11-29-2019, 02:50 PM | #1 |
General
8562
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
First long journey in the 330e
Drove from home in Oxfordshire up to Perth today. First time I've done a proper long run. The car was great, and certainly much more relaxing to drive than any of my F30 generation cars were. Lower wind, engine and road noise overall, lovely ride comfort, better stereo, more consistent DAB reception, and driver assistance systems that work great most of the time, in most traffic conditions, all add up to a good long distance car.
In terms of performance and economy, I set the battery to go no lower than 60% and did the 440 miles at 39mpg. All in all I'm pretty happy with that. In terms of pence per mile it's not far behind my wife's Merc C250d on a long journey and much cheaper most of the rest of the time. That's me cruising at high speed wherever possible. Performance was good, more than quick enough to regain lost speed, but not quite up there with my old 335d. This car impresses me more and more.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
11-29-2019, 04:29 PM | #3 |
General
8562
Rep 19,982
I wanted to see what it did with really just using engine power and not sure I'll get a chance to charge whilst I'm up here. I like to have some electric power in hand for extra boost sport mode too!
11-29-2019, 04:56 PM | #4 |
Rep 283
12-02-2019, 08:13 AM | #6 |
General
8562
Rep 19,982
Use battery control mode, which allows you to choose a level from 30% upwards in 10% increments.
I'm currently en route back down and will update further in a few hours!
12-02-2019, 08:35 AM | #7 |
Rep 43
Battery Control mode works nicely for charging too. Just test drove a G20 330e a week ago. The test car was at 50% battery when I started; drove the battery to empty in Electric mode, then set the Battery Control to 60% and continued driving for maybe another 35 minutes and the battery was back to 50%.
12-02-2019, 09:14 AM | #8 | |
Rep 829
12-02-2019, 09:40 AM | #9 | |
Rep 283
In battery control mode if say you have 80% battery and you set it up at 50% minimum, does it allow you to drive in electric until the battery gets down to 50%? Does it give you full power or only the power from the petrol engine? |
12-02-2019, 10:13 AM | #10 | ||
General
8562
Rep 19,982
12-02-2019, 10:19 AM | #11 | ||
General
8562
Rep 19,982
I drive home today, leaving Perth with around 6 miles electric range. I set it to battery control of 40% initially, which meant it had to charge up the battery for a bit. After topping up in Carlisle I left in normal hybrid mode for the rest of the way back to Oxfordshire. It managed the electrical energy very well, and without interfering further I got home with exactly 0 electrical range left and it saved the last 1-2 miles of electric for the urban part once I'd left the motorway. Trip computer says 37.8mpg, which sounds about right as average speed was a bit higher than on way up on Friday.
mlcgd21154.50 |
12-02-2019, 11:20 AM | #12 |
General
8562
Rep 19,982
Had a chance to really look at the fuel economy of this car over a variety of types of usage, with varying amounts of battery usage being allowed.
On the long motorway runs (several hundred miles) where the battery can help, even for just a few miles of given electric range, the fuel consumption is around 37-38mpg (brim to brim). If the battery is charged up during a longer motorway journey, even just going from 2 miles to 6 miles range, then overall consumption drops to around 33-34 mpg. It suggests to me that charging using the engine really doesn't make economic sense in that situation. I also did a drive at weekend from Perth to Glen Coe, on quiet roads, with the car in sport mode for the vast majority of the time. I must say it works very well and the steering and suspension changes really do make the car more sporty to drive. It really flies when you need it to, and it handles so much better than any standard F30 car does. Lots of grip, traction, confidence, despite the sub zero temperatures. Really lovely neutral handling balance, and you'd never really tell that it carries an extra few hundred kg. That said, it was never driven more than 8/10ths given the conditions. What I liked is that sport mode kept the battery topped up, yet still give loads of extra pace. No idea how it does that, but the penalty was a return of 29mpg for the 185 mile round trip. Not bad at all given the performance that was used, but a far cry from the 70mpg on the commute, being able to charge. Now, after my trip to Scotland, my average fuel consumption since new is 43mpg over 2370 miles. It was 55mpg before I left, after the first 1250 miles. Trip to Scotland was 1140 miles, done at 35mpg, with no additional charging done in that time.
mlcgd21154.50 HighlandPete6658.50 |
12-02-2019, 11:21 AM | #13 | |
Rep 829
12-02-2019, 11:26 AM | #14 | |
General
8562
Rep 19,982
Anyone who regularly does several hundred miles drives as main usage will be better off in a diesel.
12-02-2019, 11:59 AM | #15 |
Rep 829
You say your average fuel consumption since new is 43mpg. Does that refer to the miles driven on the petrol engine or overall including both petrol and electric? If it's overall, and you add in the cost of the electricity used in charging, how economical would you say it's been compared to say a 320d?
12-02-2019, 12:07 PM | #16 | |
General
8562
Rep 19,982
You have to really consider what your usage profile is though. My data so far is completely skewed by doing about half those 2300 miles with no charging. Normally on any given month using my car for my normal commuting, over 2000 miles it's going to do 60-70mpg! If you have a shorter commute then it could be way higher than that.
12-02-2019, 12:14 PM | #17 |
Rep 283
thanks for your feedback Tengocity, that makes the battery control mode more useful than I thought, for a big holiday trip, where it is not possible to charge the car, it makes sense to use it, that way full power is always available.
12-02-2019, 12:22 PM | #18 | |
General
8562
Rep 19,982
If it's for performance though I actually now think that just putting it in sports mode may be sufficient, as using it like this on Sunday it never dropped below 11 miles electric range, despite giving up lots of performance and hard acceleration. The next experiment to try would be letting the electric range drop to 0 or 1 and then using sports mode and seeing how it is.
12-02-2019, 12:24 PM | #19 | |
Rep 283
I have done 3500 miles and my average is 94 mpg + around 22 charges per month, most were free. We have another 330e in our company which is driven by a director which had a 320d before, he drives a lot (he is a salesman), in the 320d he averaged 40 mpg, in the 330e he is averaging 47 mpg, with 1 and sometimes 2 charges per day. |
12-02-2019, 12:24 PM | #20 | |
General
8562
Rep 19,982
12-02-2019, 02:32 PM | #21 |
Rep 5,681
If I put my sensible head on I ought probably to consider the G21 330e when it arrives as a chunk of my mileage now consists of the sort of runs which could be done mainly - and in some cases perhaps exclusively - on electric power. However, I understand the boot area is reduced quite significantly due to the need to accommodate the batteries and, if that makes the load area smaller than my existing F31, it would rule it out for me.
And, while it's more expensive to buy and run, my heart says I'd still prefer an M340i! |
12-02-2019, 03:21 PM | #22 | |
General
8562
Rep 19,982
