2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK Initial "real world" 330e economy (5 days in...)
      10-09-2019, 03:06 PM   #67
tricky6
Drives: G20 330e M Sport+
Originally Posted by Cranester1983 View Post
Good thing about having a company car is I don’t really care if the engine is cold 😂
But what about those poor little cold molecules bashing against those other poor little cold molecules and knocking a few atoms off... ;-)
Mine is also a company car but out of respect for mechanical things I'm still trying to be kind... :-)
      10-10-2019, 05:41 AM   #68
HighlandPete
Drives: BMW F11 535i Touring
Better PM me your VIN number, so that I don't buy it as a used car.
      10-10-2019, 07:42 AM   #69
petejigsaw
Drives: BMW G20 330e
One week since I picked mine up and due to issues getting charging points installed at home and work, not yet charging daily. One charge from 12miles to full last night, and so far, getting 38mpg overall, with a lot of manual S-mode driving and plenty of battery control (set at 70%).
Very pleased to see others getting much higher on regular charges, as that will deliver the benefit I expected. :-)
      10-10-2019, 07:56 AM   #70
JustChris
General
JustChris's Avatar
Drives: Tesla MYRWD
Originally Posted by HighlandPete View Post
Being in the Highlands, I would need convincing that at freezing temperatures, I'll not be left to run the ICE for just a few miles in everyday winter use.
In fact, this is one of my biggest concerns (as an engineer), the use of ICE in short bursts, particularly when started from cold. I don't like using any ICE for short trips, when the engine doesn't get to temperature. I see this factor as a big negative for getting the 330e.
I can see my self running the engine after a start, for the rest of my trip, (say 12 miles), simply to get it hot.
Anyone considered how the engine life will be shortened, by poor and/or short cyclic use?
Ideal scenario Pete probably for 12 miles of pure EV mode only. ICE is not called into action at all in this scenario with a little care I woudl think.
Your post went down a very different path to that it thought it might take when you mentioned the Highlands and cold....I thought you might refer to greatly reduced range in Cold conditions. A few manufacturers have a handy(ish!) range calculator that allows you to adjust parameters such as ambient temp, AC on/off etc. Obviously this will not help completely as they are designed to show how much of a theoretical 310 mile range is affected by this, but it could help to run the figures and assume like4like maybe 25% range reduction in winter etc.
I'd be envious of a standard 12 mile day trip and to my knowledge this is absolutely sweet spot usage for a PHEV.
My car made front page of Bimmerpost
      10-10-2019, 08:44 AM   #71
HighlandPete
Originally Posted by JustChris View Post
... but it could help to run the figures and assume like4like maybe 25% range reduction in winter etc.
Final leg is 12 miles. Has to be in the 24 - 36 miles range to make it work locally. I'd like to see over 30 miles in freezing conditions. Don't really think the BMW is there yet.
Longer trips, (typically 120 miles), ICE will be doing most of the work. So little advantage to having an PHEV on those trips, other than boosting performance when necessary.
      10-10-2019, 09:33 AM   #72
JustChris
General
JustChris's Avatar
Drives: Tesla MYRWD
Agreed.
X5 45e is 50+ miles I believe and a nice B58 up front too!
      10-10-2019, 04:48 PM   #73
Cranester1983
Drives: BMW 330e M Sport
Originally Posted by highlandpete View Post
better pm me your vin number, so that i don't buy it as a used car. :d
      10-22-2019, 03:39 PM   #74
Jkwon
Drives: G20 330e
Sorry to resurrect this thread but to those of you with the 330e, hows the fuel economy working out a month or so down the line?
      10-22-2019, 03:54 PM   #75
Tengocity
General
Tengocity's Avatar
Scotland
8566
Drives: 911, Cayenne Turbo, Disco 4
Not sure I agree with this Pete.
My experience is that over a journey like that the mpg difference between a journey started with an empty battery versus a full battery, would be about 5mpg in my F30 330e. I expect it would be even more on the G20 version.
That would be a journey involving significant sections of high speed running. The battery definitely helps the engine when running in standard hybrid mode, not just for moments of acceleration.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
      10-23-2019, 12:55 AM   #76
tricky6
Over 2000 miles I've averaged about 75MPG. Should be set to improve as my Manchester project is coming to a close and I'll be doing more office commutes (where I get 180-200MPG over a 92 mile return route, charging at the office).
JustChris17487.50
Jkwon27.00
      10-23-2019, 02:28 PM   #77
petejigsaw
Out of interest, I presume you are charging at both ends of your journeys, and driving in hybrid mode all the time until the battery is exhausted? And presumably you're using eco-pro mode?
      10-24-2019, 05:20 AM   #78
mlcgd21
Drives: BMW 1M, G20 BMW 330e
After 2300 miles my total average is 70 mpg, around half of the miles were done in petrol
tricky6239.50
JustChris17487.50
      10-24-2019, 05:29 AM   #79
snusnu
Drives: BMW 330e (g20)
if I will manage that i will be very happy. My Mondeo hybrid used to do around 45 mpg in 4 years on avg
      10-24-2019, 09:24 AM   #80
E93_BMW
Drives: BMW
So if my commute to and work is a total of 24 miles there and back do you think I should be able to do the full journey on full electric? It’s all town driving
      10-24-2019, 09:27 AM   #81
snusnu
yes, you should. remember - every time you brake or roll - you charge you battery.
      10-24-2019, 10:36 AM   #82
tricky6
Yep! Sometimes it doesn't quite calculate well enough and I've ended up having 1-2 miles left. If it looks that way I tend to force into electric mode, but it's pretty rare. I've definitely had a fair few blasts in Xtraboost so it's not pure eco.
      10-24-2019, 10:42 AM   #83
E93_BMW
Drives: BMW
Thanks for the reply
      10-25-2019, 02:00 PM   #84
KyleKatarn
Drives: BMW 320d
Got my brand new 330e last Monday. It has been a pleasure to drive, but today I got a brake fluid warning, saying service was due back on 2001... Was it an easy fix for you guys who had this same problem?
      10-25-2019, 02:41 PM   #85
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
443
Report to Dealer... quick fix according to those who have had this warning.
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      10-27-2019, 01:55 AM   #86
Burnzie’s BM
Burnzie’s BM's Avatar
65
Drives: BMW 330e 2019
I've not yet got my head around how it calculates this number either, I've seen it vary from 21-26 when 100% charged. Best I've ever seen is 26 miles.
One day I'll put it into full electric on a full charge and see how many miles I get.
But on my 46 mile commute (one way) I easily get 35 miles of electric. On a 170 mile trip I got 47 miles. Regen power does add up over time.
Bit colder and darker in Scotland than in Wiltshire, perhaps that's it? ;-)
Does battery regen happen in all driving modes?
      10-27-2019, 10:10 AM   #87
snusnu
Ok, so here's my observation:
Removed from charge - 22 miles of electric distance.
Drove 6.5 miles (with a bit of traffic and a bit of a road at 60 mph).
Parked.
Drove back same distance.
Parked.
Drove another mile.
Parked.
When returned - 11 miles on electric only remaining.
      10-28-2019, 04:26 PM   #88
KyleKatarn
Drives: BMW 320d
Ended up sorting this out on my own. After complaining to my dealer over the phone she sended me a pack of instructions that I had already read somewhere on this forum, detailing how to reset oil service. It worked flawlessly.
