Technical Topics DIYs and Coding Discussions Rear DRL activation
      05-09-2020, 11:12 AM   #23
Asterix
Asterix's Avatar
21
Drives: BMW 330i G20 Msport
VipinLJ ,
Here's my car's right rear taillight with DRLs -- looks the same as with headlights
Hope that helps
On F30 , it was possible to have DRL as a whole or only "inside" ( part on boot lid) or outside
Not possible on G20?
      05-11-2020, 05:00 PM   #24
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Asterix ,
Know exactly what you mean; I coded that in the REM module of my old F30, but apparently, G20s have these functions in the BDC_BODY3 module in one of its CAFD files. Haven't had a chance to check that out yet
Anyone else have?
Al
Retired: 2014 328i
BMW CCA
      05-12-2020, 01:39 AM   #25
Basti@G20 320D
Basti@G20 320D's Avatar
Sweden
25
Drives: E30, E36, E46, F30, G20
So if can go back to DRL, does anybody know how to code it with Bimmercode or not?
      05-12-2020, 07:48 AM   #26
igorbutarev
igorbutarev's Avatar
Russia
26
Drives: F30 320i G20 320d
Don't know how to do it in bimmercode, but with esys you need only go to BDC and set FEATURE_4 to activ. May be in bimmercode expert mode you can do it
      05-12-2020, 08:08 AM   #27
RSnic
RSnic's Avatar
@Basti@G20 320D,
Here's my post from earlier in this thread:
While I have Bimmercode & am a beta tester (for Android), I still use E-Sys & ProLauncher to do some coding. I coded taillight DRL Activation; here's what to do:
HU_MGU module in HMI_SPEECH section
Set DAYDRIVING_LIGHT_REAR Function to aktiv
Hope that helps!
Al
Retired: 2014 328i
BMW CCA
      05-12-2020, 10:29 AM   #28
hottroc
Drives: BMW 330e
Sorry to sound ignorant, this seems quite popular but I'm not sure I understand the purpose or need for this? Is it any different to just leaving your side lights on? What's the attraction?
      05-12-2020, 12:00 PM   #29
andy5468
andy5468's Avatar
90
Drives: BMW G20 M340D LCI
This means you would have to switch from Auto lights to sidelights when getting into the car at the start of the journey. You would then need to switch from sidelights to auto or low beam headlights when it gets dark.
An annoying feature I have discovered with the G20 is that if you start off the journey in Auto lights mode you cannot switch back to sidelights once the vehicle is in motion, so I have to drive around with low beam headlights on when they kick, often way too early and in daylight whether I want them on or not.
I coded my F32 to have front DRL brightness in sidelight position and also coded rear taillights as part of front DRL.
I think the car looks better and more noticeable with rear leds and front DRL on at all times, until it gets dark, when I would put the low beam headlights on or flick the switch to Auto.
I would like to be able to code the parameters of the G20, as I did with my F32.
      05-12-2020, 03:20 PM   #30
murderedg20
murderedg20's Avatar
Drives: 2019 330i M Sport
Yeah I coded it with bimmercode.
BDC
Expert Mode
3702LicFeatures
Feature_4 (I think you change it to aktiv or whatever the option is that it isn't on)
      05-13-2020, 01:09 AM   #31
Watzek
Watzek's Avatar
Drives: BMW G20
Glad to see that Bimmercode beta now has tail light DRL activation.
Hope that helps!
Hope that helps!
Is that coding valid for E-Sys or for Bimmercode Expert-Mode?
      05-13-2020, 07:05 AM   #32
RSnic
RSnic's Avatar
Hope that helps!
Hope that helps!
@JoeWaschl
I do not see why not. I have coded using both
Hope that helps
Al
Retired: 2014 328i
BMW CCA
      05-18-2020, 03:13 PM   #33
marcospoffo
marcospoffo's Avatar
Brazil
17
Drives: 320 F30 - 2013
Why can't I find this option DAYDRIVING_LIGHT_REAR. I've tried here in Brazil is 3 G20, a G29 and G05. The last G20 I tried was this week after being upgraded to the latest version at the reseller.
@Basti@G20 320D,
Hope that helps!
320 F30 2013.
      05-18-2020, 05:39 PM   #34
larrylam646
larrylam646's Avatar
Drives: 2020 M340i xDrive
Try "DAYDRIVING_LIGHT"
2020 Black Sapphire M340iX
      05-19-2020, 11:57 AM   #35
andy5468
andy5468's Avatar
90
Just activated mine yesterday with Bimmercode in expert mode and it works fine.
No need to do the DAYDRIVING_LIGHT_REAR with Bimmercode. I could not find any such option in Bimmercode.
All you need to do is go into BDC in Expert Mode > 3702LicFeatures
Feature_4 and change to Activ > code.
Rear LEDS are now on with front DRL's.
Next job for me is to go back into BDC in expert mode to enable the ability to turn off headlights (AUTO) if I want to whilst driving and get rid of the annoying "lights not off whilst driving" message.
In BDC01 (17BD)
OFF_IN_PWF_FAHREN_ERLAUBT to <aktiv>
MY8615.00
      05-19-2020, 02:34 PM   #36
marcospoffo
Brazil
17
Yes that exists. But it is already active. They are the frontal.
Yes through the BDC I can activate. But what I really wanted was to have the menu to be able to select the option on idrive when I felt like it. But thanks!!
In BDC01 (17BD)
320 F30 2013.
      05-19-2020, 03:01 PM   #37
larrylam646
You can add the menu item to your iDrive by FDL coding "DAYDRIVING_LIGHT" to "standard" in the HU_MGU. This menu item can be found in CAR--> Settings--> Exterior lighting
      05-19-2020, 05:28 PM   #38
marcospoffo
Brazil
17
Yes it already has. But the friend up there managed to activate separately. DRL from the front and DRl from the back. Two separate menus.
320 F30 2013.
      05-19-2020, 06:24 PM   #39
larrylam646
I was not aware that was possible.
      05-20-2020, 07:12 AM   #40
Slim999
Russia
Drives: F30 320D M-Pack Estoril Blue
2017 BMW X3 G01  [0.00]
DRL from the front and DRl from the back. Two separate menus:
      05-20-2020, 11:35 AM   #41
pneumodoc
pneumodoc's Avatar
233
Drives: G20, G01
Does the rear DRL being on look different than the lights being on?
      05-20-2020, 02:06 PM   #42
andy5468
andy5468's Avatar
90
Anyone know where I can find the following in BDC using android Bimmercode? OFF_IN_PWF_FAHREN_ERLAUBT.
Tried to find this today to enable my AUTO lights to be switched off with the engine running , but could not find it.
someone said I would find it here - BDC01 (17BD) but there is no such module located in BDC in my Bimmercode expert mode. Maybe this is just for ESYS?
      05-22-2020, 04:58 AM   #43
MY86
MY86's Avatar
Turkey
15
Drives: G30 520i G20 320i
Hi,
How do you do that?
- Just found it
HU_MGU / DAYDRIVING_LIGHT_REAR (something like that) change it to 'aktiv' and it becomes available on the ID 7 screen.
      05-22-2020, 02:35 PM   #44
andy5468
andy5468's Avatar
90
Yes. When the sidelights are on, the front lights are dimmed with rear lights. When the headlights are on, you have low beams on at the front with rear lights.
When you code rear DRL, you have full brightness DRL at the front with the rear lights.
Everyone has their own preferences on the light set up on their car.
