01-10-2019, 07:37 AM | #1 |
Rep 29
M Adaptive Suspension?
Hi all,
I am considering purchase of new 330i with M sport equipment and I am considering adding adaption suspension. Mostly I would drive the car in the city where roads are not nearly perfect and it will be a bumpy experience so I wanted know if someone tried new adaptive suspension in test drive? I found that F30 with adaptive suspension in comfort mode was useless for these roads, car would still feel to stiff. |
01-10-2019, 08:10 AM | #3 |
Rep 2,290
I think adaptive comes with M Sport? So you may get it anyways unless you opt for a delete (unsure if that’s an option).
I’m not sure if anyone here has driven the G20 setup in real life yet, but if it helps, I’ve had adaptive suspension on all my F30’s and live in a city. Never complained about it being too stiff or uncomfortable. |
01-10-2019, 09:18 AM | #5 |
Rep 147
G20 will have the so called "active" suspension, which will add more comfort while maintaining agility, on both the standard and m sport (10mm lower) packs, and then adaptive as an option.
01-10-2019, 09:44 AM | #6 |
Rep 15,858
From what I read in the pre production drives, both the standard and M-sport passive suspensions in the G20 are better sorted than the F3x models, both for comfort and handling.
Comments within the reviews indicate the Adaptive M-sport gives a similar improvement. Hopefully keeping that improvement with the wider working envelope, than either passive suspension can give. We really need more reviews and a few test drives. |
01-10-2019, 10:13 AM | #7 | |
Rep 2,290
704M sport suspension or 2VF (Adaptive M Suspension) But it doesn't really clarify how to select 2VF within ZMP. I see 2VF is included in ZTR (Track Handling Package), so I guess you need to get ZTR if you want 2VF? Really frustrating part is that ZTR isn't available for xDrive. So you can't even have adaptive suspension on xDrive then? That seems like a downgrade from the F30, since you could have adaptive suspension on the F30 xDrive (unless I'm missing something here). Of course the online configurator is of no help at all so referring only to the ordering guides only in this case. Maybe the ordering guides were updated since late 2018 and hopefully what I'm looking at is wrong. |
01-10-2019, 10:40 AM | #8 | |
Rep 2,774
01-10-2019, 11:36 AM | #9 |
Rep 2,290
01-10-2019, 11:40 AM | #10 | ||
Rep 2,558
01-10-2019, 06:16 PM | #11 | |
Rep 734
Drives: M340i x-drive
04-05-2019, 08:13 PM | #13 |
Rep 1,190
On track with the G20 adaptive suspension? Or track experience with adaptive suspension in general?
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
07-11-2019, 02:24 PM | #15 |
Rep 29
I purchased car with M adaptive suspension and it's really good. In comfort it's soft and in sport plus not to stiff. Haven't drive the card with M sport but my old E90 with regular suspension is stiff as a rock vs. M adaptive on G20.
07-12-2019, 01:27 PM | #16 | |
Rep 534
Just ordered my 330e with adaptive to (hopefully!) cure that problem. |
11-15-2019, 03:23 PM | #17 |
Rep 16
Standard Vs Adaptive
I did test drive both standard and adaptive suspension in 320D M sport and I chose Adaptive suspension for my car.
I did feel adaptive suspension is way better than the normal. I would recommend you to test drive a rough route one after the other so you could make an informed decision. |
