, 11:01 AM   #11
askforcharliek
#askforcharliek
Drives: 2020 M340 xDrive
bump! hoping to use my extra wheels from 2016 340 on 2020 m340 for winter tire/wheel set up.
2020 M340
2018 X5 40e
      02-14-2019, 12:51 PM   #12
VMRWheels
General
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
We're expecting it to be 5x112 66.6 with conical seat lugs similar to most of the other newer models. I don't see why the G20 would be any different. It may make looking for wheels a difficult task as many aftermarket wheels with this PCD and hub bore will be designed for use with Audi/VW/Mercedes ball seat lugs.
In any case, this won't be an issue for us as we custom machine everything to spec for each application anyways. Now, we just need to track one down to bring in for some R&D test fitting!
      02-18-2019, 04:16 AM   #13
Spoilt666
ʘʘʘʘʘʘʘʘ
Spoilt666's Avatar
Drives: BMW G20 330e Portimao Blue
Damn, so the V810's from my F31 won't fit on my new G20 330e
      02-18-2019, 11:52 AM   #14
VMRWheels
General
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Unfortunately, it's looking like none of the 5x120 wheels will bolt onto the new G20.
      03-25-2019, 09:37 PM   #15
HapkidoNinja
HapkidoNinja's Avatar
Drives: 2020 M340i xDrive
My M340ix is on order and I started looking for a set of 18" square rims to use in the winter.
Gripe: Why is it none of the sites list rim weight?!
I don't want to carry >30 lbs of deadweight per rim....
