Technical Topics Wheels and Tires Would 20x10 ET35 fit on my M340i?
      04-22-2020, 11:54 AM   #1
saido
Drives: M340i
Found a great deal on a set of wheels for my M340i and was wondering if the following would be too aggressive -
20x10 ET35 5x112
285/30/20 tires all around
Any feedback is appreciated!
      04-22-2020, 05:10 PM   #2
NoTanks52
Drives: M340i
20x10 ET35 5x112
I put on 19x9.5 et35 wheels in rear with 265/35/19s and the top of tire sits very close to flush with fender. The tire shop advised I had more room to put wider tires without issue, definitely 275s, maybe even 285s but you’re using a half and inch wider wheel. I know this doesn’t completely answer your question but hopefully it will give you some sense of how it will look.
Edit: just read this again, you going for a squared setup with 285s? You sure this will even fit in front? I put 235s in front and tire shop said I might be able to fit 245s but it’s close.
      04-22-2020, 05:30 PM   #3
saido
Drives: M340i
Thank you for your feedback and assistance!
Honestly, after reading your response and doing some research, I don't think this is the right way to go. I was only considering this option because I found a great deal on a set locally. They are coming off an S5.
So the search will continue! I have until lowering springs are finally available.
Thanks again!
