Technical Topics Cosmetic and Lighting Modifications (exterior & interior) Chrome vs Black grille
      02-16-2022, 07:14 PM   #111
RRoccoT
RRoccoT's Avatar
11
Drives: BMW 2022 M440i Gran Coupe
Front end is sweet.
      02-18-2022, 04:27 PM   #112
shanecolton
Drives: BMW G20 320d Msport
Originally Posted by Chuckyarla View Post
Replaced the chrome grille. Very pleased with the result.
The black grille really changes the front. Which is standard on the msport? Some seem to have chrome, others black. What font did you use on the plates. They look tasty. Not a lover here of the 4d plates. Would you mind sending me a DM pic of them upclose. Thanks.
      02-18-2022, 06:20 PM   #113
sdemo
Drives: G20 M340i
Originally Posted by sdemo View Post
or...
Shameless quote but it was stuck on last page
      02-22-2022, 05:27 AM   #114
l33v0nix
l33v0nix's Avatar
Singapore
66
Drives: G20 330i M Sport
Originally Posted by StevenDS85 View Post
The M340i has flat active shutters indeed which means the OEM honeycomb grill of an M340i won’t fit on a 330i unless you also change the active shutters to the flat ones.
However, when you look at below video it does look like it’s possible but personally I wouldn’t risk it as BMW is using different active shutters. Maybe just because of the looks ...
anyone is able to verify if the original bmw diamond mesh grille will not cause any issues on the active grille on 330 and below?
      02-23-2022, 12:12 PM   #115
dubstyle71@gmail.com
dubstyle71@gmail.com's Avatar
Drives: 330e xDrive 4 dr sedan (G20)
Right part # for 330e xDrive 2021 Black Grille
Does anyone have any links or correct part #s for the black grille replacement for a 2021 330e xDrive ? Can't stand the chrome. Single slats preferably but open to suggestions on other black options.
Thanks!
Last edited by dubstyle71@gmail.com; 02-23-2022 at 12:14 PM.. Reason: be more specific about title
      02-28-2022, 02:58 PM   #116
mrgalahad
Drives: 2012 Range Rover Sport GT
Originally Posted by CrownRoyal79 View Post
I've since switched to the gloss black mesh grille but I don't have any pictures of it.
Can i ask where you bought your black mesh grill? been looking for one
      03-01-2022, 06:33 AM   #117
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
mrgalahad ,
I got my gloss black with burnished chrome mesh onbeBay-- the specific item I got is put of stock, but am sure if you search on eBay you'll find another
Hope that helps
Al
Retired: 2014 328i
BMW CCA
      05-16-2022, 12:23 PM   #118
Conezz
Drives: G20
That’s BS. The m340 grille is completely compatible with the 330i and does not affect any functionality. Did this myself.
Just make sure you order the one that matches your camera type.
      05-16-2022, 12:29 PM   #119
Conezz
Drives: G20
Complete BS. It’s the same thing. No functionality impairment. Had it done myself. This is my 330i.
      05-17-2022, 10:22 AM   #120
l33v0nix
l33v0nix's Avatar
Singapore
66
do you mind share close up photo of your active grille behind the diamond grille?
      05-17-2022, 10:23 AM   #121
l33v0nix
l33v0nix's Avatar
Singapore
66
Attachment 2884986
i noticed the recent batch of non m340 g20 has flat active grille but earlier batches has ribbed surface on the flaps https://g20.bimmerpost.com/forums/sh...9&postcount=92
      05-17-2022, 11:23 AM   #122
Conezz
Drives: G20
The grille hasn’t changed so the flaps should be irrelevant.
If there are two different versions of the same grille, then the fittings would have to be different if the flaps need different accommodation.
      06-21-2022, 10:37 AM   #123
3ismagic#
3ismagic#'s Avatar
127
Drives: '19 330Xi M-Sport
or...
This looks great where did you find the portimao/black grill insert?
      06-21-2022, 12:10 PM   #124
sdemo
Drives: G20 M340i
or...
Thanks! I had it custom painted through IND-distribution. Came out perfect.
      08-05-2022, 03:25 PM   #125
areohbee340i
Drives: 2020 BMW M340i
I am looking for a M340i Diamond Grille in black for my M340i. I love the Cerium Grey but want to give my car a diff look and I think it will look nice. I have the 792 wheels, so I will just keep the mirrors in the same finish
      08-06-2022, 10:39 AM   #126
sdemo
Drives: G20 M340i
https://ind-distribution.com/product...e-front-grille
      05-06-2023, 04:15 PM   #127
Banhxeo
Drives: N/A
or...
This looks the best imo. Do you have more front end pics?
      05-10-2023, 02:12 PM   #128
sdemo
Drives: G20 M340i
Thank you! I don’t, because I actually put the black surround back on. It was a lot of blue, and I wasn’t loving it. I can’t say I love the black either.
So… I’m working on adding black vinyl to reduce the blue a bit and may reinstall. Will update here if I do.
      03-29-2024, 02:03 PM   #129
jrf22
Drives: BMW M340i
Double slat grille
Originally Posted by k4sh_90 View Post
Following up on my post, here's the finished product:
Where did you buy the double slat angled grill?
