11-21-2020, 08:49 PM | #23 |
Rep 207
11-21-2020, 09:59 PM | #24 |
Rep 110
I honestly don't know - if it was I didn't have it set ... I only thought to look for it after reading this post.
11-22-2020, 09:41 AM | #25 |
Rep 1,480
Drives: 2020 M340Xi (G20)
rcz22 ,
Appreciate you letting us know about the menu selections, since quite honestly I had forgotten how to get to Tach display in HUD. I had it working when I got my car & on subsequent software updates-- until 07/2020.45 that was done by my dealer. After that update Tach only appeared in HUD when I selected ALWAYS ON. Recently, my car got its first OTA update to 07/2020.54. After that I redid my custom coding. I just checked my car a little while ago and neither of the additional items for Instrument Panel or HUD. At this point, I doesn't matter whether it's a glitch in the update or perhaps the custom coding. Since for now, I am down to Bimmercode, it's somewhat challenging to research HG_MGU CAFD/NCD files. Would appreciate any help in determining what functions to code to get Tach displaying in HUD Thanks UPDATE: Thanks to E-Sys & E-SysX, found out why even iDrive menu option to display Tach HUD disappeared. When I "uncode" the tire pressure Instrument cluster (M_VEHICLE_SP2018_RUEKO), car goes back to displaying DISPLAY, HUD SPORT DISPLAY -- but only works in ALWAYS & not SPORT ONLY. Given that choice unfortunately, I opt for tire pressure
Al
T-Rex Au38.00 |
12-08-2020, 05:32 AM | #26 |
Rep 207
I have updated to 11/2020, and the issue still persist. Anyone know any coding can settle?
Tskyline10.00 tommytexter181.50 |
01-03-2021, 08:18 AM | #28 |
Rep 207
01-09-2021, 02:56 AM | #29 |
Rep 5
My M340 has the latest firmware update. With my default display set to the Alpina layout, I’m able to see the tach in my HUD by selecting Sport Displays under the Additional Displays setting:
HUD settings>Additional Displays>Sport Displays I haven’t tested this under the M layout or default layout but at least it works with Alpina. |
03-14-2021, 08:08 AM | #31 |
Rep 1,180
IFR provided the coding required on the thread below. I applied it to my March 2020 build G21 running 11/2020.50 and the tach is back
https://g05.bimmerpost.com/forums/sh...740022&page=11 |
03-14-2021, 08:25 AM | #32 | |
Rep 207
Hi,
Which one do you change to solve the problem? CB_HUD_LIST_AUS: aktiv [01] CB_HUD_LIST_AUTOMATISCH: aktiv [01] CB_HUD_LIST_FAS_PERMANENT: aktiv [01] Quote:
03-14-2021, 08:43 AM | #33 | |
Rep 1,180
CB_HUD_FAS: nicht_aktiv [00] CB_HUD_LIST_AUS: aktiv [01] CB_HUD_LIST_AUTOMATISCH: aktiv [01] CB_HUD_LIST_FAS_PERMANENT: aktiv [01] CB_HUD_LIST_SPORT_AUS: nicht_aktiv [00] CB_HUD_LIST_SPORT_FES: nicht_aktiv [00] I assume the other 3 codes are disabling the old menu options as you make them as not_active. |
03-14-2021, 09:57 AM | #34 | |
Rep 207
Hi,
Thanks. Do you have Driving Assistant Professional (5AU)? If disable CB_HUD_FAS: nicht_aktiv [00] and when driving assistant is active, does it still show in HUD? Quote:
03-14-2021, 11:23 AM | #35 |
Rep 1,180
Yes I do and yes it does. Essentially it’s gone back to how it was before i upgraded to 07/2020. I gave it a thorough test in all the driving modes and nothing appears to be missing / broken as a result. The change was I now had the new Additional Displays menu as opposed to the Sport Displays. Setting it to Automatic is the equivalent to “In SPORT mode” in the old menu.
03-15-2021, 06:00 AM | #36 | |
Rep 566
Have any BimmerCode users successfully done the following?
CB_HUD_LIST_AUS CB_HUD_LIST_AUTOMATISCH CB_HUD_LIST_FAS_PERMANENT My Istep is 07/2020.80 and I have the most recent iOS BimmerCode version. |
03-16-2021, 01:41 AM | #38 |
Rep 566
Wow, that's very interesting. I wonder why/how I'm missing them??
03-16-2021, 04:30 AM | #40 |
Rep 566
03-16-2021, 08:54 AM | #41 |
Rep 1,587
